Shop Learn
HDMI added to Prop2 - Page 21 — Parallax Forums
HDMI added to Prop2
1151617181921»
  • I've put this reply in the original HDMI thread to help resurrect it.
    Thanks!
    It may only want to support HDMI modes and not DVI modes. I have an old TV that has separate HDMI and DVI modes. Sometimes it only works on one of the settings. It will be a while before I can test that unit with the P2.
    You could try changing the clock phase. It should be "correct" already. 10 sysclocks is 1 output cycle. The code from VonSzarvas generates what I consider the correct phase. We might get it if we generate a 720x480 signal. An easy thing to try would be to use 270MHz sysclock. Also, are you in an NTSC or PAL region?
    Chip wrote the original code.
    A two-cog 640x480x8pp soft HDMI display with palette of 256 out of a possible 4096 colours was worked out last November, however it has not been tested yet. Colour levels are equally spaced but TMDS data are mostly not balanced. 720x480x8pp and sprites should be possible, too. It's questionable how much time should be spent on this, but it would good to get something working now that people have HDMI boards.
  • Thanks, TonyB. Lots of good content in the first half of this thread. I started the other thread because people shouldn't have to search a 20 page thread to find code for their HDMI board. I re-read this thread and found the code on page 10.
    Since the new silicon will generate proper signals, I though that using the 52 balanced codewords would be an acceptable trade-off for now. Generating a non-balanced signal may be an acceptable temporary trade-off as well.
    Work on HDMI audio wouldn't be wasted. What we write now should work on production silicon with minor changes.
  • If anyone wants to play with 720p24, here you go!
    The rose.gray file used is available here: forums.parallax.com/discussion/comment/1463361/#Comment_1463361
    ' HDMI framebuffer demo for P2-ES chips
    ' Framebuffer is 640x480 x 8 bit grayscale
    ' Output as 1280x720 24fps, you will see 6 copies of the image
    ' adds video preamble and null data island so it is detected as HDMI
    ' It uses only the 52 TMDS words that are naturally balanced.
    ' Pixel values with non-balanced words are assigned to their nearest balanced
    ' neighbor.
    ' Clock is generated by the smart pins
    ' http://forums.parallax.com/discussion/comment/1463078/#Comment_1463078
    ' HDMI display test for early P2 silicon with 20MHz crystal and
    ' P[7:0] connected to HDMI {R+, R-, G+, G-, B+, B-, CLK+, CLK-}
    ' The next version of silicon will have TMDS hardware to compose LVDS stream on the fly.
    con
    	xtal = 20_000_000
    	dv = 20
    	mlt = 297
    	pdv = 1
    	clk = 1 << 24 | (dv-1) << 18 | (mlt-1) << 8 | (((pdv>>1)+15) & $F) << 4
    	sys_clk = xtal / dv * mlt / pdv
    dat     org
    	jmp   #tablebypass
    tmdstable         ' This table uses only balanced TMDS words, the 8 bit input is quantized to the nearest value
         long         $1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0
     '   long    $1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0,$1f0 actual first line
         long    $1f0,$10f,$10f,$10f,$10f,$10f,$10f,$10f,$10f,$10f,$11e,$11e,$11e,$11e,$11e,$11e  ' there are  52
         long    $11e,$11e,$11e,$1e1,$1e1,$1e2,$1e2,$11d,$11d,$11d,$1e4,$1e4,$1e4,$11b,$11b,$11b  ' unique values
         long    $11b,$11b,$247,$247,$247,$247,$247,$2b8,$1e8,$117,$117,$117,$117,$117,$117,$13c  ' in this table
         long    $13c,$13c,$13c,$13c,$13c,$1c3,$1c3,$1c3,$1c6,$1c6,$1c6,$139,$139,$139,$139,$139
         long    $1cc,$1cc,$1cc,$1cc,$1cc,$133,$133,$133,$263,$263,$263,$29c,$29c,$29c,$29c,$29c
         long    $29c,$29c,$1d8,$1d8,$1d8,$1d8,$1d8,$1d8,$1d8,$127,$127,$271,$271,$28e,$28e,$28e
         long    $28e,$28e,$287,$287,$287,$287,$287,$278,$278,$278,$278,$278,$278,$278,$278,$278
         long    $178,$178,$178,$178,$178,$178,$178,$178,$178,$187,$187,$187,$187,$187,$18e,$18e
