P2v2? — Parallax Forums
P2v2?
Did the new P2 chips arrive yet? Weren't they supposed to come at the end of July?
  • MJBMJB Posts: 1,235
    edited 2019-07-31 15:59
    2019-07-31 - 00:52:14
    ON Semi didn't get the chips shipped out today, afterall, but they will be at Parallax on Thursday morning.
    https://forums.parallax.com/discussion/comment/1474740/#Comment_1474740
  • MJB wrote: »
    Thanks! I have my figures crossed! :smile:
    They actually showed up this morning. I'm headed down there right now.
  • cgracey wrote: »
    W00T! W00T! Chipmas in July!
  • cgracey wrote: »
    Will there be another live-streamed power up? :smile:
  • RaymanRayman Posts: 16,221
    edited 2019-07-31 17:51
    To be honest, that last live stream was very depressing until they finally figured out how to get the chip working...
    On the other hand, I'd really like to see HDMI working.
    Hope you have an HDMI test code all ready...
  • Rayman wrote: »
    I suspect it took a lot of resources at Parallax to make it happen too. Maybe we're better off waiting for a forum update from Chip.
  • Ken just opened the box. Chips are at a workstation ready to be mounted.
  • jmgjmg Posts: 15,200
    Rayman wrote: »
    That will also depend on being able to hit 250MHz with good margins, IIRC Chip expects this ES2 to be slightly faster, and a little cooler than first ES1.
  • Chip could do another live stream, once the new P2 revision gets tested. I would gladly see it.
    Kind regards, Samuel Lourenço
    samuell wrote: »
    I could make a video showing the chip doing some nice things.
    samuell wrote: »
    Good idea.
    How is the test coverage going ? Are there any issues yet ? - ie any things the P2 cannot do ?
  • cgracey wrote: »
    samuell wrote: »
    The things that P2ES couldn't do perhaps?
    edited 2019-08-02 05:09
    samuell wrote: »
    Yes.
    Today I've been working on a low-current I/O test that can be safely run on the wafer prober.
    When those waver tests faiĺ do you get full statistics at which subtest and where so you can learn about critical points?
    My test reports up to four pins and their errors, in case of a failure. If the test passed, the value $C3 is output on the top 8 pins.
