Discussing SD Drivers (depreciated fsrw) - Page 3 — Parallax Forums
1356789
  • cheezus wrote: »
    I'm working on a "template" cog engine, mostly for my own understanding. What I have so far is this :
    PUB start_explicit( DO, CLK, DI, CS ) : card_type
      stop
      long[@cmd] := "i"                         'set flag to know if the started cog has read its parameters
      long[@cmd][1] := @DO
    Ugh! Please don't do this. I know it was popular in Spin1 to save time by passing pointers to the parameters that happened to be on the stack, but it really kills performance in fastspin (it'll work, but it forces the compiler to store local variables on the stack instead of in registers, which is much slower). It also makes porting the code to other languages harder, because not all of them will pass variables on the stack -- many, like fastspin, will pass them in registers instead.
    You've also got the mailbox in the DAT section, which means it's shared by all instances of the object. If you wanted to drive two different cards, with two different COGs, you'd need to have a lock on the mailbox so they don't conflict. Whereas if the mailbox is a local variable of the object this wouldn't be an issue. Maybe it doesn't matter for the SD card driver, but you mentioned wanting to use this as a template for other objects, so it might come up there.
    So I would suggest that the more natural way to write this is:
    VAR
      long mbox[10] ' or whatever size
    PUB start_explicit(DO, CLK, DI, CS) : card_type
      stop
      mbox[0] := "i"
      mbox[1] := DO
      mbox[2] := CLK
      mbox[3] := DI
      mbox[4] := CS
      cog := cognew(@asm_start, @mbox)
    That'll also simplify your PASM startup code, because you won't have to juggle multiple pointers (you just have the one to mbox), and I think makes everything easier to understand, both for the human reader and for the compiler.
    Eric
  • Thanks for those tips Eric!
    As to passing parameters, I'll need to figure out the best way to handle this. I use this trick because there are many times I would like to pass more initialization info to the cog than I have parameters. I never did get my head around the "pre-load" trick used in the P1 and always did it this way. I guess I could use several commands for initialization, need to think on this more.
    Regarding the mailbox in the dat section, I also have a commented out VAR section if I wanted multiple instances running at the same time. I will have one platform with 2 sd cards so this will be something to think about. That hardware also has a shared SPI bus so was thinking about providing some SPI methods for accessing those devices as well. I think it's best to start out "generic" so maybe others can find it helpful as well.
  • Attached is a sdrw test for the eval board. Confirmed to work consistently on my P2ES. You may want to consider adding this to the RC3 distribution. It was the file @Rayman included in his, with additions for CR + LF in the terminal. Thank you @cheezus !
  • So I'm looking at the docs, trying the RTFM manual way.. I think I'm close to testing the improved read, using smartpins. I'm sure there's something still wrong though. I'm sure the experts can see where I'm going with this though.
    pri read : r  | c, o        '   Read eight bits from the card.
            c := clk
            o := do
        asm
        dirl    c
        wrpin   sp_async_tx,c
        wxpin   ##$9,c          'set base period
        dirh    c
        dirl    o
        wrpin   sp_clk_cfg,o    'sync tx
        wxpin   #%1_00111,o     'stop/start mode
        dirh    o               'enable smartpin
    '    wypin   txdata,o        'data, need to do anything?
        wypin   #8,c           'start clock, tx data '' ! should this be 8 or 16?
    busy    testp   c wc
        if_nc   jmp #busy
        rdpin   pa,c ' needed?
        rdpin   r,o
        dirl    o
        dirl    c
        '' next part per chip's smart pin documentation
        REV r              ' Set MSB First
        TRIML r,#7
        endasm
  • cheezuscheezus Posts: 298
    edited 2019-07-25 20:30
    I've been working on this a bit more, trying to prove concepts using inline asm before trying to put them in their own cog. Spent way too much time trying to get the smartpin read working without any luck but I was able to get free-running clock gen for init clocks working. The one "improvement" I've been focusing on is converting the ReadBlock function to inline asm. I need to do the same for the WriteBlock, which should improve performance a few percent. It's not 100% asm yet, I got lazy..
    pub readblock(n, b) | c, i, o, outv, r
    '   Read a single block.  The "n" passed in is the
    '   block number (blocks are 512 bytes); the b passed
    '   in is the address of 512 blocks to fill with the
    '   data.
            c := clk
            o := do
            i := di
            DRVL_(cs)
            starttime := cnt
        asm
            rep     #.end_read0, #8
            drvl    c
            drvh    c
    .end_read0
                mov     outv, #$40+17
                rol     outv,    #24
                rep     #.end_send0, #8
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send0
                drvh    i
                mov     outv, n
                rep     #.end_send1, #32
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send1
                drvh    i
                mov     outv, #$87
                rol     outv,    #24
                rep     #.end_send2, #8
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send2
                drvh    i
        endasm
            readresp
            readresp
            repeat sectorsize
                asm
                    mov     r,          #0
                    rep     #.end_read, #8
                    drvl    c
                    waitx   #14   '' !! 13 safe for up to 160 mhz, 14 for 320mhz, 57@320mhz external
                    testp   o               wc
                    drvh    c
                    rcl     r,          #1
                .end_read
                endasm
              byte[b++] := r
            asm
                rep     #.end_read2, #16
                drvl    c
                drvh    c
            .end_read2
            endasm
       return endcmd
    I've also mostly converted CMD to inline ASM. Again proving things work before burying in a cog!
    pri cmd(op, parm)  |  c, i, o, outv
    '   Send a full command sequence, and get and
    '   return the response.  We make sure cs is low,
    '   send the required eight clocks, then the
    '   command and parameter, and then the CRC for
    '   the only command that needs one (the first one).
    '   Finally we spin until we get a result.
            DRVL_(cs)
            c := clk
            o := do
            i := di
        starttime := cnt
        asm
                rep     #.end_read0, #8
            drvl    c
            drvh    c
    .end_read0
                mov     outv, op
                add     outv,   #$40
                rol     outv,   #24
                rep     #.end_send0, #8
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send0
                drvh    i
                mov     outv, parm
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send1
                drvh    i
                cmp     op, #0              wz
        if_z    mov     outv, #$95
        if_nz   mov     outv, #$87
                rol     outv,    #24
                rep     #.end_send2, #8
                drvl    c
                rol     outv,       #1      wc
                drvc    i
                drvh    c
    .end_send2
                drvh    i
        endasm
        return readresp
    I'm really hoping to get much closer to sysclock /4 or maybe /8, the waitx #14 looks really ugly, lol
    I have a few ??? I'm still trying to understand, such as I'm running @320mhz as max clock but seeing that 290mhz is where things top out.. I should probably start testing 290mhz clock??? Although once things are solid at the 160mhz "standard" clock, I haven't had a problem running up @320.
    Also, since I need to slow things down for LA scoping I've been putting the PLL out of spec in all kinds of strange ways and things are surprisingly stable. Is there a recommended pll setup for 8mhz or 16mhz?
    One thing I'd really like to do is figure out how to "tune" that waitx automatically. I tested using the SD card on my hardware and I had to push this to almost 60. I'm assuming ringing of cable and lots of PCB trace, I'll be shortening the cable eventually, hopefully this helps.
