PropGCC build issues
in Propeller 1
I'm moving the discussion of building PropGCC to a new thread to avoid polluting Ross's Catalina thread.
DavidZemon: Do you use the "fix-xcode-warnings.sh" script when building the Linux or Windows version of the propeller-gcc repository? It was originally only needed for the Mac builds. If it's use for other builds maybe it should be renamed.
source fix-xcode-warnings.sh export PREFIX=/opt/pxc make
The build-process ended with the known Issue 78.
Is there any known effort to update to a more modern GCC version or at least fix the building-issues? The last changes are 4 years old, while GCC makes progress quiet fast.
Or is this project dead and just kept online for legacy reasons?
See https://forums.parallax.com/discussion/168418/building-propgcc-with-docker
Don't know suse very well, but perhaps this will help you: https://forums.parallax.com/discussion/168418/building-propgcc-with-docker
And if not, then maybe you'd be content running all tools from the command line? https://hub.docker.com/r/davidzemon/propworld
$ g++ -std=gnu++11 -g -O2 -I. -I/Users/my_user_name/source/propgcc/binutils/gdb -I/Users/my_user_name/source/propgcc/binutils/gdb/common -I/Users/my_user_name/source/propgcc/binutils/gdb/config -DLOCALEDIR="\"/opt/parallax/share/locale\"" -DHAVE_CONFIG_H -I/Users/my_user_name/source/propgcc/binutils/gdb/../include/opcode -I/Users/my_user_name/source/propgcc/binutils/gdb/../opcodes/.. -I/Users/my_user_name/source/propgcc/binutils/gdb/../readline/.. -I/Users/my_user_name/source/propgcc/binutils/gdb/../zlib -I../bfd -I/Users/my_user_name/source/propgcc/binutils/gdb/../bfd -I/Users/my_user_name/source/propgcc/binutils/gdb/../include -I../libdecnumber -I/Users/my_user_name/source/propgcc/binutils/gdb/../libdecnumber -I/Users/my_user_name/source/propgcc/binutils/gdb/gnulib/import -Ibuild-gnulib/import -DTUI=1 -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7 -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7 -Wall -Wpointer-arith -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wempty-body -Wunused-but-set-parameter -Wunused-but-set-variable -Wno-sign-compare -Wno-narrowing -Wformat-nonliteral -Werror -c -o gdb.o -MT gdb.o -MMD -MP -MF .deps/gdb.Tpo /Users/my_user_name/source/propgcc/binutils/gdb/gdb.c clang: error: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated [-Werror,-Wdeprecated]
In my memory building binutils has always been problematic on macOS. There's always some workaround to get a complete PropGCC build.Any ideas before I jump into the binutils directory and start debugging?
dgately
Looks like that gcc version that builds is 6.0.0. That is expected, correct?
$ propeller-elf-gcc --version propeller-elf-gcc (propellergcc-alpha_v1_9_0_) 6.0.0 20150430 (experimental) Copyright (C) 2015 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
dgately
Edit: I just noticed that the propeller-gcc repository currently builds gcc4. I've changed my local copy to gcc6 and am attempting a build. If that works, I'll check that version into GitHub.
