Elev-8 system setup motors to not turn but work if armed and using the controller the motors work. — Parallax Forums
I can not get the motors to turn in system setup. If I arm the Elev-8 all the motors spin fine , throttle works , everything seems good. But I can not properly calibrate the motors. The beep and led works fine. Ideas?
