New P2 Silicon - Page 2 — Parallax Forums
New P2 Silicon
2456732
  • RaymanRayman Posts: 15,267
    I wonder if modern monitors would let one reduce the blanking times to near zero...
    If so, could do SVGA at ~330 MHz...
    Wuerfel_21 wrote: »
    Well, few people really, which is why you can get 4:3 and 5:4 monitors of average quality fairly cheap. Altough those often don't have DVI / HDMI anyways.
    Would 1080i work though?
    The P2 can signal 1080p over 3 pins in analog. Pixel rate is 148.5MHz.
    Yes, search the forums for vga 1920x1080. Works nicely even with text 240x125 on a 24” vga monitor :)
  • jmgjmg Posts: 15,193
    Mickster wrote: »
    Aside from all the fluff, is the quad decode working....and what are the spec's?
    Good question, I've not seen confirmed word on if the bug-fixes, fixed... Given the nature of everything else, the inference is yes..
  • That's good news Chip!
    Since the new revision uses half the power and gets barely warm at 390MHz, I guess that it is possible to raise the nominal frequency from 180MHz to 240MHz, with margin for overclocking?
    I mean, 240MHz would be an important milestone, and higher specs would mean higher sales, possibly. But I'm just speculating. I'm eager to see the new specs.
    By the way, when will the new boards be available for sale?
    Kind regards, Samuel Lourenço
    samuell wrote: »
    Yes, we've got huge temperature margins in the design. We designed for -40C to 85C ambient temperature. For the hot end, we figured on a junction temperature of 150C, allowing for lots of self-heating. 150C is 65C over 85C. With this reduced power dissipation, we don't need 65C of margin, but since it's there, it means we could run way faster than 175MHz or boost the 85C figure up a ways. We will eventually work with ON Semi to determine a 2-D graph of ambient temperature vs. max frequency.
    When the new boards will be available depends on when we get real packaged chips, not these glob-tops. That is looking like a few weeks, at least, maybe a month.
    All day I worked on a reduced-power I/O test program for ON Semi's wafer prober, so we don't burn up the probe cards again. I've got the program's 1.8V core current down to 52mA, from the original 440mA. It should be way safer to use on the prober now.
    Imagine how expensive and delicate this probe card must be. Wouldn't want to damage this thing.
    664 x 497 - 100K
    Before ending for the day, I got VGA working.
    This gave an opportunity to push the PLL to extremes to see if it jitters badly.
    I set the crystal divider to 64, so that 20MHz becomes 312.5KHz. Then, I multiply it in the VCO by 256 to get 80MHz. That VCO frequency is then used directly for the system clock... No pixel shimmying, at all. I tried a range of PLL configurations and I can't get any visible shimmying. So, the PLL seems to be in order now.
    Here's the code:
    '*  VGA 640 x 480 x 16bpp 5:6:5 RGB  *
    CON
      intensity	= 80	'0..128
      fclk		= 80_000_000.0
      fpix		= 25_000_000.0
      fset		= (fpix / fclk * 2.0) * float($4000_0000)
      vsync		=	4	'vsync pin (all FPGA boards now)
    DAT		org
    ' Setup
    		hubset	clkinit1		'set clock to 80MHz
    		waitx	clkwait
    		hubset	clkinit2
    		rdfast	##640*350*2/64,##$1000	'set rdfast to wrap on bitmap
    		setxfrq ##round(fset)		'set transfer frequency to 25MHz
    		setcy	##intensity << 24	'r	set colorspace for rgb
    		setci	##intensity << 16	'g
    		setcq	##intensity << 08	'b
    		setcmod	#%01_0_000_0		'enable colorspace conversion (may be commented out)
    		wrpin	dacmode_hsy,#0<<6 + 0	'enable dac mode in pin 0 for hsync
    		wrpin	dacmode_rgb,#2<<6 + 1	'enable dac modes in pins 1..3 for rgb
    		drvl	#3<<6 + 0		'enable dac outputs
    ' Field loop
    field		mov	x,#90			'top blanks
    		call	#blank
    		mov     x,#350			'set visible lines
    line		call	#hsync			'do horizontal sync
    		xcont	m_rf,#1			'visible line
    		djnz    x,#line           	'another line?
