How do you take a Propeller on an Airplane?
in Propeller 1
Hey guys, I'm flying to Boston with my wife for her business trip. I want to take an activity board and some sensors to play with during the down time. Will TSA let me board with this stuff in my carry-on luggage?
Shawn A.
Shawn A.
https://parallax.com/product/32912
And if so should I just print it off?
I am planning on bringing a wall-wart, no batteries.
Can I just throw the jumper wires into a ziplock bag.
Just check it through. Never had any problems. Make sure you have some sort of docs as Publison said. Watch the rules on certain types of batteries.
As to cavity search, as long as you don't put any Lithium batteries in there you should be OK. If not, well you may not be OK. (See all sorts of things working in a hospital, hear about much more than I would have wanted. Gives new meaning to "can't unsee that"
So there is a micro center in boston, interesting! I have 3 whole days to do whatever I want, I might have to try and locate it.
If its checked, I wasn't sure if they saw something they didn't like if they would keep the whole bag! That would be a problem!
btw, I couldn't take a Propeller on an airplane anymore ........ not unless it was a vintage Constellation
Right on memorial drive in Cambridge. Conveniently located in the same parking lot as a Trader Joe's. Just think, if they built a big roof over the two, it would be just like Fry's with indoor parking.......
Also with a bit of planning, depending on where you are driving from, it is possible to avoid the tool road in.
Edit: I did print off the pdf manuals for everything I took, and left them at the top of the checkin bag! I did not take any batteries with me either!
Thanks for the Advice guys!
Shawn A.
