Pseudo Random Bit Sequence (PRBS) signal generation using simple IDE. — Parallax Forums
I am using Arlo robot and I want to drive robot by giving PRBS signal to it.
so any idea about How to generate PRBS signal using simple IDE.
  • AwesomeCronkAwesomeCronk Posts: 1,055
    edited 2019-08-16 12:09
    Simple ide means you are using the propeller. Correct?
  • Simple ide means you are using the propeller. Correct?
    yes.
    edited 2019-09-21 17:19
    Your duplicate posts have been deleted per forum rules.
    No Cross-Posting:
    Cross-posting is: 1) submitting a post to one forum or thread, and then submitting a second linking to the original post (without changing content or intent), or 2) creating an identical post in more than one forum or thread. When the same content is found in more than one post, even under different subject lines, the forum moderator will remove one (or more) of the redundant posts and the posting account may be subject to moderation.
    edited 2019-09-25 22:49
    As I said in the PM, do you want to print random numbers to the terminal, or do you want to toggle a pin at random?
    Also, let's converse on this thread, not the PM.
  • vaibhav wrote: »
    SimpleIDE automagically means C?
  • yes in C
