return 0 in void main () is because I first tested it on the PC with the usual int main (). When copying into the P2 testsuite I forgot to delete. I have now done that because I noticed that after posting. But it doesn't change the result.
I want to use fabs() in the underlaying code.
In the function cplx_mult_float (z1r,z1i,z2r,z2i,&result_r,&result_i) I'll make a standardization to an unit vector. My first idea was to check with fabs whether this was necessary.
What I meant is to put this at the end of main() so that the function doesn't exit. Exiting main() probably halts the chip or something like that.
while (1) ;
I tested it with the infinite loop, although it was never necessary, but it doesn't change anything.
The generated pasm file says:
calla #_main
cogexit
cogid arg01
cogstop arg01
the problem is
if ( fabs(real1) >= 1.0 )
is always true.
By the way, the code above only has to do with the problem because I want to show what I need fabs for. But I think I can solve it differently.
> The generated pasm file says: calla #_main cogexit cogid arg01 cogstop arg01
> the problem is if ( fabs(real1) >= 1.0 )
> is always true.
> Reinhard
It's the stopping of the COG that I thought might be causing your problem. I've sometimes had trouble with that.
@Reinhard: I think the fabs bug has already been fixed in github. The fabs function was defined in Spin and didn't have a return type, so in the comparison it was being treated as an integer. Assigning it to a temporary variable (float t = fabs(real1), then using "t" everywhere you had fabs(real1)) would be a work-around. Or you could build the beta from source. I hope to put out a new release "soon", but things keep coming up to delay it .
No rush.
as soon as new sources are available, I compile the current status.
I just noticed that they are not just doing FlexGui, which already supports some languages. But also uPhyton and an risc compiler.
I did some tests with upython, everything was great, but I'm not a py programmer.
what i want to say, take your time and don't allow any stress.
Eric, it looks like fastspin 4.1.0 now supports Chip's RevB+ silicon PNut changes of the |< operator to DECOD and the >< operator to REV when used in a CON block?
DECOD works as expected but REV appears to work the same as >< where it reverses the number of bits, whilst the new REV syntax is in terms of MSB bit position:
CONSPIN1_REV = %0_0101 >< 5 ' %1_0100 count of bits
PNUT_REV = %0_0101 REV (5 - 1) ' %1_0100 new syntax MSB is bit 4, fastspin result is %1010
Just an observation. I noticed a difference between Propeller Tool v1.3.2 and flegui4.10 from a SPIN/PASM standpoint. Code compiles fine in Propeller Tool but errors are thrown in Flexgui compiling for a Prop1 on Windows 10.
The label asm throws an Error in Flexgui but compile fine in Propeller Tool.
{{ Tutorial 3 Basic addition in pasm}}
CON_clkmode = xtal1 + pll16x_xinfreq = 5_000_000varlong x
long y
long total
obj
pst:"parallax serial terminal"pubmain
x := 30
y := 45
pst.start(115200)
waitcnt(clkfreq*5 + cnt)
cognew(@asm, @x)
waitcnt(clkfreq*2 + cnt)
pst.str(string("total:"))
pst.dec(total~)
pst.newline
dat
asm orgmov tempvar, par' get the address of x from parmov xvar, tempvar ' assign the address to the xvar in pasmrdlong xvar, tempvar ' read the value that is in x add tempvar, #4' move over one long to get the address of y mov yvar, tempvar ' assign the address to yvarrdlong yvar, tempvar ' read the value that is in yadd tempvar, #4' move over one long to get the address of totalmov totalvar, tempvar ' assign the address to totalvaradd xvar,yvar ' add x and y together , answer in xvarwrlong xvar, totalvar ' Write x into the total variable for printing{{ Reserved variables for PASM use }}
tempvar long0
xvar long0
yvar long0
totalvar long0
flag long0fit
@TrapperBob : thanks for the bug report. As @msrobots noted, the conflict is because fastspin has "ASM" as a new reserved keyword. For the next release I'll try to make this case and some similar ones work (by treating "ASM" as a regular label in some contexts) but for now changing the word "asm" to something else like "myasm" will fix the problem.
I personally like the version of inline pasm enclosed in asm...endasm better then Chips version of just using org.
It makes more sense as re-using org and is more consistent with the language itself. ASM can just be a reserved word. No need for context sensitive filtering.
What I think would be nice if that internal system.spin object (or however you call it) you are using to resolve methods not found in sub objects, could be shared between FLEX and Chips Interpreter.
