Shop Learn
Tachyon 5.6 - Easynet: Wrong output fo ifconfig — Parallax Forums
Prop1TachProp1Tach Posts: 7
edited 2019-09-19 10:51 in Propeller 1
Hi,
We have build EASYNET in the following way:
1 - Load EEPROM with kernel (TACHYON5r6.SPIN with PropellerTool (6MHZ))
2 - Paste EXTEND.FTH
( SYSTEM REBOOTS WHEN DONE )
3 - FORGET TOOLS (HIT THE ENTER TWICE)
4 - Paste EASYFILE.FTH (&27.24.26.25 SDPINS ( SD8 ))
5 - RECLAIM
6 - Paste EASYNET.FTH (&17.20.19.18 WIZPINS ( P8 ))
7 - Paste FTP.FTH
8 - Paste HTTP.FTH
Afterwards we changed gateway and sip as follows:
&192.168.040.006 GATEWAY
&192.168.040.201 SIP
Then we get the following output from ifconfig:
ifconfig -->
NETWORK STATUS:
LINK *UP*
HARDWARE: WIZnet W5500 V4
SRC IP    &192.168.40.201
MASK      &255.255.255.0
GATEWAY   &192.168.40.6
MAC       02.FF.C5.24.6C.54.
SKT HH:MM:SS MODE  PORT   DEST   TXRD TXWR RXRD RXWR RXSZ  IR STATUS            IP ADDR
#1  02:04:02  TCP    21      0  0000.0000.0000.0000.0000.   00 14 14             &0.0.0.0
#3  02:04:02  TCP 10001      0  0000.0000.0000.0000.0000.   00 14 14             &0.0.0.0
#4  02:04:02  TCP    80  60246  0000.0000.0000.0000.0000.   00 14 14             &192.168.40.171
 ok
The position of the run time is wrong. It starts one position to late.
There are no values for TXRD, TXWR, RXRD, RXSZ and IR.
The status is '14 14', but it should be something like '14 LISTEN'.
  • Peter JakackiPeter Jakacki Posts: 10,035
    edited 2019-09-19 00:35
    @Prop1Tach - It helps if you can enclose your terminal output in CODE tags using C in your forum edit menu otherwise the forum will remove spaces and lose the formatting.
    The reason that the status was not displaying LISTEN is simply because these more handy but verbose messages were removed for taking up code space, however I have restored them for diagnostic purposes. The second 14 in your output was simply printing the value rather than the label and IP.
    Maybe not related to your testing but I had performed a RECLAIM on HTTP and FTP modules and inadvertently removed the necessary ?FTP and ?HTTP headers since they were marked private and were reclaimed. I fixed up a couple of other minor things and posted a new binary just for the IoT5500+P8 module. You can download the latest version from the Dropbox V5 binaries folder or just download the attached version I just tested.
    The RD/WR values are simply there for diagnostics and due to W5500 quirks and IIRC you can't actually read these registers unless the socket connection is established. Tachyon maintains shadow registers which are updated when it writes to the physical register.
    From my source notes:
    Since the W5500??? read and write index registers are unreadable until a connection has been established
    or cannot be written incrementally until a send then these are buffered for when they become readable
    Here's an FTP output:
    220 WELCOME TO THE TACHYON WIZNET FTP SESSION!
    213 133590
    550 Modification time not available
    #2   00:01:34 TCP  44464 32840 AB02.AB02.0000.0000.0000. 13 00 closed
    226 File successfully transferred
    #1   00:01:34 TCP     21 57124 4EFE.4EFE.007B.007C.0001. 16 00 closed
    #1   00:01:34 TCP     21 57124 0000.0000.0000.0000.0000. 00 14 LISTEN
    and the ifconfig:
    ... ifconfig -->
    NETWORK STATUS:
    LINK *UP*
    SRC IP    &192.168.0.99
    MASK      &255.255.255.0
    GATEWAY   &192.168.0.1
    MAC       02.FF.59.59.D2.D6.
