Surface mount crystal — Parallax Forums
im designing a .8"x1" board and i have everything on it i need, but i have the same crystal as on the prop mini and was wondering if there is surface mount version that is compatible with the prop? has anyone used one or know of one? the one used on the flip wont work because its too small, im hand soldering, im pretty good but not that good haha.
  • *Paging jmg* - he seems to have an encyclopedic knowledge of such things.
  • im using the 64 KB SMT EEPROM M24512 and i can solder those legs but thats about as small as i can go. i found some oscillators in a similar package but im not sure about the load capacitance and such. thanks
  • Check the downloadable schematic for Parallax's FLiP module.
    edited 2019-05-09 18:13
    The FLIP uses a tiny 5MHz MEMS oscillator; it is not a crystal per se.
    It is hard to find 5MHz xtals in small SMT packages. The smallest I have is 5x7mm. On the other hand, 10MHz xtals in much smaller SMT packages are easy and work fine with the Prop (up to PLLx8).
  • The Prop Mini crystal is not a bad choice, plus it is a proven design.
  • jmgjmg Posts: 15,193
    bnikkel wrote: »
    How small do you need to go ?
    As above, the Xtal element is physically too large to fit into tiny packages, so you can buy 5MHz Xtals but not that much smaller
    If you are ok with reduced precision, there are SMD ceramic resonators as small as (4.50mm x 2.00mm)
    Otherwise, you need powered Oscillators, and those can come quite small.
    eg As small as (1.60mm x 1.20mm) for DSC6001HI1A-005.0000T ±50ppm, or even smaller to 1.5x0.8 BGA parts, for SiT8021 (±100ppm only)
    If you have a need for real precision (single digit ppm?) and 5MHz, that's tougher, but I do spot a non-stocked part code for a
    ASTX-H12-5.000MHZ-I25-T 2.5ppm 5MHz 2.5 mm x 2 mm
    Best precision stocked looks to be ±15ppm
    ECS-3225S33-050-EN-TR Miniature Crystal Oscillator HCMOS Tight Stability 3.3V 5MHz ±15ppm -40 to 85°C 3.2x2.5x0.9mm SMD T/R
    and that supplier and family, does have down to this, as a valid part code, if your volumes are good :)
    ECS-2520S33-050-FN-TR Miniature Crystal Oscillator HCMOS Tight Stability 3.3V 5MHz ±10ppm -40 to 85°C 2.5x2x0.9mm SMD T/R
    re-checking into that FLiP osc, gives BOM was SIT8918BE-13-33E-5.000000E (2520), which now shows as 'Not For New Designs', so they must have an alternative ?
    There is also this older thread, where the lower slew, lower RFI oscillator SIT8918BEL13-33E-5.000000E was tested in FLiP
    https://forums.parallax.com/discussion/comment/1414277/#Comment_1414277
    Maybe parallax should qualify the physically compatible, alternative of
    ECS-2520S33-050-FN-TR 3.3V 5MHz ±10ppm -40 to 85°C 2.5x2x0.9mm
    a few more cents for a good boost in precision ?
    jmg wrote: »
    re-checking into that FLiP osc, gives BOM was SIT8918BE-13-33E-5.000000E (2520), which now shows as 'Not For New Designs' at Digikey, so they must have an alternative ?
    Hmm, SiTime's data sheet is still back in 2015, but if I flip in Digikey between 'Active' and 'Not For New Designs', this alternate part pops up with modest stocks.
    SIT8918BEL13-33E-5.000000G 3.3V ±50ppm -40°C ~ 105°C 4.7mA 2.50mm x 2.00mm $0.96288/1000
    Hehe, look, it is the lower slew variant, & the same part code Tracy Allen confirmed with FLiP+GPS
    - which make sense to be a default for a 5MHz Osc.
    hmm... I wonder if a sample request, like Tracy did, triggers a build of 200 pcs and those go onto Digikey's shelves ?
    Good to see stock of a lower-RFI choice, should any FLiP users need it :)
    Comparing with Avnet
    ECS-2520S33-050-FN-TR 3.3V 5MHz ±10ppm -40 to 85°C 2.5x2x0.9mm $0.7889/1k
    so you need to order 1000, but the 5x better spec of ±10ppm, is cheaper than Digikey's price for ±50ppm SIT8918
  • ive been using the prop mini as a receiver in 1/87 scale RC trucks i cut off the top of it right after the crystal and trim half the through hole on each side getting the board down to .7" x .9". my design is slightly bigger but has access to all 32 pins, i run off a 1s lipo through a diode to drop the voltage just enough. if i can find a slimmer crustal and maybe closer to the footprint of the 64kb memory im using then i could make it much smaller. i guess i need the same precision as the prop crystal or better? not to sure, my program runs fine now.
    bnikkel wrote: »
    By 'crystal' here I guess you mean Crystal or External Oscillator ?