  • I finally started making progress, realized I was making a few dumb mistakes. Forgivable since I've had a bit of a break. I've been able to get the smartpins working, although it's still not quite right. Just missing a waitx somewhere I'm pretty sure, since removing the debugging code causes things to stop working. I'd investigate further but pretty sure I'm going to lose power soon. Once the weather calms down I'll get back on it. Now that it's working I can fine tune things as needed.
        sp_sync_rx  = %0000_0011_000_0000000000000_00_11101_0  '' +3, inv
        sp_sync_cfg = %1_00111
            c := clk
            o := do
        asm
            dirl    o
            wrpin   #sp_sync_rx,o       'sync tx
            wxpin   #sp_sync_cfg,o      'stop/start mode
            akpin   o
            waitx   #12
            rep     #.end_rd, #8
                drvl    c
                waitx   #12
                drvh    c
                waitx   #2
    .end_rd
            waitx   #32
            rdpin   r, o
            rev     r
            and     r, #$ff
            dirl    o
        endasm
        te.tx(r)            ' debugging, remove breaks
    I'm glad I've got it working and I'll figure out what I'm doing wrong shortly. :smile: Then getting smartpin TX and clock working!
  • I'm just going to drop this working version here, in case.. Smartpin RX is working and I've got the clock for RX using a smartpin as well. I just need to get the smartpin TX working and then see about writing an SPI cog. Much work to be done but take one victory at a time!
    con
        sp_srx      =   %0000_0011_000_0000000000000_00_11101_0  '' +3, inv
        sp_srx_c    =   %1_00111
        sp_clk      =   %1000_0000_000_0000000000000_01_00101_0
    var
       long spi_bitcycles
    .. 'init code does this
            spi_bitcycles :=((clkfreq / spi_clk_max) /2 )+1   ' needs to be inverse of freq / max
            bt := ((clkfreq / 400_000 ) / 2 ) +1  '' UNDER 400k
        asm
                wrpin   #sp_srx,    o       'sync tx
                wxpin   #sp_srx_c,  o       'stop/start mode
                dirl    c
                wrpin   #sp_clk,    c
                wxpin   bt,         c       'set base period (*2) ''2.5 400kmax init
                dirh    c
                wypin   #initclks,  c       'start clock, tx data n-1?
        .busy   testp   c               wc
        if_nc   jmp     #.busy
                drvh    csn
                rdpin   pa,c
        .busy2  testp   c               wc
        if_nc   jmp     #.busy2
                wrpin   #0,         c
       endasm
    pri read   | c, o, t, bc      '   Read eight bits from the card
            c   := clk
            o   := do
            bc  := spi_bitcycles
        asm
                dirl    c
                wrpin   #sp_clk,    c           ' set clk pin mode
                wxpin   bc,         c           ' set clk base period
                dirh    c                       ' enable sp clk
                dirh    o                       ' enable sp di
                wypin   #byteclks,  c           ' start clock
        .busy   testp   c                   wc
        if_nc   jmp     #.busy
                rdpin   t,          o           ' get data
                dirl    o                       ' disable smartpin di
                wrpin   #0,         c           ' clear clk sp config
                rev     t
                and     t,          #$ff
        endasm
    '    term.tx(t)
        return t
    Once the TX is using smartpins, I won't need to disable the clock pin at the end of the read method. Really liking these smartpins. What a cool chip, once you get past that initial learning curve!
  • I think I've got the smartpins thing good. I'm still not 100% sure I understand the timings but it everything seems pretty solid. I've still got several things to do, one I noticed in testing is default the max spi clock to sysclock /2 in cases where sysclock is too low to meet max spi clock. I also need to generalize the bpin config to allow other sd card configurations. I'll need to wrap my head around this next but I wanted to get it working. You can invert the clock polarity by commenting out + sp_inv_pin on the clock config line. (I use default high because of pullups and pin sharing)
    @"Peter Jakacki" I can't remember if the p2d2 uses the same pins as the p2ES. If not, you will probably need to change the smartpin config lines for SP_STX and SP_SRX. Let me know if you need any help.
    I have a bunch of work left to do before hiding the spi away in it's own cog. I think I'm getting close, finally!
        SDSPI driver for P2-ES FastSpin/InlineASM RC3
        Cheezus Slice (Joe Heinz)  -   July - 2019
        Thanks to all those out there in fourm land!
        Original spin version by Radical Eye Software Copyright 2008
    'CON   Baudrate = 115200    'baud rate for serial communications
    con
       sectorsize = 512
       sectorshift = 9
       spi_clk_max = 20_000_000     ' 20mhz safe, 25 seems to work though?
       '' NOTE, SYSCLOCK needs to be 2x spi_clk_max for now
        '%AAAA_BBBB_FFF_PPPPPPPPPPPPP_TT_MMMMM_0
        'ppp        =''xxxx_CIO_HHH_LLL
        sp_inv_pin  = %0000_001_000_000 << 8
      'smartpin modes                    TT_MMMMM_0
        sp_stx      =   (%0010 << 24) + %01_11100_0     ' +2
        sp_srx      =   (%0011 << 24) + %00_11101_0     ' +3
        sp_srx_c    =   %0_00111
        sp_clk      =   %01_00101_0 + sp_inv_pin ' inv clock right way
        initclks    =    (20*(2*8)) ' send 20 bytes to init card
        byteclks    =   (2*8)
    var
       long di, do, clk, cs, starttime, sdhc, di_mask, do_mask, clk_mask, do_pin
       long spi_bitcycles
    'obj   term: "SimpleSerial.spin2"           ''-P2 TERM
    pri send(outv) | c, i      '   Send eight bits, then raise di.
            i := di
            c := clk
            asm
                    SHL outv,           #32-8       ' Set MSB First
                    REV outv                        ' Set MSB First
                    wypin   outv,       i           ' data !!
                    rdpin   pa,         c
                    wypin   #byteclks,  c           'start clock, tx data
            .busy   testp               c   wc
            if_nc   jmp     #.busy
                    wypin   #$FF,       i
    endasm
    pri read   | c, o, t     '   Read eight bits from the card.
            c   := clk
            o   := do
        asm
                rdpin   pa,         c
        .busy   testp   c                   wc
        if_nc   jmp     #.busy
                rev     t
                and     t,          #$ff
        endasm
        return t
    pub start_explicit(iDO, iCLK, iDI, iCS)| t, c,csn,o,i,  bt    'RJA adding in some things to make work
        '' globals
        do := iDO
        clk := iCLK
        di := iDI
        cs := iCS
        '' locals
        c := clk
        csn := cs
        o   := do
        i   := di
        bt := spi_bitcycles
        asm
                drvh    csn
                dirl    c
                wrpin   #sp_clk,    c
                dirh    c
                dirl    i
                wrpin   #sp_stx,    i       'sync tx
                wxpin   #%1_00111,  i       'stop/start mode
                dirh    i
                wypin   #$FF,   i
                dirl    o
                wrpin   #sp_srx,    o       'sync rx
                dirh    o
        .busy   testp   c               wc
        if_nc   jmp     #.busy
                wypin   #byteclks,  c       'start clock, tx data n-1?
                rdpin   pa,         c
        .busy2  testp   c               wc
        if_nc   jmp     #.busy2
        endasm
        starttime := t
        cmd(0, 0)
        drvh_(cs)               ' Deselect the card to terminate a command.
        cmd(8, $1aa)
        read
        read
        read
        read
        repeat
                cmd(55, 0)
                t := cmd(41, $4000_0000)
                if t <> 1
                    quit
        if t
                return -40'abort -40 ' could not initialize card
        cmd(58, 0)
        sdhc := (read >> 6) & 1
        read
        read
        read
        if sdhc == 0    ' if not hc
          return -40    ' fail mount
        return sdhc +1              ' return card type
    pri readresp | r
    '' made return timeout to caller CHZ 2-2019
    '   Read eight bits, and loop until we
    '   get something other than $ff.
       repeat
          if (r := read) <> $ff
             return r
          if checktime == -41
            return -41
    pri busy | r        '   Wait until card stops returning busy
       repeat
          if (r := read)
             return r
          if checktime == -41
            return -41
    pri checktime       '   Did we go over our time limit yet?
       if cnt - starttime > clkfreq
          return -41'abort -41 ' Timeout during read
    pri cmd(op, parm)
        DRVL_(cs)
        starttime := cnt
        read
        send($40+op)
        send(parm >> 24)
        send(parm >> 16)
        send(parm >> 8)
        send(parm << 0)
        if (op == 0)
            send($95)
        else
            send($87)
        return readresp
    pri endcmd      ' Deselect the card to terminate a command.