         long    $18e,$18e,$18e,$171,$171,$227,$227,$2d8,$2d8,$2d8,$2d8,$2d8,$2d8,$2d8,$19c,$19c
         long    $19c,$19c,$19c,$19c,$19c,$163,$163,$163,$233,$233,$233,$2cc,$2cc,$2cc,$2cc,$2cc
         long    $239,$239,$239,$239,$239,$2c6,$2c6,$2c6,$2c3,$2c3,$2c3,$23c,$23c,$23c,$23c,$23c
         long    $23c,$217,$217,$217,$217,$217,$217,$2e8,$1b8,$147,$147,$147,$147,$147,$21b,$21b
         long    $21b,$21b,$21b,$2e4,$2e4,$2e4,$21d,$21d,$21d,$2e2,$2e2,$2e1,$2e1,$21e,$21e,$21e
         long    $21e,$21e,$21e,$21e,$21e,$21e,$20f,$20f,$20f,$20f,$20f,$20f,$20f,$20f,$20f,$2f0
         long    $2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0,$2f0
    tablebypass
    	mov    0,#$1f0   ' patch table
    	hubset	##clk | %0000_01_00	'enable crystal+PLL, stay in 20MHz+ mode
    	waitx	##20_000_000/100	'wait ~10ms for crystal+PLL to stabilize
    	hubset	##clk | %0000_01_11	'now switch to PLL running
            mov     active_adj,active_pix   ' ##640-12-32 'active_pix
            sub     active_adj,#12+32
            mov     backporch_adj,backporch
            sub     backporch_adj,#10
            setxfrq ##$80000000     'set streamer to output on every clock
            mov dira,#$Fc       'P[7:0] = {R+, R-, G+, G-, B+, B-, CLK+, CLK-}
    			    'wait to set 0,1 high, they active the smart pins
    ' Output screen data over and over
    'grayfield
    	wrlut   #%0101_0100,#0  ' 2+,2-,1+,1-,0+,0-,C+,C-
    	wrlut   #%1010_1000,#1
    	wrlut   #%0101_0100,#%10_0000  '  2 bit immediate mode LUT for sync words
    	wrlut   #%0101_1000,#%10_0001  '  bit 0 goes to channel 0
    	wrlut   #%1010_0100,#%10_0010  '  bit 1 goes to channels 1,2
    	wrlut   #%1010_1000,#%10_0011  '  clock bits stay low, they come from smart pins
    	wrlut   #%0101_0100,#%100_0000  '  2 bit immediate mode LUT for sync words
    	wrlut   #%1001_1000,#%100_0001  '  bit 0 goes to channels 0,2
    	wrlut   #%0110_0100,#%100_0010  '  bit 1 goes to channel 1
    	wrlut   #%1010_1000,#%100_0011  '  clock bits stay low, they come from smart pins
    	wrlut   #%0101_0100,#%110_0000  '  4 bit immediate mode LUT for data island
    	wrlut   #%0101_1000,#%110_0001  '  4 bit immediate mode LUT for data island
    	wrlut   #%0110_0100,#%110_0010  '  4 bit immediate mode LUT for data island
    	wrlut   #%0110_1000,#%110_0011  '  4 bit immediate mode LUT for data island
    	wrlut   #%1001_0100,#%110_0100  '  4 bit immediate mode LUT for data island
    	wrlut   #%1001_1000,#%110_0101  '  4 bit immediate mode LUT for data island
    	wrlut   #%1010_0100,#%110_0110  '  4 bit immediate mode LUT for data island
    	wrlut   #%1010_1000,#%110_0111  '  4 bit immediate mode LUT for data island
            mov     x,nco_mode      'use 2 smart pins to generate the clock signal
            wrpin   x,#0
            wrpin   x,#1
            mov     x,##$5          'base period is 5 clocks
            wxpin   x,#0
            wxpin   x,#1
            mov     x,##$8000_0000  'Toggle every 1 base period
            wypin   x,#0
            wypin   x,#1
    	waitx   #(15-4)
            rdfast  frame_cnt,##framebuffer   'ready to loop-read framebuffer
    	rfbyte  thispix         ' start reading pixel data
            sets    .vi,thispix     '
            dirh    #0	        ' Start the clock generation
    	waitx   #(1)		'
            dirh    #1	        ' These 3 instructions have critical timing
    	waitx   #(10-8)	        ' This delay adjust the clock phase relative to the data
                                    ' Curiously, it may not matter
    .field  mov x,active_lines          'ready for 480 visible lines
    .vis
            rep     #1,#8
    	xcont   pre_mod,imvidpre
    	xcont   pre_mod,imvidguard
    	'rep     #1,#10
    	'xcont   sync_mod,imsync0
            rep     #3,active_pix
    .vi	xcont   pix_mod,0
    	rfbyte  thispix         ' Note: the first pixel of the frame was read at the end of
            sets    .vi,thispix     ' the last frame. Might be an issue for video.