    If you are ok with thru-hole, another choice could be 'watch crystal' cylinder packages, you can get 8mm x 3mm dia 5MHz Xtals.
    Smallest SMD 5MHz looks to be ~ (8.00mm x 4.50mm)
    ±50ppm will likely be just fine, but if there is a low cost (or sometimes even lower cost, as above) better ppm choice, then take it.
    The very low ppm are usually used for Test & measurement systems, but it does no harm to have better precision on a general board :)
  • lardomlardom Posts: 1,659
    edited 2019-05-11 02:30
    I recently designed a Propeller pcb that has two smd regulators. I liked being able to solder the parts without having to turn the board over. My next board will have even more smd parts. I found an smd 5Mhz crystal at DigiKey. I would be willing to try a crystal like this after first checking the datasheet. https://www.digikey.com/product-detail/en/ecs-inc/ECS-50-20-5PX-TR/XC1265CT-ND/827729
    edited 2019-05-11 02:43
    lardom wrote: »
    Larry, do yourself a favor and don't even bother with those huge and horrible SMD HC49 rocks. If you are going to use HC49 then use through-hole because at least they don't need huge pcb smd pads out to the side which was the industry's feeble attempt at SMD at the time, and somehow it stuck. However there are plenty of 6MHz and 10MHz rocks available in all sorts of shapes and sizes and cheap.
    Here's a 2 pad 10MHz 60 cent SMD 5x3mm that's easy to solder even with an iron, just make the pcb pads protrude out a little. I've used similar ones in commercial products for many years and my startup routine automatically checks for 5 or 10MHz crystal to end up with 80MHz but it is just as easy to specify that in your code.
    for many applications, ceramic resonators will be ok, and Murata list these as their best tolerance 5MHz models 4.5x2.0mm, stocked at Mouser and Arrow.
    CSTNR5M00GH5C000R0 4.5x2.0mm 5.0MHz +/-0.07% +/-0.11% max. +/-0.07% max. 60Ω 39pF -20℃ to 85℃ Consumer/Industrial 26c/3k
    CSTNR5M00GH5L000R0 4.5x2.0mm 5.0MHz +/-0.10% +/-0.13% max. +/-0.07% max. 60Ω 39pF -40℃ to 125℃ Automotive 26c/3k
  • Here's a 2 pad 10MHz 60 cent SMD 5x3mm that's easy to solder even with an iron, just make the pcb pads protrude out a little. I've used similar ones in commercial products for many years and my startup routine automatically checks for 5 or 10MHz crystal to end up with 80MHz but it is just as easy to specify that in your code.
    As long as I can solder them with a fine tip iron they are worth a try. I'll include the footprint in my next pcb.
  • lardom wrote: »
    Yes, they are easy but I find a good flat tip much more usable than a fine needle tip since they have problems conducting enough heat to the joint. The flat tip also allows you to solder QFP's easily.
  • Yes, they are easy but I find a good flat tip much more usable than a fine needle tip since they have problems conducting enough heat to the joint. The flat tip also allows you to solder QFP's easily.
    I've got one, thanks.
    edited 2019-05-13 21:02
    Stephanie at Parallax confirmed that FLIP now in production are now using the "L" version of the STtime clock ocillator,
    SIT8918BEL13-33E-5.000000G.
    For some time now, no interference with nearby GPS.
    However, one has to keep in mind that clock oscillators, despite their tiny tiny size, are not a lowest power solutions. They keep running at ~4mA even when the Prop is switched to RCslow. I suppose some trickery might be conceived to put it into µA standby mode, using its OE pin. ("E" in the part designation.)
    jmg wrote: »
    jmg wrote: »
  • Hi Tracy Allen
    According to SiTime's Part Number Decoder:
    https://sitime.com/part-number-decoder
    the part that is being used at Flip (SIT8918BEL13-33E-5.000000G) has only the Output Enable function, available when Pin 1 is pulled Low, as per SiT8198B datasheet (Tables 1, 2).
    By driving Pin 1 to a Low state, the present device would drop its I_od comsumption to 4.5 mA, wich is no big savings at all.
    Keeping the other specs, for it to alternativelly have the Standby function available its part number would be: (SIT8918BEL13-33S-5.000000G). Then I_std (Table 1) would rule, dropping power consumption to mere 8.5 uA max. (@3.3 V).
