Propeller 2 Discord Server
QuelloRobotics
Not sure which thread it was posted in, but someone had mentioned that having a Propeller 2-focused Discord server could be helpful.
Created the following server with that in mind: https://discord.gg/9TkW8jD
Guidelines are pinned in the ‘general’ text channel, and there are categories and channels set up for more specific topics, such as ASM, Spin2, the P2D2 project, and more.
I hope that this is a boon to the community, and any suggestions to improve the server are more than welcome.
-Peter
-Peter
I would prefer to see Parallax create and control and moderate the discord server.
As for discord server moderation, there is a ‘Admin’ role with full administrator access that will be given to any Parallax employee and any Forum moderator that joins.
I understand the distrust, and have set up the Admin role with the highest level of control and moderation possible in Discord so that those members here that are trusted and known will be at the controls.
This member has been around for years with over 450 entries under his MacGeek117 moniker.
You can set your name per server on Discord, so you could make your name match the forums just on the prop 2 server.
I joined and am RoyELtham on there.
Might have time later on tonight to contribute
Headed over, will be Spud there.
It’s been around quite a while in the gaming community, but it lends itself well to other ventures.
@JRetSapDoog good idea, went ahead and changed that
Did not see the change go through, so I went ahead and changed it..
Moderator
It's one of a number of packages for group voice chat, all developed for team based gaming. Basically IRC for voice. Teamspeak was the first I think. I used Mumble briefly when playing Eve.
PS: There's certainly a lot of shouting that happens. :P
I can no longer access any Discord server via a browser. This has been ongoing for about a week. A "Did You Know" page that should be temporary is permanent with no way to access servers or messages (which are visible very briefly before disappearing).
I'm using Chromium Version 92.0.4515.98 (Official Build) Built on Raspbian, running on Raspbian 10 (32-bit) on Raspberry Pi 4. Discord access was fine for me until this week. Could someone else please try to access the Propeller 2 or any Discord server via a browser? An HTML expert might be able to see the cause of the problem.
Can't you just upgrade your browser? Using a browser that old is an excellent way to get hacked.
I'm using the latest browser version that is possible for my system. Some people can't access Discord using Safari - different browser, different OS, same Discord website problem.
Working for me on Vivaldi 6.2.3105.54
Though Discord lately seems to be more intent on pushing stupid features no one asked for than making sure anything actually works properly...
Discord accessible again for me after not working for eight days.
Amazing.
Discord "fully rolled back an API deploy." Amazing it took so long.