    		mov	x,#83			'bottom blanks
    		call	#blank
    		drvnot	#vsync			'sync on
    		mov	x,#2			'sync blanks
    		call	#blank
    		drvnot	#vsync			'sync off
                    jmp     #field                  'loop
    ' Subroutines
    blank		call	#hsync			'blank lines
    		xcont	m_vi,#0
    	_ret_	djnz	x,#blank
    hsync		xcont	m_bs,#0			'horizontal sync
    		xzero	m_sn,#1
    	_ret_	xcont	m_bv,#0
    ' Initialized data
    clkinit1	long	%1_111111_0011111111_1111_10_00		'20MHz / 1 * 4 * 1 = 80MHz
    clkinit2	long	%1_111111_0011111111_1111_10_11
    clkwait		long	20_000_000 / 200
    dacmode_hsy	long	%0000_0000_000_1011000000000_01_00000_0	'123-ohm 3.3V
    dacmode_rgb	long	%0000_0000_000_1011100000000_01_00000_0	'75-ohm 2.0V
    m_bs		long	$7F010000+16		'before sync
    m_sn		long	$7F010000+96		'sync
    m_bv		long	$7F010000+48		'before visible
    m_vi		long	$7F010000+640		'visible
    m_rf		long	$BF050000+640		'visible rfword rgb16 (5:6:5)
    x		res	1
    y		res	1
    ' Bitmap
    		orgh	$1000 - 70		'justify pixels at $1000
    		file	"birds_16bpp.bmp"	'rayman's picture (640 x 350)
    And here's the output:
    1536 x 864 - 518K
    edited 2019-08-02 10:28
    I just did another experiment where I divided the 20MHz crystal by 64 and then multiplied it by 80 to get 25MHz. Still, no pixel shimmying. This is significant because at lower VCO frequencies, things are less stable. I can't see any instability, which is surprising to me.
    So, the chip is running at 25MHz, outputting a VGA display with that same pixel rate, and drawing only 33mA at 1.8V.
    Another problem to be ticked off :smiley:
  • Fabulous! :cool:
    edited 2019-08-02 10:58
    The colorspace converter's IQ modulator is working now. Here is baseband NTSC being output over a single pin in DAC mode:
    Here's the code:
    '*  NTSC 256 x 192 x 8bpp-lut  *
    CON
      f_color	= 3_579_545.0		'colorburst frequency
      f_scanline	= f_color / 227.5	'scanline frequency
      f_pixel	= f_scanline * 400.0	'pixel frequency for 400 pixels per scanline
      f_clock	= 80_000_000.0		'clock frequency
      f_xfr		= f_pixel / f_clock * float($7FFF_FFFF)
      f_csc		= f_color / f_clock * float($7FFF_FFFF) * 2.0
      s		= 90			'scale DAC output (s = 0..128)
      r		= s * 1000 / 1646	'precompensate for modulator expansion of 1.646
      mody		= ((+38*s/128) & $FF) << 24 + ((+75*s/128) & $FF) << 16 + ((+15*s/128) & $FF) << 8 + (110*s/128 & $FF)
      modi		= ((+76*r/128) & $FF) << 24 + ((-35*r/128) & $FF) << 16 + ((-41*r/128) & $FF) << 8 + (100*s/128 & $FF)
      modq		= ((+27*r/128) & $FF) << 24 + ((-67*r/128) & $FF) << 16 + ((+40*r/128) & $FF) << 8 + 128
      video_pin	= 0
    DAT		org
    ' Setup
    		waitx	clkwait
    		hubset	clkinit2
    		rdfast	#0,##$1000-$400		'load .bmp palette into lut
    		mov	x,#0
    		rep	@.end,#$100
    		rflong	y
    		shl	y,#8
    		wrlut	y,x
    		add	x,#1
    .end
    		rdfast	##256*192/64,##$1000	'set rdfast to wrap on bitmap
    		setxfrq ##round(f_xfr)		'set transfer frequency
