Faster SPI Bus Transfers — Parallax Forums
cgraceycgracey Posts: 14,323
edited 2020-01-17 11:31 in Propeller 2
I'm working on the 2nd-stage flash booter for application launching. The first thing to sort out is how to quickly program the flash, so the user doesn't have to wait long. Then, the loader which executes on reset must pull the data from the flash into memory very quickly.
The regular way of looping to get the next data bit, outputting it, raising the clock, and lowering the clock is quite slow. I've been working out how to speed it up. This code runs off the RCFAST oscillator at boot, which is always over 20MHz and usually ~24MHz. The oscillator is designed to not drop below 20MHz, worst-case, to support auto-baud serial connections of up to 2Mbaud.
As a first pass, I used the smart pin mode which outputs timed transitions to generate the SPI clock. I then output the data manually in software. I was lamenting that I didn't make an instruction to just shift a register and output the bit to some pin. That would have made things really easy and fast. We don't have that, but I realized that the RCZL instruction, which rotates a register two bits left and puts the bits into C and Z could save some time. The transition mode can then generate the clock in the background while my code outputs the data bit stream. It works really nicely.
Here's the code:
CON		dpin	= 17		'data pin
		cpin	= 16		'clock pin
DAT		org
		hubset	#%10_00			'use 20MHz crystal for clean scoping
		waitx	##20_000_000/100
		hubset	#%10_10
		wrpin	#%01_00101_0,#cpin	'set cpin for transition-mode output
		wxpin	#2,#cpin		'timebase is 2 clocks per transition
.loop		mov	cmd,#$55	'ready cmd data
		shl	cmd,#24
		dirl	#cpin		'2	reset transition pin, reset timebase
		dirh	#cpin		'2	(outputs low during reset)
		rczl	cmd	wcz	'2	ready bits 7/6
		drvc	#dpin		'2!	output bit7
		wypin	#16,#cpin	'2	start 16 transitions
		drvz	#dpin		'2!	output bit6
		rczl	cmd	wcz	'2	ready bits 5/4
		drvc	#dpin		'2!	output bit5
		nop			'2
		drvz	#dpin		'2!	output bit4
		rczl	cmd	wcz	'2	ready bits 3/2
		drvc	#dpin		'2!	output bit3
		nop			'2
		drvz	#dpin		'2!	output bit2
		rczl	cmd	wcz	'2	ready bits 1/0
		drvc	#dpin		'2!	output bit1
		nop			'2
		drvz	#dpin		'2!	output bit0
		jmp	#.loop
cmd		res	1
And see the picture of what it does...
«13
  • evanhevanh Posts: 17,308
    A while back I reached a transmitting theoretical sysclock/2 using a sync tx smartpin by using the streamer (w/out FIFO) to generate the SPI clock on multiple pins - One of which was that smartpin's OUT and having the smartpin B-input fed back from its OUT signal. OUT being the only input source that didn't incur the I/O routing latencies. This allowed close enough timing to hit sysclock/2.
    That said, I never got round to testing it on a real SPI device. I think it was still RevA silicon.
    I remember Peter had asked if it was worth using the smartpins at all and I'd initially said not really.
    I then started working on using the streamer for SPI data and a smartpin for SPI clock. Which morphed into the HyperRAM work.
    edited 2020-01-17 12:27
    Smart pins and the streamer can be used together. You need a scope to see what's going on, though, for sure.
    I just got sysclock/2 working and it's mind-blowingly simple. Sometimes things just work out. It was accidental that it could work so perfectly. Just a minute...
    edited 2020-01-17 12:56
    I got the streamer doing the work of outputting the bits while the smart pin generates the clock, all at sysclock/2. This worked out so nicely, it's like a dream. Very much accidental that timing aligned, so that no padding was even needed. And it only takes 3 instructions! The first instruction is just there to prevent you from starting another stream before the last one is done. So, while the streamer and smart pin are working, you could be doing other stuff, which keeps the bandwidth really high.
    This means that running from RCFAST, not counting flash erase and program delays, you could load 512KB into the flash in just 400ms! No need to even use the crystal/PLL, which could actually make the software much more complicated.