    Hope it helps a bit.
    Henrique
    Cool, good to know your testing rippled thru to the product ! :)
    A move to ±20ppm from ±50ppm would have been nice too, but that does add a few cents.
    Fair point. When running, the ~4mA is not the total change, as there is a slight saving from the Xtal-Amplifier not being used linear ( 0.3mA @ 5MHz in the data )
    There are lower power oscillators, but that comes at the cost of precision, & worse jitter, which drops to ±100ppm
    eg
    SiT8021 160 μA(MAX) f = 6.144 MHz, Vdd = 2.25V to 3.63V, no load ±100ppm (1.54mm x 0.84mm) BGA4
    That one may give less total power than using a Crystal.
    edited 2019-05-14 01:18
    Yanomani, Thanks for careful reading. I do now see the "S" variant, where pin 1 is comes configured as shutdown, with µA level current and 5ms startup time. Not to be confused with "E" variant, which uses pin 1 as output enable, higher current, faster startup.
    It is a moot for controlling power on the FLIP, which uses the "E" version, and has pin 1 hard wired high and 100% enabled anyway.
    Someone designing their own tiny board and in need of shutdown could probably come up with a scheme with the "S" version, to shutdown the clock oscillator using an auxiliary Prop output pin. The Prop can be set to boot up in RCfast, then to switch over to the more accurate oscillator when needed.
    SitTime claims to have a USB field programmer for these things, the "time machine 2", so, churn out whatever variant in frequency and features you want.
  • there seem to be few options for the 5mhz smd, what all is involved with switching to 10mhz? pro/con? thanks for all your help guys.
  • also, for what applications would a ceramic resonator not be good for?
    JMG suggested this one
  • I'm surprised that resonators were even mentioned as they are a very poor man's crystal at 5,000 ppm typical. But once again the thread gets sidetracked and in this case in the pursuit of low power, but who was asking for that?
    Take my advice and just use a 10MHz SMD since I have commercial designs running with these for close on 10 years without any problems.
    edited 2019-05-14 16:30
    bnikkel wrote: »
    Change
    CON
      _clkmode = xtal1 + pll16x                             ' Set up the clock frequencies
      _xinfreq = 5_000_000
    to
    CON
      _clkmode = xtal1 + pll8x                             ' Set up the clock frequencies
      _xinfreq = 10_000_000
  • thanks Publison, how would i write that in C?
    bnikkel wrote: »
    The Prop data sheet formally says this (PLL is always XTAL * 16)
    "The PLL internally multiplies the XIN pin frequency by 16. The PLL’s internal frequency must be kept within 64 MHz to 128 MHz – this translates to an XIN frequency range of 4 MHz to 8 MHz."
    - but as Peter mentions, many 'get away with' using 10MHz Xtals and the 160MHz PLL.VCO that then operates at.
    If your application is not commercial, or your temperatures are not extreme, it's easy enough to trial 10MHz.
    Parallax chose the 5MHz oscillator in FliP, so they can stay inside the data sheet specs.
    bnikkel wrote: »
    Anything where that 0.07% precision is not good enough :)
    eg UARTs are fine, and even USB is ok, most industrial control and servos will be fine, but TV colour burst would be out, High End Digital Audio is probably going to be sniffed at, and RF carrier work or Instrumentation / Timing would usually choose lower ppms.
    I'm surprised that resonators were even mentioned as they are a very poor man's crystal at 5,000 ppm typical..
    The one I quoted was not 5000ppm, but you are right, you can buy lower spec resonators, and at lower prices.
    eg
    STCR5M00G53-R0 Murata 5.0000MHZ $0.19290/3k ±0.2% ±0.5% Built in Capacitor 15pF 60 Ohms -20°C ~ 80°C (4.50mm x 2.00mm)
    edited 2019-05-14 22:22
    Just to clarify for those that might find this confusing, the VCO in the PLL locks onto a frequency that's 16 times the crystal frequency. IOW, it always runs at the maximum frequency, regardless of the _clkmode setting. When this setting specifies, for example, pllx8, nothing internally is multiplied by 8 but, rather, the VCO frequency is divided by 2 to get the system clock frequency. Actually, the divider chain is always active down to divide-by-16. The pllx- just selects the tap.
    And for reference i use 12MHz without anny issues. The internal PLL will perform well above the stated 128MHz as this rating is for the extremely wide spec ranges. Chip at one stage did post the max PLL value but cannot recall where that is anymore.
    About 14.3MHz has been the experienced top range although Sapieha got the DIP40 to 15MHz reliably.
