Prop C Build Errors
in Propeller 1
I am currently having issues with Simple IDE. The build appears to be failing at the very end of the build sequence. Does anyone know what the problem is? Done. Build Succeeded! proploader.exe -r -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b rcfast -p COM3 cmm/Welcome.elf Opening file 'cmm/Welcome.elf' ERROR: Download failed: -1 Opening file 'cmm/Welcome.elf' ERROR: Download failed: -1
And, if you can ZIP-up the project (Project menu's ZIP menu item will do this for you) and attach it to a post, forum folks can better help you.
dgately
ESD is the only thing I haven't been actively trying to avoid, and it seems this could have caused the chip's early demise. The other theory is that my 12 V motor control circuit needs to be on a different power source than my processor. So I am going to try to do that too.