    In this program, I'm outputting a whole 32 bits, which is what the loader will be doing to program the flash. Note that the data changes on the falling clock, so that it's stable during the rising clock. This will run SPI at over 10MHz using RCFAST:
    DAT		org
    		hubset	#%10_10
    		wxpin	#1,#cpin		'timebase is 1 clock per transition
    		drvl	#cpin			'when timebase = 1, no need to reset!
    		drvl	#dpin			'make data pin output
    		setxfrq	##$4000_0000		'set streamer rate to clk/2
    		xinit	#1,#0			'make streamer briefly busy so that the
    						'transfer-finished event occurs, so that
    						'the initial waitxfi doesn't hang
    .loop		mov	data,##$81_00_00_A9	'ready data, sent low byte first, MSB first
    		waitxfi			'2+?	make sure prior stream finished
    		xinit	mode,data	'2	start outputting data
    		wypin	#64,#cpin	'2	start clock transitions
    		jmp 	#.loop
    mode		long	$4081_0020 + dpin<<17	'streamer mode, 1-bit output, 32 bit data
    data		res	1
    Here's a picture of it running...
    1215 x 967 - 259K
    edited 2020-01-17 13:02
    Agreed, I see I had the same XINIT, WYPIN pairing.
    For reading back, it's easier to use a smartpin though.
    edited 2020-01-17 13:04
    evanh wrote: »
    There can't be a faster or a simpler way to do this. It's miraculous that the timing aligned so well. Note that it's ONE clock different, as needed, due to an extra clock delay in the streamer design.
    So, this wraps up how to do fast SPI output. Now, I've got to see about SPI input using the same ideas, but with the streamer inputting a pin. Not sure how that timing will be.
    There can't be a faster or a simpler way to do this. It's miraculous that the timing aligned so well. Note that it's ONE clock different, as needed, due to an extra clock delay in the streamer.
    Oh, you do have to be wary of those pulse/step smartpin modes. They cycle metronomically from the DIRH enable. Which means that the number of sysclocks between the enabling DIRH and the WYPIN do matter. So the XINIT-WYPIN phase timing can shift in different cercumstances.
    edited 2020-01-17 13:15
    evanh wrote: »
    Yes, I had to cover for that in the first example in the initial post, but when you set the timebase to ONE clock, you don't have that problem because its metronome ticks on every clock. The only way you could screw it up would be issuing another command before it finishes the current command, causing it to toggle some odd number of times, leaving it in the opposite state you intended. We have provision for that in the WAITXFI.
    Smartpin is easy as long as you use 32-bit words when bursting. Eight bits at a time is too sotfware burdensome.
    Streamer for reading SPI data does work but it's a lot of trial and error to align timing. Here's an example HyperRAM snippet I was using for testing various questions:
    read_block_dma
    'read data from hyperRAM
    		callpa	#readram, #send_ca		'block read command, includes padding clocks
    		wrfast	fastmask, ptra			'non-blocking
    		setbyte	dira+pinx, #0, #bytx		'tristate the HR databus for reading
    		callpa	hrbytes, #hr_clock_sp		'start SPI clock, WYPIN is returning instruction
    		mov	pa, comp
    		add	pa, #(23*dmadiv - 9)		'somewhat unnecessary crafting to help with subsequent tuning
    		waitx	pa
    		pollxfi					'clear prior event
    		xinit	rxcfg, #0			'go!
    		waitxfi					'wait for completion of DMA
    '.wloop
    '		testp	#ram_ck		wc
    '	if_nc	jmp	#.wloop
    		outh	#ram_cs
    	_ret_	rdfast	#0, #0
    Yeah, the only way to know if you are aligned on input is to maybe observe that you are getting the data you'd expect. Even if you're at sysclock/2, you may still have two apparently-good timing offsets. How to know which is the correct one? On the other hand, if you do some emperical testing, you may be able to learn the rule for a certain configuration and know for sure which offset you really want.
    edited 2020-01-17 13:47
    PS: The above example has the clock pin bit-bashed for the command, address and padding. The smartpin for the clock is engaged for the bursting stage only.
    edited 2020-01-17 14:01
    ... Even if you're at sysclock/2, you may still have two apparently-good timing offsets. How to know which is the correct one? On the other hand, if you do some emperical testing, you may be able to learn the rule for a certain configuration and know for sure which offset you really want.