That would also allow Chip to move some stuff in the common spin file like Smart Pin modes, or other SPIN language enhancements, while FLEX and the interpreter still will work alike.
@ersmith
I understand, that is not necessary to implement sin() and cos() in fastspin.
Therefore we have the cordic - unit.
But is it possible to implement asin() and acos() ?
or does someone know a way to calculate these functions with the available means?
I need this for a 'hot' project.
Reinhard
@ersmith While coding in FlexBASIC on Win10 using FlexGUI V4.1.0:
I'm having some relationship issues with FlexBASIC. Specifically, something appears wonky in the DATA/READ pairing. This code:
dim a(15) as ulong
dim n as long
data &h00_00_00_00, &h00_00_AA_00, &h00_AA_00_00, &h00_AA_AA_00, &hAA_00_00_00, &hAA_00_AA_00, &hAA_55_00_00, &hAA_AA_AA_00data &h55_55_55_00, &h55_55_FF_00, &h55_FF_55_00, &h55_FF_FF_00, &hFF_55_55_00, &hFF_55_FF_00, &hFF_FF_55_00, &hFF_FF_FF_00for n = 0 to 15read a(n)
print a(n)
next n
@JRoark ... remove the "_" in the data statements.
But is there a special reason to have the data statements?
Why not as shared array with initialiser?
$ cat jr20200125.bas
dim shared as ulong a(15) = { _
&h00_00_00_00, &h00_00_AA_00, &h00_AA_00_00, &h00_AA_AA_00, _
&hAA_00_00_00, &hAA_00_AA_00, &hAA_55_00_00, &hAA_AA_AA_00, _
&h55_55_55_00, &h55_55_FF_00, &h55_FF_55_00, &h55_FF_FF_00, _
&hFF_55_55_00, &hFF_55_FF_00, &hFF_FF_55_00, &hFF_FF_FF_00 _
dim n as long
for n = 0to15
print a(n)
next n
@ersmith
Reinhard
I think you could implement asin() and acos() in terms of the CORDIC xy to polar conversion. That is, acos(x) is the angle t for which cos(t) = x, so it's the angle you get when you convert (x, sqrt(1-x^2)) to polar coordinates (if x is in the appropriate quadrant, and is between 0 and 1). You do have to do some sanity checking and have code to handle negatives and such, but that's the basic idea. asin() is similar.
@JRoark : as you've discovered, the underscores aren't read properly in READ. Either get rid of them, or use @yeti's suggestion of initializing a static array instead of using DATA/READ. This is a bug, but the whole underscore thing is an extension anyway so I guess it could also be called a "feature" .
@yeti I didn't know you could do that! But that's how I'll do it from now on. Cool! And thanks!
@ersmith I think all this needs is a brief mention in the manual as a "fix". Honestly, I hate "data/read". It's ugly. But sometimes it's the only way.
What would be neat is having something in BASIC like the FILE feature of Spin. What led me to this point was trying to make a font table in BASIC that I can pass to Rogloh's video driver. In Spin its easy and you can stick a file in memory with just a...
FILE "myfont.fon"
...and Bob's your uncle. In BASIC... oy vey... you have to bang it in manually.
FILE "myfont.fon"
You can use FILE inside "asm shared" in BASIC:
asm shared
font
file "font.dat"
end asm
dostuffwith @font
I think the type of a label attached to a FILE will be "ubyte" but you can always cast the pointer you get.
Pretty much anything that can go in a Spin DAT section can go in asm shared.
I never even thought about using ASM SHARED. (Bangs head on keyboard). But I *did* hit on doing it from a Spin stub ala Yeti’s suggestion. So now Rogloh’s driver loads its own font and palette data, and I just query the driver for the addresses... (which for the moment I pass right back to the driver as a temporary fix. Lol).
I sincerely appreciate all of your help @ersmith and @yeti! And thanks again to @rogloh for making such an epic, hackable driver!
