Over Clocking Prop 1 "C"
in Propeller 1
I would like to try over clocking the prop. My reason is too try and gain a little speed. I will probably be using the Propeller Project Board USB to attempt this(product #32810). It looks like by using the 6.25MHZ crystal, 100MHZ can be achieved.
My question is in simple IDE C where does a person change the config from the default frequency? For some reason I cannot find it.
Shawn A.
Shawn A.
ModEdit : Moved !
I overclock many of my boards to 104MHz although they easily run over 110MHz. My last board I run at 96MHz because I wanted to do bit-banged USB although I never got around to it.
IIRC Chip said around 114MHz is the maximum PLL although Sapieha had my TriBlade (DIP40) running at 115MHz for weeks.
So, YMMV.
It appears that you can define a custom config file with the appropriate clock frequency you want to use. Here is an excerpt from then SimpleIDE User Guide:
Hopefully the above info answers your question.
It was way too nice outside today to be playing with the propeller!