    		setcfrq	##round(f_csc)		'set colorspace converter frequency
    		setcy	##mody			'set colorspace converter coefficients
    		setci	##modi
    		setcq	##modq
    		setcmod	#%11_1_0000		'set colorspace converter to YIQ mode (composite)
    		wrpin	dacmode,#video_pin	'enable dac mode in pin
    		drvl	#video_pin		'enable dac output
    ' Field loop
    field           mov	x,#35			'top blanks
    		call	#blank
                    mov     x,#192			'set visible lines
    		xcont	m_rf,#0			'visible line
    		xcont	m_av,#1			'after visible spacer
                    mov     x,#27			'bottom blanks
    		call	#blank
    		mov	x,#6			'high vertical syncs
    .vlow		xcont	m_hl,#2
    		xcont	m_hh,#1
    		djnz	x,#.vlow
    		mov	x,#6			'low vertical syncs
    .vhigh		xcont	m_ll,#2
    		xcont	m_lh,#1
    		djnz	x,#.vhigh
    .vlow2		xcont	m_hl,#2
    		xcont	m_hh,#1
    		djnz	x,#.vlow2
                    jmp     #field                  'loop
    ' Subroutines
    		xcont	m_vi,#0
    		xcont	m_av,#1
    	_ret_	djnz	x,#blank
    hsync		xcont	m_sn,#2			'horizontal sync
    		xcont	m_bc,#1
    		xcont	m_cb,c_cb
    	_ret_	xcont	m_ac,#1
    ' Initialized data
    clkinit1	long	%1_000000_0000000011_1111_10_00		'20MHz / 1 * 4 * 1 = 80MHz
    clkinit2	long	%1_000000_0000000011_1111_10_11
    dacmode		long	%0000_0000_000_1011100000000_01_00000_0
    m_sn		long	$7F010000+29		'sync
    m_bc		long	$7F010000+7		'before colorburst
    m_cb		long	$7F010000+18		'colorburst
    m_ac		long	$7F010000+40		'after colorburst
    m_vi		long	$7F010000+256		'visible
    m_av		long	$7F010000+50		'after visible (400 total)
    m_rf		long	$7F080000+256		'visible rflong 8bpp lut
    m_hl		long	$7F010000+15		'vertical sync high low
    m_hh		long	$7F010000+185		'vertical sync high high (200 total)
    m_ll		long	$7F010000+171		'vertical sync low low
    m_lh		long	$7F010000+29		'vertical sync low high (200 total)
    c_cb		long	$507000_01		'colorburst reference color
    x		res	1
    y		res	1
    ' Bitmap
    		orgh	$1000 - $436	'justify pixels at $1000, pallete at $1000-$400
    		file	"bitmap.bmp"
    383 x 273 - 52K
  • That's really tweet neat, Chip !
    edited 2019-08-02 11:08
    VonSzarvas wrote: »
    This IQ modulator was broken in the first silicon because of a Verilog sign-extension misunderstanding. It's working now. It's useful for RF modulation, not just TV. I need to get a picture of it generating a modulated sine wave, so it will be more clear.
  • Very nice Chip. All we need now is HDMI generation to be proven and the P2 should then have the three most common video interfaces nailed, certainly at 480/576 line resolutions, and higher with analog outputs. Highly versatile. Love how little instruction code these video COGs need now with the P2 instruction set.
    edited 2019-08-02 12:02
    Here is the IQ modulator running. It keeps outputting a sine of some amplitude, phase, and frequency, until you change it. In the picture, it's alternating between 10MHz and 40MHz. The P2 is running at 320MHz. Note that the scope view spans only 0.5us.
