ADC-to-Millivolts running in background of Spin2
cgracey
in Propeller 2
In the new PNut_v34p I just posted, there's a new program called ADC_to_VGA_millivolts.spin2.
It has a PASM program that runs in the background of Spin2 to perform calibrated ADC measurements, where it resolves to millivolt values. I changed the way REG[] works in Spin2, so that you can easily reference any registers declared under ORG blocks, and address them within your own cog. You can see in the 4th line below "PUB go() | i" how REG can be used:
The program assumes VIO is 3.300V. Because of mismatch in the calibration resistor paths, readings are offset by a few mV on top and bottom. If I get a chance to redesign the ADC, I will put the calibration switches BEFORE the big resistor. That would reduce the error by quite a bit. Note that the first pin is tied to GND, while the second pin is tied to VIO. Some pins are quieter than others and I'm not sure why. I believe it has to do with process variances between components within the ADC circuits.
Here is a picture of it running:
' Program reads 1..8 consecutive ADC pins and displays millivolts for each.
' A terminate-stay-resident PASM program performs conversions in background.
' Samples are always available via REG[samples][{0..7}].
CON
_clkfreq = 297_000_000 'set clock frequency
_pins = 16 addpins 7 'do conversions on these pins
OBJ
vga : "VGA_640x480_text_80x40" '_clkfreq >= 50MHz
' vga : "VGA_1280x1024_text_160x85" '_clkfreq >= 216MHz
' vga : "HDTV_1920x1080_text_240x90" '_clkfreq >= 297MHz
' vga : "HDTV_1920x1080_text_135x160" '_clkfreq >= 297MHz
PUB go() | i
vga.start(8) 'start vga
reg[pins] := _pins 'set 'pins' variable
regexec(@adc_pasm) 'launch PASM program (uses 'pins')
send := @vga.print 'set send pointer
repeat 'print samples set every 100ms
repeat i from 0 to _pins >> 6
send(dec4(reg[samples][i]), "mV ")
send(13)
waitms(100)
PRI dec4(value) | digflag, negflag, place, digit
digflag~
negflag := value < 0
abs= value
place := 1_000
repeat
if digflag || (digit := value / place // 10) or place == 1
if not digflag~~
send(negflag ? "-" : " ")
send("0" + digit)
else
send(" ")
if place == 1_000
send(digflag ? "," : " ")
while place /= 10
DAT
'* PASM Program which launches via REGEXEC *
'* Sets up an interrupt and then runs in the background *
'* Performs calibrated ADC measurements of up to 8 pins *
'* Reports samples in millivolts *
' REGEXEC header words
adc_pasm word adc_start 'initial register to load
word adc_end-adc_start-1 'additional registers to load
org $B0 'put PASM code up high
' ADC program setup
adc_start fltl pins 'set pins to ADC mode
wrpin adc_modes,pins
wxpin #9,pins '#9 is 512-clock, 10-bit conversion (8 per sample)
drvl pins 'start pins on same clock
mov pin_base,pins 'get pin base
and pin_base,#$3F
mov pin_count,pins 'get pin count
shr pin_count,#6
add pin_count,#1
mov level_base,#adc_levels 'prepare level_base altd pointer
sub level_base,pin_base
bith level_base,#9
mov ijmp1,#adc_isr 'set interrupt jump
mov x,pin_base 'set base pin IN-rise event
or x,#%001<<6
setse1 x
_ret_ setint1 #int_se1 'enable interrupt on event, return to Spin2
' ADC interrupt service routine - runs in background of Spin2 interpreter
adc_isr akpin pins 'ADC samples done, acknowledge pins
alts cycle,#vio_levels 'lookup vio and gio levels for sample computation
mov x,0
alts cycle,#gio_levels
mov y,0
sub x,y '(3300 << 12) / (vio_level - gio_level)
qdiv ##3300<<12,x 'cordic runs during REP
rep #3,pin_count 'read ADC samples and sum into adc_levels
rdpin x,pin_base
altd pin_base,level_base
add 0,x
sub pin_base,pin_count 'restore pin_base
getqx x 'get QDIV quotient
alts cycle,#pin_levels '(quotient * (pin_level - gio_level)) >> 12
subr y,0
muls y,x
sar y,#12
altd cycle,#samples 'write finished sample
mov 0,y
incmod cycle,#7 wc 'repeat for 8 cycles
if_nc reti1 'return to Spin2
altd state,#adc_modes 'end of 8th cycle, switch to next gio/vio/pin
wrpin 0,pins
resi1 'return to Spin2, resume on next interrupt
akpin pins '9th cycle, acknowledge pins
alts state,#moves 'move adc_levels to gio/vio/pin_levels
mov x,0
rep #2,pin_count
alti x,#%111_111
mov 0,0
akpin pins '10th cycle, acknowledge pins
setd x,#adc_levels 'clear adc_levels
rep #2,pin_count
alti x,#%111_000
mov 0,#0
incmod state,#3 'increment state
mov ijmp1,#adc_isr 'return to Spin2, start over on next interrupt
reti1
' Defined data
cycle long 0 'cycles {0..7, 0, 0} for each state
state long 0 'states {0..3}
adc_modes long p_adc_gio | p_adc 'adc modes, by state
long p_adc_1x | p_adc
long p_adc_vio | p_adc
moves long pin_levels<<9 | adc_levels 'moves, by state
long gio_levels<<9 | adc_levels
long vio_levels<<9 | adc_levels
adc_end 'end of PASM code to load into registers
' Undefined data
pins res 1 'initially set by Spin2 code to select the pins
x res 1
y res 1
pin_base res 1
pin_count res 1
level_base res 1
adc_levels res 8 'conversions are accumulated into this buffer
gio_levels res 8 '..and then copied to one of these three buffers
vio_levels res 8
pin_levels res 8
samples res 8 'final samples, available via REG[samples][{0..7}]
' cycle operations
' 0 (1st) add conversions to levels, compute sample[0]
' 1 add conversions to levels, compute sample[1]
' 2 add conversions to levels, compute sample[2]
' 3 add conversions to levels, compute sample[3]
' 4 add conversions to levels, compute sample[4]
' 5 add conversions to levels, compute sample[5]
' 6 add conversions to levels, compute sample[6]
' 7 (8th) add conversions to levels, compute sample[7], switch to gio/vio/pin
' 0 (9th) move levels to gio/vio/pin_levels
' 0 (10th) clear levels, advance state
' state operations
' 0 sample gio for calibration
' 1 sample pin for signal
' 2 sample vio for calibration
' 3 sample pin for signal
There is another thread talking about chopper-handling a thermocouple signal, but I suspect the P2 noise floor may be too high for that direct use ?
I'm not sure, but it can digitize complex waveforms with 30 millivolts of amplitude at full scale.
I have been out of the loop for three weeks. I see version Q. What is the latest version. Where is this posting about PNut_34 p and the es to ADC_to_VGA_millivolts.spin2.
I am confused.
Had to convert in class curriculum at my Aircraft Mechanic school to online in less than two weeks. Now finally coming up for air and getting back to the P2
Martin
http://forums.parallax.com/discussion/171196/pnut-spin2-latest-version-v34q/p1