    Here's the output from the above full program in action (With sysclock/2, XORO32 as procedural data source, and hrbytes set to 50_000):
    Total smartpins = 64   1111111111111111111111111111111111111111111111111111111111111111
    Rev B silicon.  Sysclock 30.0000 MHz
     Experimental HyperRAM Copying
        COMP  CYCLES   HR_DIV  HR_WRITE    HR_READ  BASEPIN
           0       0       2   a0aec350   e0aec350      16
    |                                      COUNT OF BIT ERRORS                                 |
    |        |                                 Compensations                                   |
    |   XMUL |       0       1       2       3       4       5       6       7       8       9 |
          30 |  200018  200325  199928  200015       0       0  200253  200622  199254  200581
          31 |  200090  199832  200474  199864       0       0  200159  199431  200548  200017
          32 |  200425  200043  199813  200109       0       0  199501  199690  199845  200702
          33 |  200020  199416  200487  200104       0       0  200089  200137  200576  200019
          34 |  199649  199906  200596  199515       0       0  199405  199784  200364  200210
          35 |  199931  199900  200788  200063       0       0  199641  199283  200275  199642
          36 |  200126  200549  199753  200124       0       0  200015  199748  199960  199838
          37 |  199821  199890  199799  199428       0       0  199918  199376  199827  200335
          38 |  200003  200160  199577  200162       0       0  200007  199878  199820  199814
          39 |  200386  199866  199471  200518       0       0  200229  199485  200011  199722
          40 |  200511  199398  199609  200121       0       0  200378  199860  200871  199878
          41 |  199954  200027  199957  200270       0       0  200033  199938  199374  199936
          42 |  199729  200026  199757  199645       0       0  200251  200442  200373  200024
          43 |  199480  200365  200539  200104       0       0  199270  200097  200005  200276
    edited 2020-01-17 14:11
    So, at sysclock/2, you were getting two timing possibilities to work? Could you make any determination about which was best? It looks like the majority of errors shift around left-to-right, from the clear center values.
    I'm thinking that to develop the SPI input, I'll have another cog output the same clock stream, but with output data. I'll then tune the inputting cog, which is outputting a sync'd clock stream, from the other cog's output data.
    Oops, sorry that was a DMA burst write. Hmm, I don't have any distinctive marking for which way the test is configured. Here's the DMA burst read output of the same:
    |        |                                 Compensations                                   |
          30 |  199833  199476  199892  199530       0       0  200077  199930  200097  199910
          31 |  200009  199815  199923  200484       0       0  200585  199816  200012  200372
          32 |  200495  199790  200225  200000       0       0  200354  200088  200065  199856
          33 |  199503  200532  199997  200316       0       0  199878  199544  200850  199484
          34 |  200215  200496  199747  200377       0       0  199977  199996  199886  199839
          35 |  200049  200043  199827  199966       0       0  199860  199573  200392  199495
          36 |  200175  200151  199593  199715       0       0  200056  200365  200048  199972
          37 |  199638  199903  200351  200225       0       0  200190  199570  199982  199609
          38 |  200324  200184  200235  199948       0       0  200632  200126  200050  199687
          39 |  199828  199783  200911  200504       0       0  199827  200510  200011  199989
          40 |  199753  199872  199446  199663       0       0  199963  199755  199548  199905
          41 |  199589  200101  199793  199948       0       0  200188  199853  200245  200165
          42 |  200215  200001  200074  199601       0       0  200095  200136  199981  199255
    edited 2020-01-17 14:21
    Drawing out the timing, it looks like you certainly should be getting two timing offsets that work, at sysclock/2.
    When the SPI device outputs, it updates its data output after the falling edge of the clock. I'll have to make my simulator work like this.
    I'm now thinking that flash programming should happen DURING the download, so that you don't suffer the download time, then have the programming time on top of it. The bigger the download to flash, the more it will benefit from download/programming overlap.
    Ah, yep, for SPI reading, late sampling is better because as the sysclock is raised the pin slew rate becomes a big issue. Attached is the full output using registered pins all round.
    evanh wrote: »
    Thanks, Evanh. That data is really interesting. Sheesh.... What do we do? Is it practical to try to adjust dynamically to these shifts?
    edited 2020-01-17 15:16
    Well, at 25 MHz, you're safe as. But top speed hyperRAMs will want super close dedicated board layout, the accessory boards aren't ideal.
    EDIT: The board layout has a large impact on the slew rate. That was proven with the revA Eval boards where the SD slot and EEPROM were placed on the opposite side of the board from the I/O header and prop2 pins. The max SPI clock was really bad there.
  • Out of curiosity, why are you not using the synchronous serial modes (%11100/%11101)? Are those what you were talking about using when you said in the OP that it was quite slow?
    Seairth wrote: »
    Chip is mostly looking at the convenience of the streamer directly managing the data in hubRAM. The Cog only has to deal with starting the DMA then.
    He was initially only talking about bit-bashing methods.
