fastspin spin2gui
in Propeller 1
This morning I was trying some different things with fastspin. One thing I was trying to do is setup Geany to basically load the EEPROM with a newly compiled .bas program. While doing different things I came across some differences in fastspin.
I created a small program, using spin2gui, which compiled without errors, and ran as expected using the 'Compile & Run' command.
Just for curiosity I tried to do a fastspin compile using the command line for the exact same code that I just used with spin2gui. That effort came up with an error, "error: syntax error, unexpected input, expecting loop". Checking further I noticed when you compile using spin2gui:
Ray
when you use the fastspin command line complie:Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2019 Total Spectrum Software Inc.
Version 3.9.25 Compiled on: Apr 14 2019
It looks like spin2gui is using an earlier version of fastspin. It also looks like fastspin command line version has a later version number, but an earlier compiled date. Hmm, what to make of this?Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2018 Total Spectrum Software Inc.
Version 3.9.7 Compiled on: Oct 21 2018
Ray
Mike R.
So, when you unzip the spin2gui.zip, the fastspin.exe that is in the folder, is an older version. Not sure why it is there, maybe add a folder called 'old' , and move that there?
Ray
Mike R.
Mike R.