//Example: Multiplication of 2 complex numbers //input: z1 = real1,imag1 // z2 = real2,imag2 //calc: z3 = z1 * z2 //output: real3,imag3 // //testcase: z2 = conj(z1) //expected: z3 is pure real. imag3 = 0. #include <stdio.h> #include <unistd.h> #include <math.h> #include <propeller.h> #define P2_TARGET_MHZ 160 #include "sys/p2es_clock.h" #define BAUD 230400 #define TOFIX(d, q) ((int)( (d)*(double)(1<<(q)) )) #define TOFLT(a, q) ( (double)(a) / (double)(1<<(q)) ) #define q 16 void cplx_mult_float (double real1, double imag1, double real2, double imag2, double *res_r,double *res_i) { int32_t r1 = TOFIX(real1,q); int32_t i1 = TOFIX(imag1,q); int32_t r2 = TOFIX(real2,q); int32_t i2 = TOFIX(imag2,q); int32_t r; int32_t i; cplx_mult_fix (r1,i1,r2,i2,&r,&i); *res_r = TOFLT(r,q); *res_i = TOFLT(i,q); printf("--debug-- %X %X %X %X %X %X\n",r1,i1,r2,i2,r,i); } void cplx_mult_fix (int32_t real1, int32_t imag1, int32_t real2, int32_t imag2, int32_t * real3, int32_t * imag3) { int32_t _abs1; int32_t _arg1; int32_t _abs2; int32_t _arg2; int32_t _abs3; int32_t _arg3; int32_t result_lo = 0; int32_t result_hi = 0; __asm { qvector real1,imag1 //z1 to polar getqx _abs1 getqy _arg1 qvector real2,imag2 //z2 to polar getqx _abs2 getqy _arg2 //qmul _abs1,_abs2 //multiply the abs //getqx result_lo //getqy result_hi //add result_hi,result_lo mul _abs1,_abs2 mov result_lo,_abs1 mov _abs3,result_lo shr _abs3,#16 add _arg1,_arg2 //add the phase mov _arg3,_arg1 qrotate _abs3,_arg3 //z3 to cartesian getqx result_lo getqy result_hi mov outa,result_lo }; *real3 = result_lo; *imag3 = result_hi; } void main(void) { double z1r = 0.5; double z1i = 0.5; double z2r = 0.5; double z2i = -0.5; double result_r; double result_i; clkset(_SETFREQ, _CLOCKFREQ); _setbaud(BAUD); sleep(1); cplx_mult_float (z1r,z1i,z2r,z2i,&result_r,&result_i); printf("(%f,%f) * (%f,%f) = (%f,%f)\n",z1r,z1i,z2r,z2i,result_r,result_i); cplx_mult_float (1.0,1.0,1.0,-1.0,&result_r,&result_i); printf("(%f,%f) \n",result_r,result_i); cplx_mult_float (0.7,0.7,0.7,-0.7,&result_r,&result_i); printf("(%f,%f) \n",result_r,result_i); }
on the output you see the problem
loadp2 -t -b230400 -p/dev/ttyUSB0 cplx_mult_c.binary ( Entering terminal mode. Press Ctrl-] to exit. ) --debug-- 8000 8000 8000 FFFF8000 8000 0 (0.500000,0.500000) * (0.500000,-0.500000) = (0.500000,0.000000) --- correct --debug-- 10000 10000 10000 FFFF0000 2BEC 0 (0.171570,0.000000) --- not correct, here I need an unit vector --debug-- B333 B333 B333 FFFF4CCD FAE0 0 (0.979980,0.000000) ----- correct
Maybe I can think of a workaround.> return 0 in void main () is because I first tested it on the PC with the usual int main (). When copying into the P2 testsuite I forgot to delete. I have now done that because I noticed that after posting. But it doesn't change the result.
while (1) ;
the problem isif ( fabs(real1) >= 1.0 )
is always true.By the way, the code above only has to do with the problem because I want to show what I need fabs for. But I think I can solve it differently.
Reinhard
> is always true.
> Reinhard
No rush.
CON SPIN1_REV = %0_0101 >< 5 ' %1_0100 count of bits PNUT_REV = %0_0101 REV (5 - 1) ' %1_0100 new syntax MSB is bit 4, fastspin result is %1010
a REV b == a >< (b+1)
is that right?That would be it. Thanks, Eric!
{{ Tutorial 3 Basic addition in pasm}} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 var long x long y long total obj pst:"parallax serial terminal" pub main x := 30 y := 45 pst.start(115200) waitcnt(clkfreq*5 + cnt) cognew(@asm, @x) waitcnt(clkfreq*2 + cnt) pst.str(string("total:")) pst.dec(total~) pst.newline dat asm org mov tempvar, par ' get the address of x from par mov xvar, tempvar ' assign the address to the xvar in pasm rdlong xvar, tempvar ' read the value that is in x add tempvar, #4 ' move over one long to get the address of y mov yvar, tempvar ' assign the address to yvar rdlong yvar, tempvar ' read the value that is in y add tempvar, #4 ' move over one long to get the address of total mov totalvar, tempvar ' assign the address to totalvar add xvar,yvar ' add x and y together , answer in xvar wrlong xvar, totalvar ' Write x into the total variable for printing {{ Reserved variables for PASM use }} tempvar long 0 xvar long 0 yvar long 0 totalvar long 0 flag long 0 fit
rename the label to myasm and everything should work with both.
anyways,
I download the newest (4.0.1) Spin2cpp / Fastspin sources.
