Executing code from lookup RAM — Parallax Forums
I was under the impression that on the Prop2 we could execute code from lookup RAM just like hub RAM, by putting the code at $200. But I can't seem to get it working. Can anyone tell me what's wrong with the following code? It works correctly if start_cog is at $100, but not if I force it to be at $200.
What am I doing wrong?
DAT
        org 0
start   cogid hex_value
        call #\Flash_Hex
        call #\start_cog
loop    jmp #loop
led_mask
        long     |< (56-32)
hex_value
        long     $10203040
hex_count
        long     $0
flash_count
        long     $0
'        orgf     $200 ' put start_cog in lookup RAM
        orgf     $100 ' put start_cog in hub RAM
start_cog
        coginit  #%1_0000, #start wc
        ret
'--DEBUGGING FUNCTIONS -----------------------------------------
CON
blip_time = 1_000_000
hex_time  = 10_000_000
flash_time = 5_000_000
DAT
        orgh $1000
' LED_On - turn LED on
LED_On
        or       dirb,led_mask
        andn     outb,led_mask
        ret
' LED_Off - turn LED off
LED_Off
        or       dirb,led_mask
        or       outb,led_mask
        ret
' Flash_LED - flash the LED flash_count times
Flash_LED
        cmp      flash_count,#0 wz
   if_z waitx    ##flash_time
   if_z jmp      #done_flash
flash_loop
        call     #LED_On
        waitx    ##flash_time
        call     #LED_Off
        waitx    ##flash_time
        djnz     flash_count,#flash_loop
done_flash
        ret
' Blip_LED - flash LED briefly (e.g. used to indicate zero)
Blip_LED
        call     #LED_On
        waitx    ##blip_time
        call     #LED_Off
        waitx    ##flash_time
        ret
' Flash_Hex - flash the LED to display up to 8 hex digits in hex_value
Flash_Hex
        cogid    hex_count
        mov      led_mask,##|<(56-32)
        shl      led_mask,hex_count
        mov      hex_count,#8
digit_loop1
        ' skip leading zeroes
        rol      hex_value,#4
        mov      flash_count,hex_value
        and      flash_count,#$f wz
 if_z   djnz     hex_count,#digit_loop1
        ' if all we have are zeroes, do one blip
        tjnz     hex_count,#digit_loop2
        call     #Blip_LED
        jmp      #done
digit_loop2
        tjnz     flash_count,#do_flash
        ' for zero digits, do one blip
        call     #Blip_LED
        jmp      #do_next
do_flash
        ' for non-zero digits, flash the digit count
        call     #Flash_LED
do_next
        djz      hex_count,#done
        waitx    ##hex_time
        rol      hex_value,#4
        and      flash_count,#$f
        jmp      #digit_loop2
done
        waitx    ##hex_time*2
        ret
  • RaymanRayman Posts: 16,006
    edited 2019-03-29 00:57
    You have to jump into lut for it to work...
    Oh, you have to copy it into LUT first?
    https://forums.parallax.com/discussion/165903/how-to-write-lut-exec-assembly-code
  • _ret_ prefix can avoid separate ret.
  • RossHRossH Posts: 5,699
    Rayman wrote: »
    Aha! Thanks.
    TonyB_ wrote: »
    Yes, still getting used to that one :)
    See my link above..
    Need to copy code into lut first ...
  • evanhevanh Posts: 17,059
    edited 2019-03-29 04:12
    I've been stashing all my generic subroutines in lutRAM. This is where ORG becomes useful. :) You'll note that the copying is going from hubRAM to lutRAM even though there is an ORG $200 on the block to be copied. The only code block that usefully starts off in cogRAM of cog#0 is the ORG prior to first ORGH. And if that ORGH is set to typical $400 then only 1 kB can fit before it.
    Here's my subroutine wrapper code:
    ORGH
    ALIGNL
    _diaginit				'only called once at beginning
    '-------- Copy lut code into position --------
    		setq2	#(LUT_end - LUT_code - 1)	'copy length, in longwords
    		rdlong	0, ##@LUT_code			'the "0" is lutRAM zero, or $200 in memory map
    ORG  $200					'longword addressing
    '  LUT Code  (Has to be copied from hubram to lutram)
    LUT_code
    LUT_end
    FIT  $400
    evanh wrote: »
    Yes, I am intending to do the same thing. Thanks for the wrapper code.
    Don't forget, the internal stack is only 8 deep.
    And the _RET_ cannot restore the C & Z flags, but you can with RET wc/wz/wcz
  • RossH wrote: »
    As others have already mentioned, you have to explicitly load the LUT RAM with code before trying to execute from it. A few other points:
    - Unlike P1+LMM, P2+hubexec runs at full speed except for branches, which incur a hub lookup penalty
    - As I result I was surprised at how little difference putting code in LUT makes. It's worth it for small loops (particularly if you can use REP) but in general hubexec works pretty well
    - The other reason to keep code in LUT is if you need to use the rdfast/wrfast mechanism, which conflicts with hubexec
    - Oddly enough, it's more efficient to keep code in LUT and tables in COG RAM than the reverse. "rdlut" takes 3 cycles to execute, as opposed to 2 cycles for accessing COG memory, so getting data from COG memory is 50% faster than getting it from LUT memory
    Eric
    Also, keeping data in cogRAM keeps full selection of manipulation on tap. No load-and-store when the data's all in the general registers already.
    For P1, it was often best to put tables at register #0 for fastest access... Wonder if that's still true here...
    I don't know how fast the Prop1 was at doing that but the Prop2's ALT instructions makes tables in any part of cogram easy.
  • TonyB_TonyB_ Posts: 2,268
    edited 2019-03-29 13:18
    If cog and LUT RAM are in one contiguous block of $400 longs in hub RAM, presumably adding $200 to PTRB after COGINIT gives start address of LUT code?
  • TonyB_ wrote: »
    It's rare for the COG code to actually fill $200 longs (especially since the last $10 are registers). Besides, instead of:
       add ptrb, ##$200
    it's actually 1 instruction shorter to do:
       loc ptrb, #\@cog_code_addr
    What's the backslash do?
  • The backslash forces absolute rather than relative addressing. It's optional as long as you don't move the code around, but personally in situations like this I like to know exactly what the assembler is generating -- with the backslash it's forcing a direct move of the hub address for cog_code into ptrb, without it it could do a relative address, so adding the current pc with the difference to @cog_code_addr.
    I'd still prefer to see different mnemonics for these instructions (loc and locrel, or locabs and locrel, or whatever) instead of the backslash, but that's another story.