    Smartpins can't improve the read slew rate issue, they're not not true clock inputs.
    Not to derail the topic, but it seems reasonable that most people coming to the P2 will gravitate towards those pin modes first. I get that they are not the fastest possible solution in all cases, but the fact that Chip seemed to skip over them as a possible solution makes me concerned about their actual usefulness. I'm particularly surprised that they're not being considered for the receive mode, where it seems they should be the ideal choice here.
    edited 2020-01-17 15:48
    Ah, also, the first output above, as well as it being for hyperRAM writes, was also for a hyperRAM board with a 33 pF capacitor on the clock pin at the accessory header.
    Here's the output for the same config, write timings, but with the unmodified hyperRAM board fitted:
    |        |                                 Compensations                                   |
          30 |  199989  197827  199665  120247       0   80158  199466  199560  200175  199492
          31 |  199698  198623  200400  119343       0   79878  200656  199841  200318  200168
          32 |  200224  198486  200006  120221       0   79984  199874  199616  199543  199877
          33 |  199739  198849  200309  119626       0   80254  199900  200038  199516  200405
          34 |  200279  198725  199441  119604       0   80181  199502  200343  199657  199785
          35 |  200024  198217  200105  120474       0   79568  200594  200360  199700  200017
          36 |  199997  198479  199730  119457       0   80041  200091  200052  199947  199885
          37 |  200328  197861  199471  119789       0   80383  200050  200324  199848  199994
          38 |  200257  198228  200124  119661       0   79991  199869  200074  199925  199705
          39 |  199935  198333  199471  119520       0   79915  199892  199430  199939  199881
          40 |  199896  197917  199842  119358       0   80709  199921  200193  199817  200103
    Note, only has one good compensation column. Problem with this is when attempting to go to full DDR capabilities of the hyperRAM the column with zero errors vanishes entirely. :( Attached is the full output which demonstrates that the slew rate issue doesn't affect writes.
    Seairth wrote: »
    They do work. Rx works right up to optimal sysclock/2. Tx is fine from about sysclock/8 or slower.
    Just that the Prop2 can go so fast, and is so easy to push it there, that there is other potential issues that could never affect the Prop1. Many other micros didn't have the speed in the past either. It's all a little new in some ways.
    Seairth wrote: »
    evanh wrote:
    Smartpins can't improve the read slew rate issue, they're not true clock inputs.
    ... I'm particularly surprised that they're not being considered for the receive mode, where it seems they should be the ideal choice here.
    In theory, it should be possible to have the read shifter be clocked by the incoming SPI clock signal, rather than the internal sysclock. How easy that is to make happen correctly in an FPGA, for example, I have no idea. Doing this prevents the sample window from closing when SPI clock is faster than sysclock/2.
    Then, the other half of dealing with this is latching the shifted data into a buffer without any potential glitches between the two clocks. It shouldn't be a huge issue given the ratio between shifting and latching. Similar to solving the sysclock PLL mode change.
    The smart pin serial synchronous input mode inputs the clock and the data, so it can get to sysclock/2.
    The smart pin serial synchronous output mode, on the other hand, inputs the clock and outputs the data, so it suffers turn-around delays, making sysclock/2 impossible.
    edited 2020-01-18 16:19
    I did all kinds of testing today and came up with some simple bullet-proof ways of using the streamer to pump SPI data to and from hub memory at clk/2.
    First, you need to set up a smart pin to generate the clock signal and set the streamer rate:
    		drvl	#dpin			'make data pin output if you are outputting
    To output a value:
    		xinit	.dout,data	'2	start outputting data
    		waitxfi				'wait for streamer to finish
    .dout		long	$4081_0000 + dpin<<17 + 32	'streamer 1-bit output, 32 bits of s data
    To output from hub memory:
    		rdfast	#0,address		'set fifo for read
    		xinit	.hout,#0	'2	start outputting hub data
    .hout		long	$8081_0000 + dpin<<17 + 32	'streamer 1-bit output, 32 bits from hub
    To input to hub memory:
    		wrfast	#0,address		'set fifo for write
    		waitx	#3		'2+3	align clock transitions with input sampling
    		xinit	.hin,#0		'2	start inputting hub data
    .hin		long	$C081_0000 + dpin<<17 + 32	'streamer 1-bit input, 32 bits to hub
    That's all there is to it!
