Happy Easter and Thanks
Whit
Happy Easter from Robotics Under the Stole - https://roboticsunderthestole.blogspot.com/2019/04/happy-easter-2019-from-rus.html
Thanks to all of you for your steadfast presence here on the Forums, your wise counsel, and the encouraging joy that you constantly share!
@Whit: You really need to create a "conversion" kit to turn any capable Parallax robot (S2 and forward) into a...
Holy Roller.
https://www.popularmechanics.com/technology/robots/a26698/germany-robot-priest/
and
Sub EasterDate (d, m, y)
' EASTER DATE CALCULATION FOR YEARS 1583 TO 4099
' y is a 4 digit year 1583 to 4099
' d returns the day of the month of Easter
' m returns the month of Easter
' Easter Sunday is the Sunday following the Paschal Full Moon
' (PFM) date for the year
' This algorithm is an arithmetic interpretation of the 3 step
' Easter Dating Method developed by Ron Mallen 1985, as a vast
' improvement on the method described in the Common Prayer Book
' Because this algorithm is a direct translation of the
' official tables, it can be easily proved to be 100% correct
' This algorithm derives values by sequential inter-dependent
' calculations, so ... DO NOT MODIFY THE ORDER OF CALCULATIONS!
' The \ operator may be unfamiliar - it means integer division
' for example, 30 \ 7 = 4 (the remainder is ignored)
' All variables are integer data types
' It's free! Please do not modify code or comments!
Dim FirstDig, Remain19, temp 'intermediate results
Dim tA, tB, tC, tD, tE 'table A to E results
FirstDig = y \ 100 'first 2 digits of year
Remain19 = y Mod 19 'remainder of year / 19
' calculate PFM date
temp = (FirstDig - 15) \ 2 + 202 - 11 * Remain19
Select Case FirstDig
Case 21, 24, 25, 27 To 32, 34, 35, 38
temp = temp - 1
Case 33, 36, 37, 39, 40
temp = temp - 2
End Select
temp = temp Mod 30
tA = temp + 21
If temp = 29 Then tA = tA - 1
If (temp = 28 And Remain19 > 10) Then tA = tA - 1
'find the next Sunday
tB = (tA - 19) Mod 7
tC = (40 - FirstDig) Mod 4
If tC = 3 Then tC = tC + 1
If tC > 1 Then tC = tC + 1
temp = y Mod 100
tD = (temp + temp \ 4) Mod 7
tE = ((20 - tB - tC - tD) Mod 7) + 1
d = tA + tE
'return the date
If d > 31 Then
d = d - 31
m = 4
Else
m = 3
End If
End Sub