    #1   00:06:13 TCP     21 57276 0000.0000.0000.0000.0000. 00 14 LISTEN
    #2   00:06:13 TCP  45328 34330 AAF4.AAF4.0000.0000.0000. 03 00 closed
    #3   00:06:13 TCP  10001 55296 0000.0000.0000.0000.0000. 00 14 LISTEN
    #4   00:06:13 TCP     80 44676 0000.0000.0000.0000.0000. 00 14 LISTEN
     ok
    and a diagnostic look at the FTP socket registers:
    ...  FTP .SOCKET -->
    #1   00:07:31 TCP     21 57276 0000.0000.0000.0000.0000. 00 14 LISTEN        ok
    ...  0 $40 WIZ @SKT DUMP -->
    0000.0000:   01 00 00 14  00 15 18 03  73 40 CE 20  C0 A8 00 65    ........s@. ...e
    0000.0010:   DF BC 05 B4  00 00 80 00  00 00 00 00  00 00 02 02    ................
    0000.0020:   08 00 00 00  00 00 00 00  00 00 00 00  FF 40 00 00    .............@..
    0000.0030:   01 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................ ok
    ...  0 $40 WIZ @RX DUMP -->
    0000.0000:   55 53 45 52  20 61 6E 6F  6E 79 6D 6F  75 73 0D 0A    USER anonymous..
    0000.0010:   50 41 53 53  20 6D 6F 7A  69 6C 6C 61  40 65 78 61    PASS mozilla@exa
    0000.0020:   6D 70 6C 65  2E 63 6F 6D  0D 0A 53 59  53 54 0D 0A    mple.com..SYST..
    0000.0030:   46 45 41 54  0D 0A 50 57  44 0D 0A 54  59 50 45 20    FEAT..PWD..TYPE  ok
    ...  0 $40 WIZ @TX DUMP -->
    0000.0000:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0010:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0020:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
    0000.0030:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................ ok
    ...  0 $40 WIZ @COMMON DUMP -->
    0000.0000:   00 C0 A8 00  01 FF FF FF  00 02 FF 59  59 D2 D6 C0    ...........YY...
    0000.0010:   A8 00 63 00  00 00 00 04  00 13 88 10  28 00 00 00    ..c.........(...
    0000.0020:   00 00 00 00  00 00 FF FF  00 00 00 00  00 00 BD 00    ................
    0000.0030:   00 00 00 00  00 00 00 78  25 04 00 00  00 00 00 00    .......x%....... ok
  • LtechLtech Posts: 269
    edited 2019-09-19 06:56
    I get error on BST
    "I get invalid propeller image! this is very bad "
    I try the one on dropbox and on you comment.
    Building manual works
  • Hi Peter,
    We have meanwhile changed my comment from yesterday.
    Now it is better readable.
    I have downloaded the binary of your comment from today.
    But I get
    Checksum Error!
    Byte 5 (Checksum) is incorrect.
    when I try to open EASYNET-IOT.binary with the Propeller Tool.
    When I download EXTEND.FTH, EASYFILE.FTH, EASYNET.FTH, FTP.FTH and HTTP.FTH
    and paste them manually, building works also here.
    Changing gateway and sip with
    I can use telnet in a teraterm window with IP 192.168.040.201 and port 10001.
    In that window I can use forth for instance
    1 2 + .
    But after a while the teraterm window disappears.
    I can also use http in a firefox window to read the contents of a file on the sd card.
    With
    192.168.40.201/EASYFILE.FTH
    I get the contents of the that file in firefox.
    Although the whole contents is already there,
    it is still loading for the file until a timeout is reached.
    During that time I can read the next file with
    192.168.40.201/EASYNET.FTH
    I get the contents of that file,
    but every time it is still loading although the contents is already there.
  • I have a new binary which I have confirmed loads properly. That binary checksum is more of a nuisance but my hex utility should have set it correctly nonetheless.
    If you use Filezilla for FTP be sure to use site manager to setup the server as plain FTP as quickconnect does not do this.
    For simple FTP try typing ftp://<your ip> into your browser and it should list the files and from there you can download any files.
  • Prop1TachProp1Tach Posts: 7
    edited 2019-09-20 11:42
    The download of the binary works.
    I can also download files from the SD card with simple FTP and Filezilla.
    But when I upload a small file (00189513.HTM) with Filezilla,
    the file has in the end a size of 67108864 and is not readable any more on the SD card.
    It may have to do with the same problem I mentioned yesterday,
    that I can use http in a firefox window to read the contents of a file on the sd card.
    With
    The 3rd problem, which I also mentioned yesterday, is,
    why a telnet session in teraterm (with IP 192.168.040.201 and port 10001) disappears after a while.
    Does anyone know, what has to be done to solve one or more of those porblems?