    Here's the code, kind of hacked from the NTSC example:
    CON
      s		= 127			'scale DAC output (s = 0..128)
      mody		= ((+000*s/128) & $FF) << 24 + ((+000*s/128) & $FF) << 16 + ((+000*s/128) & $FF) << 8 + 128
      modi		= ((+000*r/128) & $FF) << 24 + ((-000*r/128) & $FF) << 16 + ((-000*r/128) & $FF) << 8 + 128
      modq		= ((+120*r/128) & $FF) << 24 + ((-000*r/128) & $FF) << 16 + ((+000*r/128) & $FF) << 8 + 128
      video_pin	= 8
    DAT		org
    ' Setup
    		hubset	clkinit1		'set clock to 320MHz
    		waitx	clkwait
    		hubset	clkinit2
    		setcfrq	##$20000000
    		setci	##modi
    		setcq	##modq
    ' Field loop
    field
    		xcont	m_cb1,c_cb1
    		setcfrq	##$20000000
    		xcont	m_cb2,c_cb1
    		setcfrq	##$08000000
    		jmp	#field
    ' Initialized data
    clkinit1	long	%1_000000_0000001111_1111_10_00		'20MHz / 1 * 16 * 1 = 320MHz
    clkinit2	long	%1_000000_0000001111_1111_10_11
    m_cb1		long	$7F010000+100
    m_cb2		long	$7F010000+50
    c_cb1		long	$FF0000_01
    643 x 518 - 130K
    rogloh wrote: »
    Yes, I'll get to the HDMI tomorrow.
    That's brilliant chip!
    Agreed Roger, with so little code it's easy to understand. The complexities are hidden by the hardware!
    With Composite Video, VGA, and with fingers crossed HDMI, we have an extremely powerful little processor! The internal DACs round it off nicely. :smiley:
  • If the PLLs are the bottleneck are you going to take another pass at them to up that speed even more? It's probably unnecessary, but a 400Mhz clock speed without cooling would certainly give the Prop2 one more cool thing to brag about
    @threadz,
    Don't expect another respin for P2 unless something very serious is found. Each respin is expensive, and another 6-9 month delay.
    This is way more than was ever expected which was 160MHz although we were quietly hoping for 200MHz.
    We are way above expectations!
    Many of us would have been happy with the first "ES" iteration. I guess the only show-stopper problem was with the verilog handling of the -ve sign. This next silicon is just way beyond what we were even hoping for after the "ES" silicon.
    Even if we get another P2 variant (less cogs/ram/pins), I doubt that I would take the risk to tweek anything else. The motto "don't fix what ain't broke" comes to mind here.
    Glad to see IQ modulator working...
    Now, I'm wondering what frequencies I can use around the house without getting in trouble...
  • Oh... for some reason i was thinking silicon tweaks had a few weeks turnaround for small batches. Like PCBs i guess... idk what I was thinking of.
    Regardless, doubling the expectation to 320Mhz is impressive and the silicon keeping up with 400Mhz+ with thermal management is even cooler (pun intended) so I'm far from disappointed.
  • Chip, that VGA demo was simply beautiful! I absolutely love the quality, and I’m curious to know what the max resolution is!
  • threadzthreadz Posts: 56
    edited 2019-08-02 16:28
    @Rayman, In most places the 40m band is at least partially available to amateur broadcasters, largely due to commercial services in that range shutting down to due to lack of use. 7.0-7.1Mhz offers great range, sometimes 1500km+ and decent throughput with not that much atmospheric interference.
    Plus, with the P2's smart pins, streamers, and many cogs, you could plausibly occupy the entire baud at once. Fun!
  • Hi Chip,
    That is quite impressive!
    Cluso99 wrote: »
    @threadz,
    That is my opinion, too. The first iteration could already pass perfectly as a finished product, and was above expectations. But this last respin solves important bugs and opens new possibilities in terms of speed and current consumption. If all tests pass, then is ready for launch at this point, IMHO.
  • Really excellent news Chip.
    Better than expected, always a good place to be!
  • Fantastic news on the PLL and IQ modulator.
    Rayman wrote: »
    I was thinking the old 49MHz cordless phone / walkie talkie band would work. Of course, it would be nice to receive signals as well. The ADC is limited to low MHz. Possibly P2 + SA602 would make a neat little SDR. The ADC has 40 dB of gain control!
    Possibly, the clock gating has reduced the total ground/supply noise, on simple tests, which has further helped the VCO noise effects ?
    More COGs running could impact this ?
    Did you try one of the higher pixel rate VGA demo's ?
    Sometimes the pixel jitter is more obvious at higher clock speeds.
    I will do some more VGA experiments tonight. I will start up more cogs to create more noise and try higher frequencies.
    Good news, as I think that also means the quadrature counters will work now too ?
    There should be quite wide security market applications for P2, where cameras need text inserted to label & timestamp, and some simple movement detection could decide on recording the cameras..
