Spin2 - Page 12 — Parallax Forums
Spin2
191012141518
  • It really depends on how many symbols you have in the program. For small numbers of symbols then sure hash-bucket collisions will be rare, but for larger numbers of symbols you will get bucket collisions unless you use a vary large number of buckets.
    P2 programs are able to be much much larger with a lot more symbols.
    edited 2020-02-09 08:14
    Roy Eltham wrote: »
    Yes, I agree. It just doesn't seem like comparing full hashes would be that much more efficient than comparing lengths, when maybe you'll never need to walk more than three entries, worst case. Chances are far greater that lengths will be the same than hashes, but the incidence of either, on top of a bucket collision, is near zero.
    P.S. I think I'm just wanting to economize, as a byte for the length is less than a long for the hash. And, the length byte is going to be there in any case, since the symbol name is packed into the linked record.
  • Well yeah, ultimately it doesn't matter that much what you do once you get to the bucket, most of the time savings is in getting there.
    My hashtable code is generic and doesn't know anything about the data stored in it. My entry is a hash key, a pointer to the entry data, and a next pointer (for buckets with multiple entries). The lookup is a FindFirst/FindNext mechanism.
    It's something I had already before I made OpenSpin. In reality, my hashtable is a combined hashtable and linked list (so there is a separate list next pointer in the entries), so you can walk all the entries in the table without keys.
    It's the FindSymbol() function in the symbol engine that knows what the data is and does the string compare of the find results.
    I got all the fast symbol stuff working, thanks to Roy. I rewrote all my symbol table code to work with the hashing. I need to find a big program that is typically slow to compile and then check the difference.
    Here is my new symbol code in the Spin/PASM compiler:
    ;*  Symbol Engine							*
    ; Hash table index ($1000 elements):
    ;	long:	pointer to symbol record (0=no record)
    ; Symbol records:
    ;	byte:	symbol length, including terminating zero
    ;	bytes:	symbol chrs + 0
    ;	long:	symbol value
    ;	byte:	symbol type
    ;	long:	pointer to next record (0=no record)
    ; Variables
    ddx		symbol_ptr			;these three must be set to the current symbol set
    ddx		symbol_ptr_limit
    ddx		symbol_hash_ptr
    ddx		auto_symbols_hash,1000h		;auto symbols
    dbx		auto_symbols,auto_symbols_limit
    ddx		auto_symbols_ptr
    ddx		main_symbols_hash,1000h		;main symbols
    dbx		main_symbols,main_symbols_limit
    ddx		main_symbols_ptr
    ddx		local_symbols_hash,1000h	;local symbols
    dbx		local_symbols,local_symbols_limit
    ddx		local_symbols_ptr
    dbx		symbol,symbol_limit+2		;+2 for obj.method extra byte and 0
    dbx		symbol2,symbol_limit+2
    ; Enter auto symbols into hashed symbol table
    enter_auto_symbols:
    		call	reset_auto_symbols
    		call	write_auto_symbols
    		lea	esi,[automatic_symbols]	;reset pointers
    @@next:		call	hash_symbol		;hash symbol name to get length
    		lea	edi,[symbol2]		;copy symbol name to symbol2
    	rep	movsb
    		lodsd				;get value
    		mov	ebx,eax
    		lodsb				;get type
    		call	enter_symbol2		;enter symbol
    		cmp	[byte esi],0		;end of automatic symbols?
    		jne	@@next
    @@done:		ret
    ; Reset auto/main/local symbols
    reset_auto_symbols:
    		mov	edi,offset auto_symbols_hash
    		jmp	reset_hash_table
    reset_main_symbols:
    		mov	edi,offset main_symbols_hash
    reset_local_symbols:
    		mov	edi,offset local_symbols_hash
    reset_hash_table:
    		xor	eax,eax
    		mov	ecx,1000h
    		rep	stosd
    		ret
    ; Write auto/main/local symbols
    write_auto_symbols:
    		mov	[symbol_ptr],		offset auto_symbols
    		mov	[symbol_ptr_limit],	offset auto_symbols + auto_symbols_limit - (1+32+1+4+1+4)
    		mov	[symbol_hash_ptr],	offset auto_symbols_hash
    		ret
    write_main_symbols:
    		mov	[symbol_ptr],		offset main_symbols
    		mov	[symbol_ptr_limit],	offset main_symbols + main_symbols_limit - (1+32+1+4+1+4)
    		mov	[symbol_hash_ptr],	offset main_symbols_hash
    		ret
    write_local_symbols:
    		mov	[symbol_ptr],		offset local_symbols
    		mov	[symbol_ptr_limit],	offset local_symbols + local_symbols_limit - (1+32+1+4+1+4)
    		mov	[symbol_hash_ptr],	offset local_symbols_hash
    		ret
    ; Enter symbol2 into symbol table
    ; symbol2 must hold name, terminated with 0
    ; al must hold type
    ; ebx must hold value
    enter_symbol2:	push	eax
    		push	ecx
    		push	edx
    		push	esi
    		push	edi
    		push	eax			;save type
    		mov	edi,[symbol_ptr]	;get symbol record pointer
    		cmp	edi,[symbol_ptr_limit]	;make sure symbol table has enough room for another symbol
    		jae	error_stif
    		lea	esi,[symbol2]		;hash symbol2 name to get length and hash index
    		call	hash_symbol
    		add	edx,[symbol_hash_ptr]	;get hash table pointer
    		jmp	@@check			;append new record
    @@skip:		mov	edx,eax			;point to next record
    		movzx	eax,[byte edx]		;skip over record
    		add	eax,1+4+1		;account for length byte, (symbol length in eax), value long, type byte
    		add	edx,eax
    @@check:	mov	eax,[edx]		;check link
    		or	eax,eax
    		jnz	@@skip			;if not zero, skip again
    		mov	[edx],edi		;link and enter record
    		mov	al,cl			;enter symbol length
    		stosb
    	rep	movsb				;enter symbol name with terminating zero
    		mov	eax,ebx			;enter symbol value
    		stosd
    		pop	eax			;enter symbol type
    		stosb
    		xor	eax,eax			;enter new link terminator
    		stosd
    		mov	[symbol_ptr],edi
    		pop	edi
    		pop	esi
    		pop	edx
    		pop	ecx
    		pop	eax
    		ret
    ; Find symbol in auto/main/local symbol table
    ; symbol must hold name, terminated with 0
    ; if found, eax=type and ebx=value
    ; if not found, eax=0 (type_undefined) and ebx=0
    find_symbol:	push	ecx
    		push	edx
    		push	esi
    		push	edi
    		lea	esi,[symbol]		;hash symbol name to get length and hash index
    		call	hash_symbol
    		mov	ebx,offset auto_symbols_hash		;search auto symbols
    		call	@@find
    		jnc	@@found
    		mov	ebx,offset main_symbols_hash		;search main symbols
    		call	@@find
    		jnc	@@found
    		mov	ebx,offset local_symbols_hash		;search local symbols
    		call	@@find
    		jnc	@@found
    		xor	eax,eax			;symbol not found
    		xor	ebx,ebx
    @@found:	pop	edi
    		pop	esi
    		pop	edx
    		pop	ecx
    		ret
    @@find:		push	edx			;preserve hash table index
    		add	edx,ebx			;get hash table pointer
    @@link:		mov	edx,[edx]		;check for symbol record
    		cmp	edx,1			;if record < 1 then c=1
    		jc	@@nope			;if no record, symbol not found, c=1
    		movzx	eax,[byte edx]		;get symbol length
    		inc	edx			;point edi to symbol
    		mov	edi,edx
    		add	edx,eax			;point edx to next link
    		add	edx,4+1
    		cmp	eax,ecx			;if symbol size mismatch, check next link
    		jne	@@link
    		push	ecx			;symbol size match, compare symbol names
    		push	esi
    	repe	cmpsb				;c=0 if match
    		pop	esi
    		pop	ecx
    		jne	@@link			;if names mismatch, check next link
    		mov	ebx,[edx-1-4]		;found symbol, get value
    		movzx	eax,[byte edx-1]	;get type, c=0
    @@nope:		pop	edx
    		ret
    ; Hash symbol at esi
    ; on exit:
    ;	ecx = symbol length, including terminating zero
    ;	edx = hash index
    hash_symbol:	push	eax
    		push	esi			;save symbol pointer
    		xor	ecx,ecx			;reset symbol length
    		xor	edx,edx			;reset hash
    @@hash:		xor	eax,eax			;get symbol chr into eax
    		lodsb
    		inc	ecx			;inc length
    		cmp	al,0			;if chr = 0, finish hash
    		je	@@finish
    		add	edx,eax			;hash += chr
    		mov	eax,edx			;hash += (hash << 10)
    		shl	eax,10
    		add	edx,eax
    		mov	eax,edx			;hash ^= (hash >> 6)
    		shr	eax,6
    		xor	edx,eax
    		jmp	@@hash			;next chr
    @@finish:	mov	eax,edx			;hash += (hash << 3)
    		shl	eax,3
    		add	edx,eax
    		mov	eax,edx			;hash ^= (hash >> 11)
    		shr	eax,11
    		xor	edx,eax
    		mov	eax,edx			;hash += (hash << 15)
    		shl	eax,15
    		add	edx,eax
    		mov	eax,edx			;make 12-bit hash index
    		ror	eax,16
    		xor	edx,eax
    		mov	eax,edx
    		shr	eax,32-4
    		xor	edx,eax
    		and	edx,0FFFh
    		shl	edx,2
    		pop	esi			;restore symbol pointer, ecx=symbol length, edx=hash index
    		pop	eax
    		ret
    ; Backup symbol to symbol2
    backup_symbol:	push	ecx
    		push	esi
    		push	edi
    		lea	esi,[symbol]
    		lea	edi,[symbol2]
    		mov	ecx,symbol_limit+2
    	rep	movsb
    		pop	edi
    		pop	esi
    		pop	ecx
    		ret
    edited 2020-02-11 23:37
    Okay, here is the latest PNut_v34b.exe with Spin2. Spin2 is not documented, yet, but you can get a taste of it here. This compiler should be super fast now with the hashed symbol tables.
    https://drive.google.com/file/d/1HWnhswX2fd3W9H1gYSFqNeWToBMO7N7T/view?usp=sharing
    There is a Spin2 VGA demo and driver in this .zip file. Also, the current Spin2 interpreter and flash loader sources are there, and they are now built into PNut. Just an F10 or F11 runs or programs your code into the P2.
    Here is the latest Spin2 operators file.
  • Chip, C++ STL offers hashed tables for free, no development required...hint, snicker :wink:
  • evanhevanh Posts: 17,288
    pedward wrote: »
    ... C++ STL offers ...
    And ... instantly bloated.
  • Yes, if the goal is to put something native on P2, chip working in assembly right now makes a lot of sense.
    edited 2020-02-09 23:47
    potatohead wrote: »
    It's just habit for me, mainly. It only took several hours to get the whole hashing thing worked out and implemented into the symbol table system, thanks to Roy's timely help. I was thinking I wouldn't get to this for a few more months because of a bunch of other stuff I need to do, but I had a dream about it the other night and I had a strong confidence I could do it. Everything Roy ever said about his solution stuck in my mind.
    Now, has anybody even tried it out? Spin2 is working. That's the bigger news. The faster symbol system just makes it a lot snappier than it's ever been.
  • I am about to. This is a great day. Thanks Chip!
  • potatohead wrote: »
    This was x86 assembly in the compiler, not PASM.
    I realize Chip is writing what he knows, but the compiler is only maintainable by him, which makes him a source of contention in Parallax's workflow.
    I don't care is pulling in the STL causes some minor bloat, it eliminates technical debt, uses a standard interface, reduces security vulnerabilities, and it makes the code maintainable by other people.
    The P* ecosystem is so fragmented right now it's crazy. There are what, 4 or 5 spin compilers and 3 C compilers at this point?
  • Thanks Chip!
    Looking forward to putting Spin2 to work.
    potatohead wrote: »
    This is a great day!
    +1 :)
    That's a lot of whinging there Pedward.
  • JRoarkJRoark Posts: 1,215
    edited 2020-02-10 00:32
    Yep! But IMHO, that really should be listed as a feature, not a bug. To wit: If half of the compiler creators were simultaneously kidnapped by aliens, we’d *still* have a nice, maintainable tool set.