    PUB stop                    ' RJA adding in some things
    PUB release
    pub start(basepin)
      result := start_explicit(basepin, basepin+1, basepin+2, basepin+3)
    '   data.
       starttime := cnt
       cmd(17, n)
       readresp
       repeat sectorsize
          byte[b++] := read
       read
       read
       return endcmd
    pub writeblock(n, b)
    '   Write a single block.  Mirrors the read above.
       starttime := cnt
       cmd(24, n)
    '   cmd(24, doSDHC(n))
       send($fe)
       repeat sectorsize
          send(byte[b++])
       read
       read
       if ((readresp & $1f) <> 5)
          return -42'abort -42
       busy
       return endcmd
    '  Permission is hereby granted, free of charge, to any person obtaining
    '  a copy of this software and associated documentation files
    '  (the "Software"), to deal in the Software without restriction,
    '  including without limitation the rights to use, copy, modify, merge,
    '  publish, distribute, sublicense, and/or sell copies of the Software,
    '  and to permit persons to whom the Software is furnished to do so,
    '  subject to the following conditions:
    '  The above copyright notice and this permission notice shall be included
    '  in all copies or substantial portions of the Software.
    '  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
    '  EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
    '  MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
    '  IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
    '  CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
    '  TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
    '  SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
  • Pretty sure I'm getting close now. This is completely untested and I need to double check the init sequence a few times before I even try to debug this. I just wanted to post this in case someone cares to take a quick look for obvious errors. You know how it is when you stare at code too long and start missing things.
    CON 'Constants section
       byteclks    =    (2*8)
    VAR
        byte cog
        byte do, clk, di, cs
    PUB HOOK    ' test compile
    start_explicit( 3, 2, 1, 0 )
    PUB Stop
        if cog
            cogstop(cog-1)
        cog := 0
    PUB GetCog
        return cog
    PUB start_explicit( _DO, _CLK, _DI, _CS ) : card_type | domask, dimask, sbt
        '' save pins for later?
        do  := _DO
        clk := _CLK
        di  := _DI
        cs  := _CS
        '' prepare smartpin clock mask and bit time
        domask := getmask(clk, do)              ' bpin mask (clk)
        dimask := getmask(clk, di)
        sbt :=((clkfreq / spi_clk_max) /2 )+1   ' SPI bit time
        if sbt < 2                              ' make sure at least sysclock /2
            sbt := 2
        stop
        long[@cmd][1] := do | (clk << 8) + (di << 16) + (cs << 24)
        long[@cmd][2] := domask + (dimask << 8)     ' clock masks
        long[@cmd][3] := sbt                        ' spi bit time
        long[@cmd][4] := clkfreq                    '1s
        long[@cmd][5] := clkfreq / 100_000_000      '1us
        cog := cognew(@_asm_start,@cmd) + 1
        if cog
            repeat until long[@cmd] <> "i"  ' wait until cog is done reading parameter
            card_type := long[@cmd][1]       ' arg1 returns card type or returns with ptr to error from low level driver
        else                                  ' we don't have a cog?
            return
    PUB ReadBlock(n, b)
        return DoCommand("r", n, b, 0)
    PUB WriteBlock(n, b)
        return DoCommand("w", n, b, 0)
    PRI DoCommand(_cmd, _arg1, _arg2, _arg3)
        if cmd <> 0
          return @cogbusymsg '' busy
        arg1 := _arg1
        arg2 := _arg2
        arg3 := _arg3
        cmd  := _cmd
        repeat until cmd <> _cmd
        return err
    PRI getmask(clk, data) | t
        t := clk - data
        if ( || t ) <> t
          t := ( || t ) + %0100
    DAT org
    _asm_start      mov     ptr_to_mbox,    ptra        ' save mbox address for later
                    '' get parameters from spin
    do_init         mov     ptra,       ptr_to_mbox ' return ptra back to mbox
                    rdlong  tmp,        ptra++      ' pins long
                    mov     pinDO,      tmp
                    and     pinDO,      #$ff
                    mov     pinCLK,     tmp
                    shr     pinCLK,     #8
                    and     pinCLK,     #$ff
                    mov     pinDI,      tmp
                    shr     pinDI,      #16
                    and     pinDI,      #$ff
                    mov     pinCS,      tmp
                    shr     pinCS,      #24
                    and     pinCS,      #$ff
                    rdlong  tmp,        ptra++      'mask long
                    mov     sp_doclk,   tmp
                    and     sp_doclk,   #$f
                    mov     sp_diclk,   tmp
                    shr     sp_diclk,   #4
                    and     sp_diclk,   #$f
                    rdlong  sp_bt,      ptra++      ' timing long
                    rdlong  delay1s,    ptra++      ' 1s long
                    rdlong  delay1us,   ptra        ' 1us long
                    '' setup pins
                    drvh    pinCS
                    dirl    pinCLK      '' setup Clock pin
                    mov     tmp,        sp_clk
                    add     tmp,        sp_inv_pin  ' invert clock
                    wrpin   tmp,        pinCLK
                    wxpin   sp_bt,      pinCLK      ' set base period (*2)
                    dirh    pinCLK                  ' enable clk
                    dirl    pinDI       '' setup DI pin
                    mov     tmp,        sp_stx      ' save mode, bpin might change
                    add     tmp,        sp_diclk    ' setup bpin
                    wrpin   tmp,        pinDI       ' sync tx
                    wxpin   sp_stx_c,   pinDI       ' stop/start mode
                    dirh    pinDI                   ' enable smartpin
                    wypin   #$FF,       pinDI       ' prime shifter
                    dirl    pinDO       '' setup DO pin
                    mov     tmp,        sp_srx      ' save mode, bpin might change
                    add     tmp,        sp_doclk    ' setup bpin
                    wrpin   tmp,        pinDO       ' sync rx
                    wxpin   sp_stx_c,   pinDO       ' 8 bit, pre
                    dirh    pinDO                   ' enable pin
                    '' card init
                    drvh    pinCS                   ' set cs high
                    wypin   #initclks,  pinCLK      ' set init clocks
                    getct   timeout                 ' setup 1s timeout
                    addct1  timeout,    delay1s     ' in case card does not respond
                    mov     sd_cmd,     #0          'cmd 0,0
                    mov     sd_parm,    #0
                    call    #wait_clock             ' wait for smartpins to finish
                    call    #do_sdcmd
                    mov     sd_cmd,     #8          ' cmd 8 $1aa
                    mov     sd_parm,    #$1AA
                    call    #do_sdcmd
                    call    #read_byte                   ' read 32 bit
                    call    #read_byte
                    call    #read_byte
                    call    #read_byte
    .cmd55          mov     err_out,    ##-40
                    mov     sd_cmd,     #55         'cmd 55,0
                    mov     sd_parm,    #0
                    call    #do_sdcmd
                    mov     sd_cmd,     #41         'cmd 55,0
                    mov     sd_parm,    ##$4000_0000'
                    call    #do_sdcmd
                    cmp     data_out,   #$01    wz  ' 01 = idle
            if_z    jmp     #.cmd55
                    mov     sd_cmd,     #58          'cmd 0,0
                    mov     sd_parm,    #0
                    call    #do_sdcmd
                    call    #read_byte
                    and     data_in,    #40
                    cmp     data_in,    #0      wz
            if_z    mov     adrShift,   #9
            if_nz   mov     adrShift,   #0
                    call    #read_byte
                    call    #read_byte
                    call    #read_byte
                    mov     err_out,    #0
                    mov     sd_cmd,     #16          'cmd 0,0
                    mov     sd_parm,    ##$200
                    call    #do_sdcmd
    do_init_ret     ret
    get_cmd         rdlong  cmd_in,     ptra    wz  '
                    '' timeout and release card after 10s
            if_z    jmp     #get_cmd                'no cmd so handle time
                    rdlong  arg1_in,    ++ptra      '
                    rdlong  arg2_in,    ++ptra      '
                    rdlong  arg3_in,    ++ptra      '
                    rdlong  arg4_in,    ++ptra      '
                    cmp     cmd_in,     #"r"    wz
            if_z    jmp     #read_a
                    cmp     cmd_in,     #"w"    wz
            if_z    jmp     #write_b
    '                cmp     cmd_in,     #"z"    wz
    '        if_z    jmp    #release
                    cmp     cmd_in,     #"i"    wz
            if_z    call    #do_init
                   '' do commands
    end_cmd         wrlong  err_out,    ++ptra
                    mov     cmd_in,     #0
                    wrlong  cmd_in,     ptr_to_mbox
                    jmp     #get_cmd
    read_a          '' arg1 is sd ptr, arg2 is hub
                    mov     sd_cmd,     #17          ' cmd 8 $1aa
    '                shr     adrShift,   arg1_in    ' non-hc compatibility
                    mov     sd_parm,    arg1_in
                    call    #do_sdcmd
                    call    #read_resp
                    mov     ptrb,       arg2_in
                    rep     @.endread,  sectorsize
                    call    #read_byte
                    wrbyte  data_in,    ptrb++
    .endread
                    call    #read_byte
                    call    #read_byte
    read_a_ret  ret
    write_b         '' arg1 is sd ptr, arg2 is hub
                    mov     sd_cmd,     #24          ' cmd 8 $1aa
                    call    #do_sdcmd
                    mov     data_out,   #$fe
                    call    #send_byte
                    mov     ptrb,       arg2_in
                    rep     @.endsend,  sectorsize
                    rdbyte  data_out,   ptrb++
                    call    #send_byte
    .endsend
                    call    #read_byte
                    call    #read_byte
                    call    #read_resp
                    and     data_in,    #$1f
                    cmp     data_in,    #5      wz
        if_nz       mov     err_out,    ##-42
                    call    #sd_busy
    write_b_ret     ret
    do_sdcmd   ' OP is sd_cmd, parm = sd_parm
                    drvl    pinCS
                    call    #read_byte
                    mov     data_out,   sd_cmd
                    add     data_out,   #$40
                    call    #send_byte
                    mov     data_out,   sd_parm
                    shr     data_out,   #24
                    and     data_out,   #$ff
                    call    #send_byte
                    shr     data_out,   #16
                    and     data_out,   #$ff
                    call    #send_byte
                    shr     data_out,   #8
                    and     data_out,   #$ff
                    call    #send_byte
                    and     data_out,   #$ff
                    call    #send_byte
                    cmp     sd_cmd,     #0          wz
        if_z        mov     data_out,   #$95
        if_nz       mov     data_out,   #$87
                    call    #send_byte
                    call    #read_resp
    do_sdcmd_ret    ret
    send_byte       SHL     data_out,   #32-8       ' Set MSB First
                    REV     data_out                ' Set MSB First
                    wypin   data_out,   pinDI       ' data !!
                    rdpin   pa,         pinCLK
                    wypin   #byteclks,  pinCLK      ' start clock, tx data
                    call    #wait_clock
                    wypin   #$FF,       pinDI
    send_byte_ret   ret
    read_byte       rdpin   pa,         pinCLK
                    call    #wait_clock
                    rdpin   data_in,    pinDO       ' get data
                    rev     data_in
                    and     data_in,    #$ff
    read_byte_ret   ret
    sd_busy         call    #read_byte
                    cmp     data_in,    #0          wz
       if_z         call    #check_time
    sd_busy_ret     ret
    read_resp       call    #read_byte
                    cmp     data_in,    #$ff        wz
    read_resp_ret   ret
    check_time      pollct1                         wc
       if_c         mov     err_out,    ##-41
    '   if_c         jmp     #timed_out
    check_time_ret  ret
    wait_clock      testp   pinCLK                  wc
            if_nc   jmp     #wait_clock
    wait_clock_ret  ret
    {=== Smart pin constants ===}
    sp_clk      long    %01_00101_0
    sp_stx      long    %01_11100_0
    sp_srx      long    %00_11101_0
    sp_stx_c    long    %1_00111
    sp_srx_c    long    %0_00111
    sp_inv_pin  long    %0000_001_000_000 << 8
    adrShift    long    0    ' will be 0 for SDHC, 9 for MMC & SD
    sectorsize  long    512
    ' loaded on init
    {=== Pin Variables ===}
    pinDO       long    0    ' do
    pinCLK      long    0    ' clk
    pinDI       long    0    ' di
    pinCS       long    0    ' chip select
    {===== Smartpin Clock Variables =====}'' smartpins stuffs
    sp_doclk    long    0
    sp_diclk    long    0
    sp_bt       long    0
    {===== Command Mailbox =====}
    ptr_to_mbox res 1
    cmd_in      res 1
    arg1_in     res 1
    arg2_in     res 1
    arg3_in     res 1
    arg4_in     res 1
    err_out     res 1
    {=== Timing Variables ===}
    delay1s     res 1   ' clkfreq = 1 s
    delay1us    res 1   ' clkfreq / 100_000_000
    timeout     res 1
    {=== Temp Variables ===}
    tmp         res 1     ' this may get used in all subroutines...don't use except in lowest
    data_in     res 1
    data_out    res 1
    sd_cmd      res 1
    sd_parm     res 1
    'buff        res 299
    FIT 496
    dat         '' debug codes
    cogbusymsg  byte    "SPI Busy",0
    badpins     byte    "pins out of range",0
    dat         '' singleton spin mailbox
    alignl
    cmd     long 0
    arg1    long 0
    arg2    long 0
    arg3    long 0
    arg4    long 0
    err     long 0
    var    '' multi spin mailbox
    long  cmd, arg1, arg2, arg3, arg4, err
  • AJLAJL Posts: 524
    edited 2019-07-30 23:26
    I couldn't get your code and my comments to fit in one post, so only code relevant to my comments follows.
    In the asm init section, I don't see where do_init is used separately from _asm_start. Moving the just saved pointer back isn't really needed is it?
    Rearranging your code could allow the use of a setq+ rdlong construct to read the whole parameter block in one action. It could save some pointer maths and the code reduction will allow for the extra long needed (tmp2). Using getnib, getbyte, and getword instead of shift and mask for the slice and dice of the packed parameters is worth investigating too.
    In the clock pin setup you add two constants before the WRPIN. Why not just a single constant?
    read_byte destroys the contents of data_in on each call, so where you call it multiple times in sequence are you only interested in the last byte received?
    I've run out of time, but that's a start.
    cheezus wrote: »
    DAT org
                    mov     pinDO,      tmp
                    and     pinDO,      #$ff
                    mov     pinCLK,     tmp
                    shr     pinCLK,     #8
                    and     pinCLK,     #$ff
                    mov     pinDI,      tmp
                    shr     pinDI,      #16
                    and     pinDI,      #$ff
                    mov     pinCS,      tmp
                    shr     pinCS,      #24
                    and     pinCS,      #$ff
                    mov     sp_doclk,   tmp
                    and     sp_doclk,   #$f
                    mov     sp_diclk,   tmp
                    shr     sp_diclk,   #4
                    and     sp_diclk,   #$f
                    '' setup pins
                    drvh    pinCS
                    mov     tmp,        sp_clk
                    wrpin   tmp,        pinCLK
                    '' card init
                    mov     sd_parm,    #0
                    call    #do_sdcmd
                    mov     sd_parm,    #$1AA
                    call    #do_sdcmd
                    call    #read_byte
                    call    #read_byte
                    call    #read_byte
                    mov     sd_parm,    #0
                    call    #do_sdcmd
                    call    #do_sdcmd
            if_z    jmp     #.cmd55
                    mov     sd_parm,    #0
                    call    #do_sdcmd
                    call    #read_byte
                    and     data_in,    #40
                    cmp     data_in,    #0      wz
                    call    #read_byte
                    call    #read_byte
                    call    #read_byte
                    mov     err_out,    #0
                    mov     sd_parm,    ##$200
                    call    #do_sdcmd
    do_init_ret     ret
                    cmp     cmd_in,     #"r"    wz
            if_z    jmp     #read_a
                    cmp     cmd_in,     #"w"    wz
            if_z    jmp     #write_b
    '        if_z    jmp    #release
                    cmp     cmd_in,     #"i"    wz
            if_z    call    #do_init
                   '' do commands
                    mov     cmd_in,     #0
                    jmp     #get_cmd
                    call    #do_sdcmd
                    call    #read_resp
                    mov     ptrb,       arg2_in
                    call    #read_byte
    .endread
                    call    #read_byte
                    call    #read_byte
    read_a_ret  ret
                    call    #do_sdcmd
                    mov     data_out,   #$fe
                    call    #send_byte
                    mov     ptrb,       arg2_in
                    call    #send_byte
    .endsend
                    call    #read_byte
                    call    #read_byte
                    call    #read_resp
                    and     data_in,    #$1f
                    cmp     data_in,    #5      wz
                    call    #sd_busy
    write_b_ret     ret
                    drvl    pinCS
                    call    #read_byte
                    add     data_out,   #$40
                    call    #send_byte
                    shr     data_out,   #24
                    and     data_out,   #$ff
                    call    #send_byte
                    shr     data_out,   #16
                    and     data_out,   #$ff
                    call    #send_byte
                    shr     data_out,   #8
                    and     data_out,   #$ff
                    call    #send_byte
                    and     data_out,   #$ff
                    call    #send_byte
                    cmp     sd_cmd,     #0          wz
                    call    #send_byte
                    call    #read_resp
    do_sdcmd_ret    ret
                    rdpin   pa,         pinCLK
                    call    #wait_clock
                    wypin   #$FF,       pinDI
    send_byte_ret   ret
                    call    #wait_clock
                    rev     data_in
                    and     data_in,    #$ff
    read_byte_ret   ret
                    cmp     data_in,    #0          wz
    sd_busy_ret     ret
    read_resp_ret   ret
    check_time_ret  ret
    wait_clock_ret  ret
    sectorsize  long    512
    ' loaded on init
    pinDO       long    0    ' do
    pinCLK      long    0    ' clk
    pinDI       long    0    ' di
    sp_doclk    long    0
    sp_diclk    long    0
    sp_bt       long    0
    ptr_to_mbox res 1
    cmd_in      res 1
    arg1_in     res 1
    arg2_in     res 1
    arg3_in     res 1
    arg4_in     res 1
    err_out     res 1
    timeout     res 1
    data_in     res 1
    data_out    res 1
    sd_cmd      res 1
    sd_parm     res 1
    'buff        res 299
    FIT 496
    dat         '' debug codes
    alignl
    cmd     long 0
    arg1    long 0
    arg2    long 0
    arg3    long 0
    arg4    long 0
    err     long 0
  • @AJL, Thanks for taking a look. I've got a bunch of problems in my code above... The first I found was I was missing a dummy rdlong at the beginning of my init. I also am packing the clock pin masks wrong. There's also something ?else? wrong because I'm outputting clock but still not getting data.
    Re. init -
    This is one I'm not 100% sure how I want to do. I'd like to be able to change sysclock or pins by restarting the cog (it's called from get_cmd) I could probably get away with one entry point but was even thinking about separating the timing stuff from pin stuff but going to leave it like this for now I think.
    re. setq + rdlong -
    This is one improvement I'm going to look at once I have things working. That goes for the getnib / setnib instructions, just not quite there yet. Trying to stay as close to what I know..
    The extra constant for the clock pin inverts it and I plan on having a switch somewhere to control the polarity of the clock, as well as set default max SPI clock. Just haven't been able to get my head around that yet.
    Read_byte trashes data_out and most of the time I'm not interested in any of the data.
  • I'm stumbling my way through, found all kinds of errors.. I'm stuck on the conversion of readblock… It took me a while to figure out what is going on and it seems like I'm trashing the call stack? I believe it's because of my use of CALLs and JMPs. I'm missing the obvious and correct way of conditional repeat. Spin code is this.
    pri readresp | r
       repeat
             return r
          if checktime == -41
            return -41
    When I was trying to convert it to ASM I had a feeling this wouldn't work.
       if_z         jmp     #read_resp
    read_resp_ret   ret
    I'm completely stuck right now and i'm pretty sure this is the problem.
    edited 2019-07-31 07:59
    Scratch that, seems the problem is REP is not working :neutral: I noticed this while trying to use the output of fastspin to help guide me. For some reason, this is not repeating 512 times, just falling through. I know there was a bug with the REP instruction but I can't remember what it was exactly. I think I'm just doing something wrong.
                    mov     ptrb,       arg2_in
                    rep     @.endread,  ##512
                    call    #read_byte
    .endread
                    call    #read_byte
                    call    #read_byte
    *edit
    CONFIRMED. I tried a couple different things but couldn't get rep to work??? I have it working inline ASM but not in actual asm! RTFM!!
    I was able to get it working and now the SD card mounts!
    .loop           call    #read_byte
                    djnz    count,       #.loop
    I need to cleanup code and do some testing to make sure things are stable but I think I'm close!!
    edited 2019-07-31 07:42
    You can't jump or call within a rep
    REP works in hub memory, as well, but executes a hidden jump to get back to the top of the repeated instructions.
    Any branch within the repeating instruction block will cancel REP activity. Interrupts will be ignored during REP looping.
  • You can't jump or call within a rep
    DUH!!! Thanks Peter, feeling kinda silly now :smile: All these new instructions, all new gotchas!
  • evanhevanh Posts: 17,011
    That's a normal REP rule. The CALL counts as an exit branch from the REP mechanism. Another rule is any exit branching can't be the last instruction of the REP block. Another rule is interrupts are put on hold until the REP completes/exits.
    The flaw (Corrected in the final silicon) is to do with a group of branching instructions that test the hardware events mechanism, eg: JCT1.
    edited 2019-07-31 13:45
    Thanks guys! I'm getting close, just got to nail down block writes! Once I get that done I'll try to clean up code and post. A quick benchmark (since I don't have writes yet and can't run the full test) for mounting a card is 4.57ms bit-bashed inline asm, 4.04ms inline asm smartpins and 2.33ms smartpins in their own cog. These were all @160mhz sysclock and 20mhz spi clock. Note, my LA can't keep up with 20mhz SPI. :smile:
    Interestingly enough, the bit-bashed command packet is 2nd to complete although it's the all out loser in final times.
    Bit - bashed SPI
    Smartpins inline
    Smartpins cog
    *edit
    Got block writes working so was able to come up with a full set of test times. To mount the card, read and write 2m.
    inline asm bit-bashed-19.5s
    inline asm smart-pin-14s
    cog smart-pin-10.9s
    I'll give the code a quick cleanup, now that I've got everything working including clock polarity. There's a lot of places to improve still. I'd like to figure out a way to determine max spi clock at init, although I really can't wrap my head around any way besides brute-force init card and increase speed till it fails. Maybe I'm missing something obvious as usual. Really happy I have this working though.
    *final edit
    I did some code cleanup and have just about everything where I want it. I'm posting a NEW RC3 here and once things are tested further I'll update the first post.
    1920 x 1080 - 126K
    1920 x 1080 - 128K
    1920 x 1080 - 126K
  • Still testing RC3 posted above. I've got a bunch of work left to do but it's fairly functional AFAIK. I'm wondering if anyone can give me a reason why it would be better to return a negative error code, as opposed to aborting? I'm probably going to re-write with aborts, as V1 used. Just wondering if anyone has a good argument against aborts?
  • RaymanRayman Posts: 15,899
    I don’t like abort
    Seems like unnecessary complexity to me
  • Rayman wrote: »
    I don’t like abort
    For some cases I can see how it could be considered unnecessary but I'm working on the Touchscreen OS again and aborts seem really helpful for SD cards. The ability to point to an error message, instead of needing to do a lookup on an error code. Six of one, half dozen of the other... I guess it could be done with conditional compile and would be the best, because a lot of P1 apps expect negative return type errors from FSRW. I really like how verbose Kye's SD driver is, plus it would be nice to not need to rewrite the ENTIRE touch.spin.
    As I said, I really like Kye's driver and have pretty much talked myself into trying to get the genius piece of code working. One of the functions that is very essential to the OS is the ability to launch a file from SD card and it seems that @Cluso99 's on-chip SD could do this with little additional code. I just haven't wrapped my head around that yet. In the past I had commented out large portions of Kye's driver to free up memory but now that we have enough hubram I'm hoping to be able to do BIG THINGS much easier.
    Perhaps the title of this thread should be changed to cover both FSRW and KYE's SD?
    Kye’s SD driver is great. It’s easy to follow. I added a few extras such as returning the physical sector etc.
    From a users perspective the names are too long, but makes understanding what its doing a breeze.
    This is one of the reasons i wanted to get the Spin1 interpreter working with P2. But i got sidetracked near the end with work and haven’t managed to get back to it yet.
    FWIW the ROM SD code, with the addition of write, and tweeking the actual spi routine, this should slot into Kye’s code nicely.
  • Cluso99 wrote: »
    Kye's driver is great and the Touch OS is based largely on your OS based on Kye's SD driver :smiley: I really wish I could wrap my head around how to interface cleanly with the ROM SD code. I know I'm probably just making it harder than I need to.
    The main reason I didn't focus on using the ROM code was needing to understand SPI on the P2 a little better.
    I'm stuck needing a driver for the resistive touch ADC XPT2046. Going to try modifying SDSPI for this. Once I get that done I'll be able to test a lot more, although I'm sure there will be a ton of debugging and bugfixes.
    One of the things that looks really promising is LUT sharing. IE, read block from sd using CogN into shared LUT and use CogN+1 to push that block to display (or ram/flash). CogN could be reading the next block while N+1 is writing the current block. Seems like this could save a TON of hubcycles over the way things are done on the P1. I don't see myself getting around to this any time soon since I'm not sure how other people would be able to use such a specific driver.
    I'm hoping to try using the rom to run a file, how many times can I get this one wrong? lol
    I updated the 1st post with the current RC and some RC notes. I really wish I was better at documentation but until I get some feedback from people using this it seems pointless. I'm guessing right now there isn't much need for a P2 FSRW or Kyes, but that will change soon hopefully!
    Really hoping the new silicon doesn't break things too much, hopefully worst case is change smartpin clock from sysclock /2 to /3 or /4. Time will tell though!
    @cheezus,
    Note the ES ROM has some fixes in the respin ROM to better recover from the SD DO problem which fails to release the DO drive from the SD card. This means the SD ROM code positions change in the new ROM. The Serial Monitor/Debugger did not change position so this is fine to call.
    Second thing to note is that the SD ROM code (routine) to drive the SPI code is deliberately not fast to ensure it works reliably from hubexec. It has send/receive combined ie it shifts in (reads) as it shifts out (writes).
    The code in the new ROM is way better in the DO error handling, so this is what I will be using as a base for my SD (if you or others haven't done it when I need it), with just the write sector added, and the SPI send/receive routine replaced with a faster version.
    BTW there is IIRC a single further fix for the DO that did not make it into the new ROM, so I will need to dig it out. I am overseas for another 2 weeks so that will have to wait.
  • Cluso99 wrote: »
    @cheezus,
    I've looked at the first ROM code quite a bit. It's beautiful, but I was planning on having a cog just for the SD driver so hubexec is what got me confused. I was also aware of the changes for the respin, another reason I haven't worked on this. I would have liked to build a driver around it but figured you would be doing one (using hubexec) so focusing on something that could be stuffed in a cog like P1. FSRW is a bare minimum driver and so my focus on early development. Soon I'll need a way to run a precompiled binary and if I can figure out how to copy the filename to the right place in hub and jmp into the hubexec code I'll be really happy.
    I don't have time to verify just now, but this is what you need to know
                       '+-------[ SD: Initialise/Locate/Load/Run a file from SD ]---------------------+ <--- SD: init/locate/load/run a file --->
                       '+ On Entry:        +
                       '+      fname[3]:       filename[11] 8+3 without "."  (will be $0 terminated)  +
                       '+ Call Format:        +
                       '+              CALL    #@_Run_SDfile                   '                      + < call: init/locate/load/run a file >
                       '+ On Return:        +
                       '+      "NZ" if error, else does not return                                    +
    fc560     fdb00040 _Start_SDcard   call    #@_SDcard_Init                  ' initialise & read CSD/CID
    fc564     f6079a00                 mov     skiprun,          #0            ' load/run MBR/VOL code
    fc568     adb00174         if_e    call    #@_readMBR                      ' read MBR/VOL/FSI/FAT
    fc56c     adb002a0         if_e    call    #@_readDIR                      ' read directory for filenames
                       ''              mov     skiprun,          #0            ' load/run <file> (already 0)
    fc570     adb0038c         if_e    call    #@_readFILE                     ' read/load/run the file
    fc574     fd800100                 JMP     #try_serial                     ' failed: so go back and try serial
    fc578     fdb00028 _Run_SDfile     call    #@_SDcard_Init                  ' initialise & read CSD/CID
                       ''              mov     skiprun,          #1            ' do not load/run MBR/VOL code
    fc57c     adb0015c         if_e    call    #@_readMBR1                     ' read MBR/VOL/FSI/FAT (don't run)
    fc580     adb002bc         if_e    call    #@_searchDIR                    ' search dir for <fname>
    fc584     f6079a00                 mov     skiprun,          #0            ' load/run <file>
    fc588     adb00374         if_e    call    #@_readFILE                     ' read/load/run the file
    fc58c     fd64002d                 RET                                     ' return "NZ" = failed, "Z" if loaded ok
    fc590     fdb00010 _Load_SDfile    call    #@_SDcard_Init                  ' initialise & read CSD/CID
    fc594     adb00144         if_e    call    #@_readMBR1                     ' read MBR/VOL/FSI/FAT (don't run)
    fc598     adb002a4         if_e    call    #@_searchDIR                    ' search dir for <fname>
                       ''              mov     skiprun,          #1            ' do not load/run <file> (already 1)
    fc59c     adb00360         if_e    call    #@_readFILE                     ' read/load the file
    fc5a0     fd64002d                 RET                                     ' return "NZ" = failed, "Z" if loaded ok
    and
                       DAT
                       ''============[ COG VARIABLES - SD BOOT]========================================
    fc560 1c0                          org     $1C0              ' place the variables in cog $1C0-$1DF
    fc560 1c0          cmdout          res     1                       ' The 8b CMDxx | $40
    fc560 1c1          cmdpar          res     1                       ' The 32b parameters
    fc560 1c2          cmdcrc          res     1                       ' The 8b CRC (must be valid for CMD0 & CMD8)
    fc560 1c3          cmdpar2         res     1                       ' SDV1=$0, SDV2=$40000000
    fc560 1c4          cmdtype         res     1                       ' reply is R1=1, R3=3, R7=7, else 0
    fc560 1c5          reply           res     1                       ' R1 reply (moved to replyR1 when R3/R7 32b reply here)
    fc560 1c6          replyR1         res     1                       ' R1 reply (8b saved when R3/R7 32b reply follows)
    fc560 1c7          dataout         res     1                       ' 8/32 bit data being shifted out
    fc560 1c8          bytescnt        res     1                       ' #bytes to send/recv
    fc560 1c9          bitscnt         res     1                       ' #bits to be shifted in/out
    fc560 1ca          ctr1            res     1
    fc560 1cb          timeout         res     1                       ' = starttime + delay
    fc560 1cc          spare           res     1
    fc560 1cd          skiprun         res     1                       ' 1= skip load/run mbr/vol & load/no-run fname
        '\ 1=SDV1, 2=SDV2(byte address), 3=SDHC/SDV2(block address)
    fc560 1ce          blocksh         res     1                       '/ block shift 0/9 bits
    fc560 1cf          clustersh       res     1                       ' sectors/cluster SHL 'n' bits
    fc560 1d0          vol_begin       res     1 '$0000_2000           ' Ptn0: first sector of PTN
    fc560 1d1          fsi_begin       res     1 '$0000_2001           ' Ptn0:       sector of file system info
    fc560 1d2          fat_begin       res     1 '$0000_3122           ' Ptn0: first sector of FAT table
    fc560 1d3          dir_begin       res     1' $0000_4000           ' Ptn0: first sector of DATA is DIR table
    fc560 1d4          dat_begin       res     1 '$0000_4580 $0000_54C0' Ptn0: first sector of file's DATA
    fc560 1d5          ptn_size        res     1 '$0008_0000           '       file-size 32KB = 64<<9 sectors
    fc560 1d6          _bufad          res     1
    fc560 1d7          _blocknr        res     1
    fc560 1d8          _sectors        res     1
    fc560 1d9          _entries        res     1
    fc560 1da          bufad           res     1                       ' ptr sector buffer
    fc560 1db          blocknr         res     1                       ' sector#
    fc560 1dc          fname           res     3                       ' 8+3+1
    fc560 1df          _hubdata        res     1
    In your code...
    cog $1C0-$1DF is required for use by the SD ROM driver
    Place the filename (8+3+$0) into 3 longs at fname (cog $1DC) (remember little endian so reverse each group of 4 characters!)
    So "filename.xtn" would become "elif" + "eman" + ($0,"ntx")
    Call _Load_SDfile
    Call _Run_SDfile
    edited 2019-08-11 00:22
    I'm working on this again and I think I'm getting ready for another release. I need to verify all my changes are correct first but it looks much nicer now that I'm using the getbyte instructions. There's a couple uglies left maybe someone can point to the CLEAN way to do this.
    ... ' ex1
    … 'ex2
                    rev     data_in
                    and     data_in,    #$ff
    read_byte_ret   ret
    I also need to use all the new test instructions but I think I can get those :wink: SPI smartpin setup looks like this now
        stop
        long[@cmd][1] :=  _DO | (_CLK << 8) + (_DI << 16) + ( _CS << 24)' pins
        long[@cmd][2] := getmask(_CLK, _DO) + (getmask(_CLK, _DI) << 4) ' clock masks
        long[@cmd][2] += spi_clk_inv << 8                                 ' clock invert
        long[@cmd][3] := GetBitTime(spi_clk_max)                        ' spi bit time
        long[@cmd][4] := GetBitTime(400_000)                            '400k
        if cog
            card_type := long[@cmd][4]       ' arg5 returns card type or returns with ptr to error from low level driver
    DAT org
                    rdlong  tmp,        ptra++          ' command long 0
                    rdlong  tmp,        ptra++          ' pins long    1
                    getbyte pinDO,      tmp,    #0
                    getbyte pinCLK,     tmp,    #1
                    getbyte pinDI,      tmp,    #2
                    getbyte pinCS,      tmp,    #3
                    rdlong  tmp,        ptra++          'mask long      2
                    getnib  sp_doclk,   tmp,    #0
                    getnib  sp_diclk,   tmp,    #1
                    getnib  sp_inv_pin, tmp,    #2
                    shl     sp_doclk,   #24
                    shl     sp_diclk,   #24
                    shl     sp_inv_pin, #14
                    rdlong  sp_bt,      ptra++          ' timing long   3
                    rdlong  sp_init_bt, ptra            ' 400k          4
                    rdlong  delay1s,    #$14            ' clkfreq from hub
                    '' setup pins
                    drvh    pinCS
                    mov     tmp,        sp_clk
                    wrpin   tmp,        pinCLK
                    wxpin   sp_init_bt, pinCLK      ' set base period (*2)
                    '' card init
                    wypin   sectorsize, pinCLK      ' set init clocks
    I think the fifo could help in the readbyte and writebyte but haven't wrapped my head around that yet.
    I'm ready to try getting this runfile thing sorted and I THINK understand things pretty well. I'm about to start renaming some of my variables to match the convention laid out by @Cluso99. Not that there's a shortage of cogram yet with 237 longs left...
    The other thing that I've been trying to wrap my head around is the LUT sharing.. Seems that YModem would really benefit from being able to load the LUT with 1k from the SD and then the ASync serial cog could just use a shared LUT bypassing the hub. I would also like to do this with my RAM/Display driver i'm working on and it seems probable, it would need some convention to be set with the objects that share the adjacent cog.
  • Packing the mask long into nibbles instead of bytes doesn't really gain anything.
    How about something like this using bytes:
    DAT org
                    rdlong  tmp,        ptra++          ' command long 0; not used
                    rdbyte pinDO,      ptra++         ' pins long 1
                    rdbyte pinCLK,     ptra++
                    rdbyte pinDI,       ptra++
                    rdbyte pinCS,      ptra++
                    rdlong sp_doclk,        ptra              ' mask long 2
                    getbyte  sp_diclk,   sp_doclk,    #1
                    getbyte  sp_inv_pin, sp_doclk,    #2
                    shl     sp_doclk,   #24
                    shl     sp_diclk,   #24
                    shl     sp_inv_pin, #14
                    '' setup pins
    Slightly smaller memory footprint, and saves double handling the data when it isn't necessary.
    edited 2019-08-11 09:52
    AJL wrote: »
    DAT org
                    shl     sp_doclk,   #24
                    shl     sp_diclk,   #24
                    shl     sp_inv_pin, #14
                    '' setup pins
    I'm packing into nibbles so I have extra bits later if I need them. Not real sure HOW to use them yet so it might be a waste. I was thinking about different ways I could do this and I really wanted it to all fit into the mailbox. I finally got the init sequence the way I wanted, with all of the parameters being loaded by the normal command loop.
    DAT org
    [code]
    DAT
                    org
            if_z    jmp     #get_cmd                            ' no cmd so handle time
                    rdlong  err_out,        ++ptra              ' dummy read to align err pointer
                    '' decode command
                    cmp     cmd_in,         #"i"    wz
            if_z    jmp     #do_init
                    cmp     cmd_in,         #"c"    wz
            if_z    call    #card_init
                    cmp     cmd_in,         #"r"    wz
            if_z    jmp     #read_a
                    cmp     cmd_in,         #"w"    wz
            if_z    jmp     #write_b
    '        if_z    jmp    #release
                    mov     err_out,        #5                  ' err = no command                 '
                   '' do commands
    end_cmd         drvh    pinCS                               ' set cs high
                    wrlong  err_out,        ptra
                    mov     cmd_in,         #0                  ' signal done to spin driver
                    jmp     #get_cmd
    do_init         getbyte pinDO,          arg1_in,    #0
                    getbyte pinCLK,         arg1_in,    #1
                    getbyte pinDI,          arg1_in,    #2
                    getbyte pinCS,          arg1_in,    #3
                    getnib  sp_doclk,       arg2_in,    #0
                    getnib  sp_diclk,       arg2_in,    #1
                    getnib  sp_inv_pin,     arg2_in,    #2
                    shl     sp_doclk,       #24
                    shl     sp_diclk,       #24
                    shl     sp_inv_pin,     #14
                    mov     sp_bt,          arg3_in             ' get max clock
                    mov     sp_init_bt,     err_out             ' get 400k clock
                    mov     err_out,        #0                  '  err = no error
                    mov     spare,          ##sp_clk            ' transition
                    add     spare,          sp_inv_pin          ' invert clock
                    wrpin   spare,          pinCLK              ' set clock mode
                    mov     spare,          ##sp_stx            ' sync tx
                    add     spare,          sp_diclk            ' setup bpin
                    wrpin   spare,          pinDI               ' set di mode
                    wxpin   #sp_stx_c,      pinDI               ' set di config
                    mov     spare,          ##sp_srx            ' sync rx
                    add     spare,          sp_doclk            ' setup bpin
                    wrpin   spare,          pinDO               ' set do mode
                    wxpin   #sp_srx_c,      pinDO               ' set do config
                    call    #card_init
                    jmp     #end_cmd
    I'm pretty happy with this although the memory footprint is a little wasteful, with cluso's variables in cog. I could probably squeeze out a few cog longs but it's getting there.
    I keep thinking about ways to deal using the LUT and I've got a proposal. Instead of passing a positive number for the hub address for block read/write, if you pass a negative number it will be loaded to LUT. This would give us 4 pages, I just need to figure out how to handle loading cog2 and doing something with the data. Since the LUT can't be accessed in bytes like the cogram can, i'm not sure how much more efficient packing bytes into longs and copying to LUT will be. I think that's the next step though.
    I did separate the SD card init from pins init, to allow mounting of cards without resetting pins. I need to setup commands for this, as well as handle release properly. I also want to implement an auto-release timeout too, just need to try to implement it.
  • shorten this up.
        cmd := "i"   'set flag to know if the started cog has read its parameters
        cmd[1] :=  _DO | (_CLK << 8) + (_DI << 16) + ( _CS << 24)' pins
        cmd[2] := getmask(_CLK, _DO) + (getmask(_CLK, _DI) << 4) ' clock masks
        cmd[2] += spi_clk_inv << 8                                 ' clock invert
        cmd[3] := GetBitTime(spi_clk_max)                        ' spi bit time
        cmd[4] := GetBitTime(400_000)                            '400k
    edited 2019-08-11 10:16
    I'm going to release RC4 here, it's a major code cleanup. I tried to use all the instructions where applicable. Things clean up nicely this way. I know that with 3 operand instructions vs 2 regular instructions it's only readability but still, I LOVE P2ASM!!!!
    I'm also including Ymodem with this release, although it appears receive is broken. I think it's baud related, or maybe it's a buffer overflow issue since smartpin serial isn't buffered? I'd think that would show up as a problem sending a file TO the sd card?? I'll debug that as soon as I'm done with this SD driver
    I updated the above code blurbs to reflect the new versions. Now that I've got cog variables cleaned up a bit and I'm getting ready to try to run a file I have a couple final questions. First to verify the file that is renamed and placed on card is the .EEPROM file created? (?duh?) Most important, if I create a constants section with the rom hook addresses... what's the proper JMP convention? I'm SOOOO lost on that part!
    DAT
            jmp     #$FC578     'jump into rom code?
    CON P2_REVa_ROM_ADDRESS_TABLE
      _Start_SDcard    = $FC560
      _Run_SDfile      = $FC578
      _SDcard_Init     = $FC5A4
      readFILE         = $FC900
      search_dir       = $FC840
      _reset_booter    = $FCA78
      _Start_Monitor   = $FCA88
      _Enter_Monitor   = $FCA8C
      _Redo_Monitor    = $FCA9C
      _SerialAddr      = $FCAA8
      _SerialBaud      = $FCAB0
      _SerialInit      = $FCAB8
      _HubTxCR         = $FCAE4
      _HubTxRev        = $FCAEC
      _HubTx           = $FCAF0
      _HubRx           = $FCB10
      _HubHexRev       = $FCB24
      _HubHex8         = $FCB28
      _HubHex          = $FCB2C
      _HubTxStrVer     = $FCB9C
      _HubTxString     = $FCBA4
      _HubListA2H      = $FCBC4
      _HubList         = $FCBC8
      _RdLongCogHub    = $FCF34
      _HubRxStrMon     = $FCCC4
      _HubRxString     = $FCCCC
      _HubMonitor      = $FCD78
      _Download        = $FCEA4
      _ParseHex        = $FCF68
    I'm also thinking about the whole pushing data to LUT. I guess as far as raw performance goes it would help to use the FIFO, so I should probably start reading up on that... LUTS seems like the way to go, although if you have to pack / unpack bytes it might not be as efficient? It would be wasteful to only get one block read/write into luts and I think it would also kinda defeat the purpose?!?
    *edit
    Thanks for the suggestion @msrobots, here's the updated version. I made the change to the release real quick.
        stop
        arg1 :=  _DO | (_CLK << 8) + (_DI << 16) + ( _CS << 24)' pins
        arg2 := getmask(_CLK, _DO) + (getmask(_CLK, _DI) << 4) ' clock masks
        arg2 += spi_clk_inv << 8                               ' clock invert
        arg3 := GetBitTime(spi_clk_max)                        ' spi bit time
        err := GetBitTime(400_000 )                            '400k
        if cog
            repeat until cmd <> "i"     ' wait until cog is done reading parameter
    Still looking for "fixes" for these -
    ... ' ex1
    … 'ex2
                    rev     data_in
                    and     data_in,    #$ff
    read_byte_ret   ret
