Should ORG imply ORGH?
RossH
in Propeller 2
Ok,
I found what may be a problem with the ORG directive on the P2 (or if it is meant to work this way then it is VERY confusing!). The problem is that using ORG with a non-zero value appears to generate incorrect cog addresses. You can fix it by inserting a corresponding ORGH, but should this really be necessary?
For example, consider this code ...
Everything is fine here. But suppose we remove the long at cog_5 and instead use an ORG directive to instruct the assembler to put the next long at cog location 6 ...
Here, the code generated is correct, but the long labelled cog_6 actually appears at cog location 5. To make it work correctly, I have to uncomment the "cogh" directive.
I'm fairly sure this is not the expected behaviour .... but the P2 is such a strange beast that I am just not 100% sure!
By the way - PNUT and P2ASM both behave the same way.
DAT
org $0
cog_0 mov cog_7,cog_6
cog_1 mov cog_6,cog_8
cog_2 mov cog_7,cog_8
cog_3 mov cog_8,cog_6
cog_4 mov cog_6,cog_7
cog_5 long $55555555 ' force next cog address to be 6
cog_6 long $66666666
cog_7 long $77777777
cog_8 long $88888888
DAT
org $0
org $6 ' force next cog address to be 6
' orgh $6*4 ' force next hub address to match cog address
orgf - "fill to"
DAT 00000 000 org $0 00000 000 f6000e06 cog_0 mov cog_7,cog_6 00004 001 f6000c08 cog_1 mov cog_6,cog_8 00008 002 f6000e08 cog_2 mov cog_7,cog_8 0000c 003 f6001006 cog_3 mov cog_8,cog_6 00010 004 f6000c07 cog_4 mov cog_6,cog_7 00014 006 org $6 ' force next cog address to be 6 ' orgh $6*4 ' force next hub address to match cog address 00014 006 66666666 cog_6 long $66666666 00018 007 77777777 cog_7 long $77777777 0001c 008 88888888 cog_8 long $88888888The hub address increments by 4 and the cog address increments by 1 based on the value of the last ORG.Note that labels in P2 have two values, their "hub address" and their "default address". After ORGH these are always the same, but after ORG X the "default address" starts over at X but the hub address continues incrementing as before. "@ label" always refers to the hub address of a label, whereas just plain "label" is the default address.
Finally, there are actually 3 assemblers for P2 -- PNut, P2ASM, and fastspin. They all treat ORG and ORGH the same way.
ORGH and ORGF are Prop2 specials.
Well, at least it's consistent! I can't remember using ORG this way on the P1 ... but I am pretty sure I would have been both surprised and annoyed at behaviour like this
On P2, a COG start can happen at non zero addresses, and a COG can go right into HUBEXEC on start too.
Yes, orgf does it. I don't remember that from my P1 days. Thanks.