    Here is a test program that I developed this with. There are two cog programs. One outputs data and the other receives and verifies data. They time-align their clock outputs so that you can know that the receiver (clock on P18) is aligned with the transmitter (clock on P16). The transmitter outputs data on P17 and the receiver inputs from P17. It's doing 32 bits at a time. In the hub-transfer modes, you could do up to 8191 bytes at a time, unless you could use $FFFF for infinite and then do an XSTOP at the right time.
    ' Inputting and outputting SPI data at clk/2 using the streamer and transition mode
    		cpin1	= 16		'clock pin, transmitter
    		cpin2	= 18		'clock pin, receiver
    		adr_in	= $0_FFFC	'input streamer writes to long here
    		adr	= $1_0000	'64KB buffer of random data used for testing
    ' Setup
    DAT		org
    transmit	hubset	#%10_00			'use 20MHz crystal for clean scoping
    		hubset	#%10_10
    		wrfast	#0,##adr		'fill 64KB with random data
    		rep	#2,##$1_0000/4-1
    		getrnd	.data
    		wflong	.data
    		getct	.ct			'get initial time offset for testing
    		add	.ct,##1000
    		setq	.ct			'launch cog1 with time offset
    		coginit	1,#@receive
    ' Output SPI data while generating clock
    		wrpin	#%01_00101_0,#cpin1	'set cpin for transition-mode output
    		wxpin	#1,#cpin1		'timebase is 1 clock per transition
    		drvl	#cpin1			'when timebase = 1, no need to reset!
    		loc	ptra,#adr		'ptra points to 64KB random data
    .loop		rdfast	#0,ptra			'set up fifo read for streamer
    		addct1	.ct,#$1FF	'	wait for test time
    		waitct1			'go!
    		xinit	.hout,#0	'2	start outputting data from hub
    		wypin	#64,#cpin1	'2	start clock transitions
    		add	ptra,#4			'inc and wrap ptra within 64KB buffer
    		cmp	ptra,##adr+$1_0000  wz
    	if_z	loc	ptra,#adr
    		jmp 	#.loop			'loop
    .ct		res	1
    ' Input SPI data while generating clock
    		org
    receive		mov	.ct,ptra		'set initial time offset
    		wrpin	#%01_00101_0,#cpin2	'set cpin for transition-mode output
    		wxpin	#1,#cpin2		'timebase is 1 clock per transition
    		drvl	#cpin2			'when timebase = 1, no need to reset!
    .loop		wrfast	#0,##adr_in		'set up fifo write for streamer
    		addct1	.ct,#$1FF	'	wait for test time, odd number assures
    		waitct1			'go!	all hub offsets will be tried
    		nop			'2	two clocks needed to align wypin's
    		wypin	#64,#cpin2	'2	start clock transitions
    		waitx	#3		'5	align clock transitions with input sampling
    		xinit	.hin,#0		'2	start inputting data to hub
    		waitxfi				'wait for streamer to finish before reading data
    		rdlong	.data,ptra++		'get long from random data, ptra += 4
    		cmp	ptra,##adr+$1_0000  wz	'wrap ptra within 64KB buffer
    	if_z	loc	ptra,#adr
    		rdlong	.comp,##adr_in		'read long that arrived via streamer
    		cmp	.comp,.data	wz	'compare it to expected data
    		drvz	#20			'output match on p20
    		jmp	#.loop
    .hin		long	$C081_0000 + dpin<<17 + 32	'streamer mode, 1-bit input, 32 bits to hub
    .data		res	1
    .comp		res	1
    .ct		res	1
  • cgracey wrote: »
    Reading back through the docs, I now see the two-clock delay comment. I guess for slaves that can read on the rising edge, I suppose you could get down to sysclock/4 (so that output is effective written on the falling edge). But, other than that, sysclock/8 (or maybe sysclock/6 for slow-enough clock settings) is the best you can achieve?
    Seairth wrote: »
    I don't know. This gets so complex that writing code and looking at it on the scope is the best way to know the timing.
    The smart pin synchronous serial input suffers from the turn-around delays. We added another flop on each input on Rev B silicon, and I don't think I updated the docs for that mode.
    If you can control the clock, you can do much better than the smart pin synchronous input mode. If you are waiting for an external clock, you can't improve its function. There are just a lot of register stages.
  • I assume this streamer based SPI would be easy to adapt to multi-bit SPI links? (like the various 2-bit and 4-bit SPI variants found on many SPI memories)
    Maybe even 4-bit SD bus? Although the way the SD card is connected for booting complicates this.
    Yep, streamer is good at handling 1- 2- 4-bit parallel sequential bursts. And can handle them as most significant or least significant first.
