Anyone used SETPAT & WAITPAT ?
Cluso99
in Propeller 2
I expected this to fall straight thru with either MODCZ (not sure which way round the Z works for ==)
But neither fall thru'.
waitx ##_clockfreq
mov match,inb
and match,mask
' modcz _set,_clr ' C & NZ ' INB
modcz _set,_set ' C & Z ' INB
setpat mask,match
waitpat
match long $00000000
mask long $C0000000
Obviously I am missing something, but what???
Hmm, is the users intention not already clear and unambiguous ?
That will be it!
A trigger event is required to fire the waitpat.
I thought with the P1 that a waitpeq/waitpne would pass immediately if the condition was met.
mov match,inb and match,mask xor match,mask ' invert the SI=P31 pin ' modcz _clr,_set wcz ' NC & Z (INA & D) == S ' modcz _clr,_clr wcz ' NC & NZ (INA & D) != S modcz _set,_set wcz ' C & Z (INB & D) == S ' modcz _set,_clr wcz ' C & NZ (INB & D) != S setpat mask,match waitpat ' wait for activity on SI=P31Docs say
Set pin pattern for PAT event. C selects INA/INB, Z selects =/!=, D provides mask value, S provides match value.
ie the mask in D, should not need the match also masked elsewhere ?
Not quite; the instruction doesn't really say which of c and z should be updated (c, z, or both).
However, if neither is updated that's probably a bug. fastspin will issue a warning in this case. I don't think PNut warns about it, but perhaps that would be a useful addtion.
This is the test done for the event (C and Z are flag states and D and S are register values from when SETPAT executed):
event = (((C ? INB : INA) & D) == S) ^ !Z
ie if you are looking for a value, and that value exists prior to performing the waitpat, then waitpat never returns.
I don’t think the P1 works this way. It just tests to see if the condition is met.
Totally. WAITPEQ and WAITPNE
Actually, for the 360 feedback servo, I have to measure a high period and the following low period. So on P1, I do a WAITPxx for a low, followed by a WAITPxx for a high to be certain I am measuring the whole high period (followed by another WATPxx for the end of the high period, etc). Basically, I am LOOKING for edges, so the P2 should work out better. Plus I think I can implement a timeout for the case where the servo died without feedback.
There is a state-measuring smart pin mode that alternately measures high and low times, without missing a clock.
So that means it is edge activated, and is triggered on a change-to moment ?
That would need to be made clear in the DOCs
Sounds great for Duty capture to high precision, on a single smart pin. Which mode is that ?
So to do what WAITPNE did on the P1 I have to
mov match,INA and match,mask modcz _clr,_clr setpat mask,match waitpatAnd what if INA changes just in between the mov and the setpat? Then waitpat will wait although the condition I want to wait for is already met? Looks like a major design flaw. What is the recommended workaround?No problem, I can do everything I need with both possibilities. I just have to know. The docs are not clear about this.
the P1 equivalent of what you have is
The P1 suffers from the same issue, but more sysclocks occur between the read and wait on the P1.
But why use that sequence? The wait instructions automatically perform the AND between INx and the mask.
So, preconditioning the flags and then executing the wait with the mask is sufficient if the mask eliminates the irrelevant bits from consideration.
My understanding is that each cog can only wait on INA or INB, not both at the same time.
The major P2 difference is that you can set up the match (or not) conditions and poll the comparison flag while doing other work, with pollpat.
Correct me if I'm wrong, but as I've read Chip's statement there is a fundamental difference. On the P1 WAITPEQ/PNE is level sensitive. If the condition is already met then it doesn't wait. On the P2 WAITPAT is edge sensitive. A transition from false to true is required to trigger end-of-wait. If the condition is already met before SETPAT has beed executed no event is generated and WAITPAT waits forever.
For all operations like interrupt triggering, pulse counting etc. it always important not to miss an event. A "blind spot" during setup of the wait condition is something to avoid.
Because Chip said it's required: The & is performed first, then the comparison (==). If it was the other way round then the & wasn't neccessary.
I share that feeling but to know for sure it would be good if Chip could confirm this.
Your code doesn't need to perform the '& INx' in advance of the WAITPAT:
The SETPAT defines the conditions for the event detection circuitry, which then continually performs the '& mask' and comparison to determine whether to set the event flag.
If it is critical for level sensitivity, then you would replace the SETPAT / WAITPAT sequence with a mask and compare loop.
Untested code:
REP 4, #0 ALTR masked AND mask, INA CMP match, masked wz TJNZ continue 'TJNZ for WAITPNE, TJZ for WAITPEQAn alternative for WAITPEQ operation, if you have a pin to spare, would be to set up a smartpin in NCO frequency mode such that IN toggles as fast as possible and then include it in the mask for SETPAT. This guarantees that even if the condition of interest already exists, a change occurs which triggers the event within two NCO base periods, preventing a stall.
Untested, but something like:
