Tachyon NEON V5 (FAT32 and Ethernet Servers in 32kB EEPROM!)
1151617181921»
  • MJBMJB Posts: 1,149
    I used the command line tool under Linux; I think that loading the file into PropellerIDE added some line breaks or something which prevented it from working. Certainly it is working now!
    /opt/parallax/bin/propeller-load -r TACHYON.binary
    Now all I have to do is learn Forth! :-D
    welcome - and have FUN
    just start with Peter's examples and oneliners with immediate feedback
    then work through the stack words and watch a lot with .S
    so you get a feeling whats going on under the hood
  • Peter JakackiPeter Jakacki Posts: 8,980
    edited 2019-10-27 - 03:56:26
    @SirWorldwide
    There is just so much runtime and dev stuff built into Tachyon that I tend to forget myself. Even the control key shortcuts are handy such as ^? to list the current stack and stats. ^S is also handy for clearing the stack too. If you want to know more about a word then type HELP <word> and it will list the internals of it including header info.
    A terminal capture example of using HELP
    ...  : MYDEMO 10 FOR I . NEXT ;
    ...  MYDEMO --> 0 1 2 3 4 5 6 7 8 9  ok
    ...  HELP MYDEMO
    5A3C 3C84 0 MYDEMO
    ADDR: DATA  NAME
    3C84: 800A  10
    3C86: 0156  FOR
    3C88: 0172  I
    3C8A: 0416  .
    3C8C: 0166  NEXT
    3C8E: 005A  EXIT
    If you want to test code that can fit onto one line then you don't need to define a word before executing it. In the case of MYDEMO you could just as easily type in "10 FOR I . NEXT" interactively. Normally you can't have compile-only words executed interactively in traditional Forths, and there are no special interpret vs compile words either so that ." HELLO WORD" works either way.
  • Hi there,
    Is there a way to include files to build your application?
    INCLUDE CONFIG.FTH
    INCLUDE RELAY.FTH
    INCLUDE ALARM.FTH
    INCLUDE MAIN.FTH
    kdewey wrote: »
    Hi there,
    INCLUDE CONFIG.FTH
    INCLUDE RELAY.FTH
    INCLUDE ALARM.FTH
    INCLUDE MAIN.FTH
    Forth does not use a classical compile/link model. Instead an IMAGE-Model.
    Just start from a base Tachyon image with Kernel, Extend, (Filesystem ...) loaded.
    And then paste in additional code from your editor into the terminal.
    after "loading"/"including" all this code
    do a BACKUP and the actual status of the image is saved into EEPROM - ready at next boot.
  • @ErNa - it's worse than that! :smile: Not only is there a test version of EASYFILE but there is also the TAQOZ version being rehashed, all into one. So all those goodies that I've done for TAQOZ including formatting etc will work on the P1 too! In the process Tachyon and TAQOZ will be more compatible which may involve some renaming etc so that the new Tachyon will become a V6 Turbo. Part of this testing involves digging out dozens of different designs of mine and checking it on them too. I am even playing with one of Cluso99's P8XBlade2 modules that I had to replace the crystal with a 6Mhz cylindrical type to get it working though. Wonder what was wrong with it? :wink:
    If it weren't for compatibility I would never bother with any MS filesystem. Besides none of them are really designed for SD cards or embedded systems. But I try to make the best of it by imposing my own operating conditions once it is in a system.
    Unusual as I test all pcbs properly. Remember it uses a 12MHz xtal so you must use pllx8.
  • RS_JimRS_Jim Posts: 1,338
    edited 2019-12-10 - 15:27:41
    edit post deleted
    Hi @Peter Jakacki
    while reading
    module EXTEND ." Primary extensions to TACHYON V5 kernel - 190916-0730 " ;
    I discovered that WRAP is defined as pre as well as pub
    --- define a wrap constant := val & size-1
    pre WRAP
    CREATE ( size -- ) W,
    DOES> ( val -- val2 ) R> W@ 1- AND
    pub WRAP ( on/off -- ) '?' ESCB '7' AEMIT asw ;
    to my understanding the later will make the first unaccessible.
    ' WRAP 10 DUMP gives the pub code.
    I like the clean programming with CREATE DOES> :-)
  • @MJB - There's so much stuff packed into the humble P1 with Tachyon that even I lose track of it all :)
    I see the pre WRAP is defined as a modulo wrap constant defining word, but I can't remember ever using it! The latter WRAP to control ANSI wrapping could be used but once again I've never used it.
    I would rename the pre WRAP to something to indicate modulo operation perhaps.
    So, when are you going to start using TAQOZ and the P2???
    as you see at least I started with Tachyon again.
    Just interfacing a
    pzem-004t
    power monitor to log what my water pumps are doing.
    Very dry here - luckily just one big rain event filled most of my reservoir, so for the comming summer I am ok now.
    Hope you are save with all the bush fires there ...
    TAQOZ and the P2: when P2D2 + dev board are ready let me (us) know the cost so I can order
