DS1302 RealTimeClock/event timing issue
I'm using the ds1302 rtc that's built into the ppdb, and the "DS_fulldemo.spin from OBEX. I've added my own little bit of code at the bottom of the demo. The goal is to use it for timing based events. So far i'm just experimenting with toggling a led based on the seconds. That works for any given second 0-59. When i add an "OR" to the if condition (if seconds == 1 OR 37 ect.) , the pin toggles each time through the loop, which is once a second. I'm not sure what to try or look for to go forward, any help or idea is appreciated. Thanks
{{ DS1302_full-demo.spin}}
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
OBJ
  SN    : "Simple_Numbers"
  rtc   : "DS1302_full"
  debug : "SerialMirror"        'Same as fullDuplexSerial, but can also call from subroutines
VAR
  byte hour, minute, second, day, month, year, dow
  byte cmd, out
  byte data[12]
  long activitiesStack[75]
PUB main|i,_month,_day,_year,_dow,_hour,_min,_sec
dira[10]~~
  waitcnt(clkfreq * 5 + cnt)                      'wait 5 secs, start FullDuplexSerial
  Debug.start(31, 30, 0, 115200)
  Debug.Str(String("MSG,Initializing...",13))
  'call this function each time the propeller starts
  rtc.init( 4, 5, 6 )                             'ports Clock, io, chip enable
  'set time
  debug.str(string("=========== DS1302 demo ===========",13))
  debug.str(string("enter 1 to setup ds1302, 0 to proceed on to demo without setting time",13))
  if(debug.GetNumber<>0)
    debug.str(string("enter month (1-12)",13))
    _month:=debug.getnumber
    debug.str(string("enter day (1-31)",13))
    _day:=debug.getnumber
    debug.str(string("enter year (00-99)",13))
    _year:=debug.getnumber
    debug.str(string("enter day of week (1-7)",13))
    _dow:=debug.getnumber
    debug.str(string("enter hour (0-23)",13))
    _hour:=debug.getnumber
    debug.str(string("enter minute (0-60)",13))
    _min:=debug.getnumber
    debug.str(string("enter second (0-60)",13))
    _sec:=debug.getnumber
    'call this function only after DS1302 power on
    rtc.config                                    'Set configuration register
    'call this function to set DS1302 time
    rtc.setDatetime( _month, _day, _year, _dow, _hour, _min, _sec ) 'month, day, year, day of week, hour, minute, second
  'change the tricle charger setup from that currently defined in the config function
  'Trickle charger setup                       tc_enable     diodeSel   resistSel
  rtc.write(rtc.command(rtc#clock,rtc#tc,rtc#w),(%1010 << 4) + (1 << 2)+ ( 1 ))
  out:=rtc.read(rtc.command(rtc#clock,rtc#tc,rtc#r))
  Debug.Str(string("Trickle charge register contents = "))
  Debug.bin(out,8)
  Debug.Str(String(13,13))
  'write data values to ram registers
  repeat i from 0 to 30
    cmd:=rtc.command(rtc#ram,i,rtc#w)
    Debug.Str(string("Writing RAM address "))
    Debug.Dec(i)
    Debug.Str(string(" cmd byte = "))
    Debug.Bin(cmd,8)
    Debug.Str(String(13))
    rtc.write(cmd,i)
  'read data values from ram registers
    cmd:=rtc.command(rtc#ram,i,rtc#r)
    Debug.Str(string("Reading RAM address "))
    Debug.Dec(i)
    Debug.Str(string(" = "))
    out:=rtc.read(cmd)
    Debug.Dec(out)
  'write data to registers 0-11 in burst mode
  Debug.Str(string("Writing RAM data in burst mode"))
    data[i]:=30-i
  cmd:=rtc.command(rtc#ram,rtc#burst,rtc#w)
  rtc.writeN(cmd,@data,12)
  'read data registers 0-11 in burst mode
  Debug.Str(string("Reading RAM data in burst mode",13))
  cmd:=rtc.command(rtc#ram,rtc#burst,rtc#r)
  rtc.readN(cmd,@data,12)
  repeat i from 0 to 11
    Debug.Str(string("Data "))
    Debug.Dec(i)
    Debug.Dec(data[i])
 ' cognew (activities, @activitiesStack)
  'read date and time, once per second
  repeat
    rtc.readTime( @hour, @minute, @second )     'read time from DS1302
    rtc.readDate( @day, @month, @year, @dow )   'read date from DS1302
    Debug.str( SN.decx(hour,2) )
    Debug.str( string(":"))
    Debug.str( SN.decx(minute,2) )
    Debug.str( string(":") )
    Debug.str( SN.decx(second,2))
    Debug.str( string(", ") )
    Debug.str( SN.decx(dow,2))
    Debug.str( string(" ") )
    Debug.str( SN.decx(month,2))
    Debug.str( SN.decx(day,2))
    Debug.str( SN.decx(year,2))
    waitcnt( clkfreq + cnt )
    activities
pub activities
dira[10]~~
'repeat
      if second ==1 or 37         'trigger event based on a time
          !outa[10]
  • the OR operator doesn't work like that.
    you want to write it like this:
    if second == 1 or second == 37
      ' do something here
    Or alternatively
    case second
      1, 37 :
         ' do something here
      other:
         ' do something else here
  • That fixed it, thank you Wuerfel_21