    Maybe if Parallax was a billion dollar company, with 30 people committed 24/7 to developing these languages against a firm release date and a published hardware spec, this criticism might stick. Instead we have a virtual do-ocracy, where some unpaid enthusiasts saw a need, picked-up the ball, and ran with it. For free. Epically.
    So I’m OK with the fragmentation. :) And I’m frankly impressed with how the individual creators have negotiated some standards and achieved a respectable degree of interoperability. And they did all of this for free, without any official support from Parallax, or even a comprehensive hardware specification, and they did it before the chip was even officially released.
    IMHO, thats just really cool. Kudos to them!
  • Downloaded PNut, and the vga demo works as expected.
    The PNut text editor doesn't show any scrollbars. I'm using Windows 7 Pro x64.
    Would be nice to have a vertical scroll bar at least.
  • @ cgracey
    Excellent!!. Thanks Chip!!
    It's working great :)
    959 x 665 - 1M
    Until the documentation comes together, you can peruse the Spin2 interpreter source to see the various commands.
    Future improvements to make:
    1) automatic constant resolving
    2) dead code removal
    3) debugging - a biggie, formative
    I know we need a scroll bar.
    > @"Bob Lawrence (VE1RLL)" said:
    > @ cgracey
    Try F11. It will run the program on every reset and power-up. Be sure to turn on the DIP switch for the flash.
  • Working great here too!
    Really glad you got here Chip!
    @pedward
    Yeah, lots of tools. Wonderful problem to have.
    Re: Chip working x86 assembly
    This limits things, forces thought back down to the nubs. The product is lean and mean.
    It will all translate to PASM and be the same way.
    Had it been written with something big, higher level, what got done just now would be a dream, likely never completed.
    Early on, the point of this exercise was to design chip and tools as one cohesive thing. Now that goal has been actualized, Chip can continue on with some vision he has had for an long time.
    Meanwhile, there are a ton of tools! Nobody is really inhibited at this point.
    Beautiful to see.
    Remember the "only Prop Tool" discussion on P1, until Bill thought up LMM?
    Not even a thought on P2, we have HUBEXEC.
    Oh, I forgot to mention that Jeff Martin is plugging the new compiler into the PropellerTool. That has scroll bars and context highlighting.
  • pedward,
    I code for a living in C++ making commercial products, we don't use STL hardly at all. It's slow (unless you do a bunch of extra work with overriding memory allocation), bloated, and not really cross platform (many things don't work on many platforms).
    STL is cool and all if you don't have alternatives, but don't think of it as the end all be all, and certainly be careful how you use it, because it lets you paint yourself into really bad performance.
    However, if Chip was using C or C++ he could have used mine, and I could have helped more along the way.
    Anyway, really glad to see Spin2 in the wild.
  • cgracey wrote: »
    Excellent!
    Hope to hook my debugger to Spin2 soon and watch it work it's magic.
    edited 2020-02-10 02:51
    For anyone that wants to print it , it's only 49 pages :)
    potatohead wrote: »
    Thanks heaps Chip :smiley::smiley::smiley:
    Unfortunately I won't get a chance to try it out until next w/e. I have some great things that require Spin2 and I really wanted to keep it in the Spin2 language. First cab off the rank is Kye's FAT32 driver - I've done the P2 AMS section months ago. Once that is working, my OS for P2 will almost fall out as done :sunglasses:
    JRoark wrote: »
    +1
  • ozpropdev wrote: »
    Excellent!
    !!! That's going to be very fun.
  • So I’m OK with the fragmentation. :) And I’m frankly impressed with how the individual creators have negotiated some standards and achieved a respectable degree of interoperability. And they did all of this for free, without any official support from Parallax, or even a comprehensive hardware specification, and they did it before the chip was even officially released.
    I have to second this. Nice work people. It's super appreciated. High value.
    Thank you. Mean it.
  • +1
  • JRoark wrote: »
    +1
  • cgracey wrote: »
    What happened to PropellerIDE? I thought that was going to be the cross platform replacement for the PropellerTool. Will PropellerIDE be updated to work with Spin2?