Problem with Parameter passing solved .
Reinhard
Reinhard
dim a(15) as ulong dim n as long data &h00_00_00_00, &h00_00_AA_00, &h00_AA_00_00, &h00_AA_AA_00, &hAA_00_00_00, &hAA_00_AA_00, &hAA_55_00_00, &hAA_AA_AA_00 data &h55_55_55_00, &h55_55_FF_00, &h55_FF_55_00, &h55_FF_FF_00, &hFF_55_55_00, &hFF_55_FF_00, &hFF_FF_55_00, &hFF_FF_FF_00 for n = 0 to 15 read a(n) print a(n) next n
...yields this for output:0, 0, 0, 0, 170, 170, 170, 170, 85, 85, 85, 85, 255, 255, 255, 255
What do you think? I'm torn between begging and chocolate here. lol.EDIT: Its the underscore characters. The parser is fine with the "&h" notation, but its fussy at the underscores.
$ cat jr20200125.bas dim shared as ulong a(15) = { _ &h00_00_00_00, &h00_00_AA_00, &h00_AA_00_00, &h00_AA_AA_00, _ &hAA_00_00_00, &hAA_00_AA_00, &hAA_55_00_00, &hAA_AA_AA_00, _ &h55_55_55_00, &h55_55_FF_00, &h55_FF_55_00, &h55_FF_FF_00, _ &hFF_55_55_00, &hFF_55_FF_00, &hFF_FF_55_00, &hFF_FF_FF_00 _ } dim n as long for n = 0 to 15 print a(n) next n
$ quiet fastspin jr20200125.bas $ spinsim -b jr20200125.binary 0 43520 11141120 11184640 2852126720 2852170240 2857697280 2863311360 1431655680 1431699200 1442796800 1442840320 4283782400 4283825920 4294923520 4294967040
FILE "myfont.fon"
From the version with "data":
00000d80 6b ee fc 5c 3b 84 fc 5c 26 68 30 30 30 30 30 30 |k..\;..\&h000000| 00000d90 30 30 2c 20 26 68 30 30 30 30 41 41 30 30 2c 20 |00, &h0000AA00, | 00000da0 26 68 30 30 41 41 30 30 30 30 2c 20 26 68 30 30 |&h00AA0000, &h00| 00000db0 41 41 41 41 30 30 0a 26 68 41 41 30 30 30 30 30 |AAAA00.&hAA00000| 00000dc0 30 2c 20 26 68 41 41 30 30 41 41 30 30 2c 20 26 |0, &hAA00AA00, &| 00000dd0 68 41 41 35 35 30 30 30 30 2c 20 26 68 41 41 41 |hAA550000, &hAAA| 00000de0 41 41 41 30 30 0a 26 68 35 35 35 35 35 35 30 30 |AAA00.&h55555500| 00000df0 2c 20 26 68 35 35 35 35 46 46 30 30 2c 20 26 68 |, &h5555FF00, &h| 00000e00 35 35 46 46 35 35 30 30 2c 20 26 68 35 35 46 46 |55FF5500, &h55FF| 00000e10 46 46 30 30 0a 26 68 46 46 35 35 35 35 30 30 2c |FF00.&hFF555500,| 00000e20 20 26 68 46 46 35 35 46 46 30 30 2c 20 26 68 46 | &hFF55FF00, &hF| 00000e30 46 46 46 35 35 30 30 2c 20 26 68 46 46 46 46 46 |FFF5500, &hFFFFF| 00000e40 46 30 30 0a 00 00 00 00 b6 02 00 00 cc 0e 00 00 |F00.............|
Compiled without optimisation:
$ ls -l jr*binary -rw-r--r-- 1 yeti yeti 2868 Jan 25 21:09 jr20200125.array.binary -rw-r--r-- 1 yeti yeti 3880 Jan 25 21:08 jr20200125.data.binary
asm shared font file "font.dat" end asm ... dostuffwith @font
I think the type of a label attached to a FILE will be "ubyte" but you can always cast the pointer you get.Pretty much anything that can go in a Spin DAT section can go in asm shared.
