cogserial - fullduplex smart serial using interrupt - Page 6 — Parallax Forums
12346»
  • @msrobots
    Please look at the above code. Is there an issue with cogserial at 9600 baud?
  • I am getting this error.
  • Hi @pilot0315,
    I have to look into that error, but you might can use my other attempt of a 2-port driver, this one just uses one file and is more in line with FastSpin's drivers.
    Enjoy!
  • @msrobots
    Thanks I will look at that.
  • @msrobots
    Thanks for the try but getting the same. Hex spits out hex, dec spits out numbers str spits out gibberish.
    Martin
  • @msrobots
    Same with cogserial
  • pilot0315 wrote: »
    @msrobots
    Martin
    you have to do something wrong.
    can you post some code to look at?
  • @msrobots
    Sorry for not sending the code sooner. I cannot get anything working at 9600 baud. Tried serveral gps models from parallax all have 9600 baud.
    Have had excellent experience with the P1 doing this in PropC or Spin. I looked at the Cogserial code as well as the fullduplexserial2 and I do not see anything obvious to me. Eventhough I am not an expert in asm language.
    Thanks for the help.
    No rush.
  • as I was thinking it looks like you are using strings wrong.
    Spin does not have types so a string is just a address in memory pointing to some memory location hopefully ending with a byte 0.
    ser.str(string("test",10,13)) should work and output the text "test" followed by a new line.
    It basically defines a 'string' of bytes in memory like
    byte "test",13,10,0 and gives the memory address of that location to the function ser.str(…)
    gpsraw := gpsd.rx
    ser.str(gpsraw)
    can not work
    gpsraw is a long, a memory address where you can access 4 bytes. so your rx receives the lowest byte in gpsraw. As it should do. Say you get a "A" then gpsraw will be the number 65 stored at @gpsraw in memory.
    But this is not a string. It is just a number in one of the 4 bytes described by gpsraw, defined as long.
    ser.tx(gpsraw) will give you the character received...
  • @msrobots
    I thank you for your help. I am attempting to port from the code in spin and PropC from P1. So we shall see.
    Again thanks.
    Martin
  • Yeah, if you more familiar with C, use C.
    With fastspin you still can use FullDuplexSerial2.spin, there are examples you define FullDuplexSerial2.spin as a class and can use it from C.
    Enjoy!
