So that means all of the Spin, Spin2, C, and BASIC libraries have to live in one folder? I have a substantial number of Spin libraries that I'd like to point to. What hoping that the compiler could use multiple library paths.
At the moment I usually keep the libraries in separate folders named "spin/", "basic/", and so on, and refer to them by names like "spin/FullDuplexSerial".
The underlying compiler can handle multiple libraries (you can put the -L option on the command line multiple times, once for each library) but it isn't exposed in the GUI yet, except through the rather crude way of changing the compiler command in the Commands > Configure Commands... dialog box. It sounds like supporting multiple libraries in the GUI would be a useful addition, thanks for the suggestion.
I tried adding a second -L with the path to my Spin libraries; it did not work, Is it because your main library folder acts like an anchor for any library option?
No, the library paths should be independent (and seem to be when I try it out here). They're all relative to the current directory the program is running in. It probably wouldn't hurt to give complete paths to the library (like "C:\MyProp\Library").
Does your library path have spaces in it? Perhaps there's a bug in handling that. Could you share your command line and the errors it's showing?
That last line jumps up two directories, then down through images into raw. I don’t know if this works outside html or not, but it might.
To HTML, that's just a string like any other. The meaning of the string as a path is handled by the host OS (Unix compatible in this case) when it gets used for file access.
One second after posting I noticed that the path I added was Windows-style while the others are Linux-style. I modified my additional path and now it works.
Hmmm, that's interesting. The Windows style path should have worked. Somewhere there must be an assumption about the path separator. I'll have to open a bug for that. Thanks for checking it!
Jon: The final (non-preview) version of flexgui that I just uploaded has a new dialog box that allows you to select multiple libraries. Thanks for suggesting this, it should make things easier for many people coming from other IDEs.
Gave it a try. The program does allow me to add to the libraries list, but that list is not being saved to when that window is closed. Is there supposed to be an [OK] button to handle that? The only thing now is [Add] and [Delete].
Darn it, I was sure I had tested that, but I must have forgotten and left the window open. So for now just leave the libraries window open (it's not modal, so you can switch away from it or even minimize it), and the contents will be used automatically when you compile and run.
Ah, I see what happened, I made a last minute change that I thought would improve things and actually broke it . Sorry about that. I'll release 4.0.1 in a day or two with that fixed and any other bugs that people find.
While making that change to save the library paths, can you fix the issue for macOS where the buttons are not displayed, initially? And the width of the window limits viewing long pathnames...
To fix this, I added "tsk::" to button descriptions and a "-width 72" to the library path fields, in pathbox.tcl
The changes to the library path window work on macOS... Thanks!
But... Every other time that window is opened (selecting the menu item, "Libraries directory..."), the UI is frozen. The OK button looks selected, but I can't click on any UI items except the red close box of the window. A third selection of the menu results in a working window... And on and on...
dgately
Hmmm, interesting. Maybe on some platforms it's better to just destroy the window and re-create it rather than "withdraw" and re-show. I've updated the source code to do this, I hope it'll work better for you.
That works... Note that the "Configure Commands..." has a similar issue in that the previously clicked button is highlighted when you return to that window... Then, it 'auto-magically' clears itself, leaving the button highlighted, but functional.
dgately
I added a refernce to my time library like this:
Resulting error: This is the command output:
dgately
dgately
Thanks @dgately
dgately
There's a new binary release (4.0.1) containing these GUI fixes and some minor C bugfixes to fastspin, as well as the latest loadp2. As usual, it may be obtained either from my Patreon page (https://patreon.com/totalspectrum) or from Github (https://github.com/totalspectrum/flexgui/releases/latest).