    	rep     #1,frontporch
    	rep     #1,hsyncwidth
    	xcont   sync_mod,imsync1
    	rep     #1,backporch_adj  '-10
    	drvnot  #16
            djnz    x,#.vis
    	rep     #1,#10
            mov x,pre_lines           'ready for 10 invisible lines
    .pre
            rep     #1,active_pix
    	rep     #1,frontporch
    	rep     #1,hsyncwidth
    	rep     #1,backporch
            djnz    x,#.pre
            mov x,vsync_lines            'ready for 6 sync lines
    .sync
            rep     #1,#8
    	xcont   sync_mod,imdatpre
    	xcont   sync_mod,imdatguard   ' data guard band
    	xcont   raw_mod,di_head       ' null data packet
    	xcont   raw_mod,di_head+1
    	xcont   raw_mod,di_head+2
    	xcont   raw_mod,di_head+3
    	xcont   raw_mod,di_head+4
            rep     #5,#7
    	xcont   raw_mod,di_tail
    	xcont   raw_mod,di_tail+1
    	xcont   raw_mod,di_tail+2
    	xcont   raw_mod,di_tail+3
    	xcont   raw_mod,di_tail+4
            rep     #1,active_adj ' ##640-12-32 'active_pix
    	xcont   sync_mod,imsync2
    	rep     #1,#frontporch
    	rep     #1,hsyncwidth
    	xcont   sync_mod,imsync3
    	rep     #1,backporch
            djnz    x,#.sync
            mov x,post_lines            'ready for 31 invisible lines
    .post
            rep     #1,active_pix
    	rep     #1,frontporch
    	rep     #1,hsyncwidth
    	rep     #1,backporch
            djnz    x,#.post
            rep     #1,active_pix
    	rep     #1,frontporch
    	rep     #1,hsyncwidth
    	rep     #1,backporch_adj ' -10
            jmp #.field
    ' Data
    sync0       long    %11010_10100     '
    sync1       long    %00101_01011     '    hsync
    sync2       long    %01010_10100     'vsync
    sync3       long    %10101_01011     'vsync + hsync
    imsync0     long    %11_11_00_11_00__11_00_11_00_00   'even bits=sync0, odd=sync0
    imsync1     long    %10_10_01_10_01__10_01_10_01_01   'even bits=sync1, odd=sync0
    imsync2     long    %10_11_00_11_00__11_00_11_00_00   'even bits=sync2, odd=sync0
    imsync3     long    %11_10_01_10_01__10_01_10_01_01   'even bits=sync3, odd=sync0
    imvidpre    long    %01_01_10_01_10__01_10_01_10_10   'even bits=sync0, odd=sync1
    imvidguard  long    %01_10_01_01_10__10_01_01_10_10
    imdatpre    long    %00_01_10_01_10__01_10_01_10_10   'even=ch0 odd=ch1,2
    imdatguard  long    %00_11_00_01_11__10_00_00_11_11   'even=ch0 odd=ch1,2
    'line_mod    long    $1080<<16 + linebytes   'RFBYTE streamer mode
    frame_cnt    long    640*480 / 64
    'line_vis    long    base + linebytes*0  'visible line address
    'line_inv    long    base + linebytes*1  'invisible line address
    'line_syn    long    base + linebytes*2  'sync line address
    'line_tail   long    base + linebytes*0 +512*10 'visible line address
    'tail_mod    long    $1080<<16 + (linebytes-(512*10))   'RFBYTE streamer mode
    'tail_cnt    long    (linebytes-(512*10)) / 64
    nco_mode    long    %0000_100000000_01_00110_0
    pix_mod     long    $8<<28 + 0<<16 + 1<<23 + 10   ' 1 bit immediate LUT
    sync_mod    long    $9<<28 + 1<<16 + 1<<23 + 10   ' 2 bit immediate LUT
    pre_mod     long    $9<<28 + 2<<16 + 1<<23 + 10   ' 2 bit immediate LUT
    raw_mod     long    $a<<28 + 3<<16 + 1<<23 + 8    ' 4 bit immediate LUT
    frontporch  long    100
    hsyncwidth  long    40
    backporch   long    220   ' must be > 10
    active_pix  long    1280  ' must be > 44
    active_lines long   720
    pre_lines   long     5
    vsync_lines long     5
    post_lines  long    19   ' +1 to this value
    thispix     long    0
    active_adj  long    0
    backporch_adj   long   0
    ' http://hamsterworks.co.nz/mediawiki/index.php/Minimal_HDMI
               'full data island          160 bytes = 40 longs = 32 pixels
               'minimum transmission unit  40 bytes =  5 longs =  4 pixels
               'channel  210  210  210  210  210  210  210  210  210  210
    di_head     byte    %000_0000,%110_0111,%001_0110,%111_0001,%111_0000 ' play once
                byte    %000_0000,%111_0111,%000_0111,%111_0000,%110_0001
    di_tail     byte    %000_0000,%111_0111,%000_0111,%111_0000,%110_0001 ' play x7
    'color       res 1
    'bal     res 1
    'bal_m       res 1
    'bal_sign    res 1
    'bal_r       res 1
    'bal_g       res 1
    'bal_b       res 1
    'color_r     res 1
    'color_g     res 1
    'color_b     res 1
    'rgb     res 1
    x       res 1
    y       res 1
    z       res 1
    t       res 1
    	fit
    DAT orgh
    framebuffer            file "rose.gray"
    A computer monitor with HDMI input did not accept this signal. My TV handles it but seems somewhat buggy. It sometime flashes between the P2 signal and my computer signal that is probably still in the screens memory somewhere. It happens at startup and seems to settle down after a few minutes.