  • Ok, I noticed the same thing so I will track this down. I popped my trashed card into my P2 board where I have format utilities and simply told it to reformat the mbr and nothing else. That did the trick. I may add something like that to the P1.
    I will check what this timeout is on Firefox. The FTP side looks fine and I can click on a file in the directory listing and it loads up fine.
    The telnet session has a timer on it but we can change that easily. You can even just type in "0 contmr TIMEOUT" to prevent this background from timing out and executing a disconnection request.
  • ErNaErNa Posts: 1,489
    The symptoms point to HTTP is not detecting EOF correctly. If the URI addesses an HTML-File, the webserver responses but the browser screen remains empty while loading continues. Forcing the browser to stop loading, the website is displayed correctly.
    On the other hand, Filezilla downloads the file and closes correctly.
    Uploading a File using Filezilla ends quickly and normally, but shows a 64MB file size. This file can not be accessed on a Windows computer.
  • ErNa wrote: »
    The FTP STOR command calls FMAKE$, but I see for some reason I decided to create a 64MB file by default. Not a big deal when you have Gigabytes to work with. Originally I made it 1MB but if you start storing a larger file it then has to allocate clusters which I only like to do with the newly created file to keep all the files unfragmented. So perhaps I may change that default to a user specified default otherwise 1MB, but I will need to check why it zapped the MBR. In fact, on TAQOZ the filesystem can't write to the MBR unless it has special permissions.
    --- Open or create a file
    pub FMAKE$ ( name -- flg )
    	--- create default 1MB file if it doesn't exist
    	FOPEN$ NOT IF 64 MB FILE$ FCREATE$ FOPEN$ THEN
    edited 2019-09-23 12:44
    Using
    "0 contmr TIMEOUT"
    the telnet session is not timed out any more.
    Today I have downloaded the changed sources from DropBox
    and have tested the upload of a file of size 5 KB with filezilla onto the SD card again to find out,
    if the situation has changed meanwhile.
    Now the uploaded file has a size of 1048576 instead of 67108864 last week.
    This is the output of the serial session in a tera term window:
    550 File not available
    #2   00:00:00 TCP  46732 62120 0C64.0C64.0000.05B4.05B4. 07 18 FIN WAIT        &192.168.40.171
    #1   00:00:00 TCP     21 62119 2197.2197.0053.005C.0009. 16 00 closed
    If I try again for some times, then I get the following output:
    150 Accepted data connection for PRNT2255.HTM
      Propeller .:.:--TACHYON--:.:. Forth V5r6 NEON 560190920.1700
    CODE:$5342 = 20802 bytes
    NAME:$550E = 7922 bytes
    DATA:$7950 = 1088 bytes
    FREE:      = 460 bytes
     Data Stack (0)
    CARD: SU08G SD03.80 #77E9.E903 2010/1 !C0FF.80AF 1,611us
    FAT: #5C98.7460 MSWIN4.1 IOT5500     FAT32   7,944,011,776 bytes (32kB clusters)
    *** Tachyon Forth EASYNET Network Servers and EASYFILE File Server ***
    CARD: SU08G SD03.80 #77E9.E903 2010/1 !C0FF.80AF 1,602us
    IOT5500
    EXTEND  .FTH   EASYFILE.FTH   EASYNET .FTH   00189169.HTM   00189513.HTM
    PRNT0105.HTM   PRNT0155.HTM   PRNT1155.HTM   PRNT1255.HTM   PRNT2255.HTM
    The original file has a size of 5109.
    The file is still not readable on a Windows system.
    An od -b on a linux system shows:
    $ od -b PRNT1155.HTM
    0000000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000
    1447000 370 377 377 017 377 377 377 377 377 377 377 017 377 377 377 017
    1447020 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000
    4000000
    It seems, that the contents of the original file is not uploaded to the destination file on the SD card.
  • @Prop1Tach - I am checking this the STOR command and fixing up any little bugs I find. However EASYFILE never creates a zero sized file but instead preallocates more than enough clusters so that the file can be any size up to the amount preallocate. If it preallocates 1MB then the file can be any size from 0 to 1 MB, all unfragmented linear addressing. I just need to make sure that STOR sets the files size when it is done.
    BTW, Preallocating 1MB is not a waste, it is just practical. Even if we were to create 1,000 files then that would still only take up 1GB on the card and the smallest card I can buy is 16GB. However I will look at some other ways of doing this by creating new files at the end of the used memory and letting them grow while STOR is saving to it.
