ADC Sampling Breakthrough - Page 35 — Parallax Forums
1323335373852
  • cgracey wrote: »
    TonyB_ wrote: »
    To make things more clear, if window function is y = ƒ(t) then
    delta = dy
    inta = y
    intb = inty = ∫ydt
    We could even go a level deeper and define the filter by only six points:
    (1) initially from Y=0, begin upwards acceleration (+1)
    (2) at the inflection point of the filter rise, begin upwards deceleration (-1)
    (3) at the start of the plateau when delta is now zero, cancel acceleration (0)
    (4) at the end of the plateau, begin downwards acceleration (-1)
    (5) at the inflection point of the filter fall, begin downwards deceleration (+1)
    (6) at the end of the filter when Y and delta are now 0, cancel acceleration (0)
    It would take only two parameters to define the filter:
    a) the acceleration/deceleration period for filter rise and fall
    b) the plateau period
    With a few more bits of resolution, we could dial it in much better than we have been.
    What if we set min and max dy values? 0 <= |dy| <= 3
    TonyB_ wrote: »
    I compiled the simplified algorithm per Saucy's recommendation and it works great. It cut 18 ALMs from each smart pin.
    Here is what the code looks like now. It's just amazing how much this has been simplified:
    I think we've had separate savings of 34, 10 and now 18 ALMs, with a logic increase between the second and third. At one time it was 80+ ALMs per smart pin.
    I'll look at modifying the BASIC program for shift register skipping to allow a single set of 12 taps later this afternoon.
    Okay. That would be great. Remember they just have to sum to 2040..2047, preferably a single value.
    TonyB_, I have one interesting development. By making the side lobes longer on the largest filter, I think it really cut noise down.
  • cgracey wrote: »
    TonyB_ wrote: »
    I have the two Tukeys sharing the same taps in BASIC. It half worked first time and completely second time. I'll do the Hann, which won't be quite the same as now, then post the program.
    Is this a change or an observation? And side lobes means side lobes, not ramps?
    TonyB_ wrote: »
    TonyB_ wrote: »
    I mean that on the longest filter, the ramp-up and ramp-down are longer.
  • TonyB_TonyB_ Posts: 2,279
    edited 2018-12-15 15:17
    Hann working, will post code soon. Slight logic saving if delta left shifted before adding to inta. Tap skipping:
    Tukey45
    tap[10] -> tap[13]
    tap[31] -> tap[51]
    tap[56] -> tap[59]
    Hann30
    tap[10] -> tap[13]
    tap[16] -> tap[18]
    tap[18] -> tap[51]
    tap[51] -> tap[53]
    tap[56] -> tap[59]
    Blackman22
    tap[8]  -> tap[13]
    tap[13] -> tap[16]
    tap[16] -> tap[18]
    tap[18] -> tap[51]
    tap[51] -> tap[53]
    tap[53] -> tap[56]
    tap[56] -> tap[61]
    Tap register is reset when filter mode changes
    First taps skipped in skip sequence shift in 0
    EDIT:
    Add Blackman22 window.
    edited 2018-12-14 20:47
    BASIC program with tap skipping:
    a = 2: b = 3: c = 8: d = 33 'All windows
    m = 1 'Tukey68
    'm = 2 'Tukey45
    'm = 4 'Hann30
    'm = 8 'Blackman22
    t0 = 0
    t1 = t0 + a
    t2 = t1 + b
    t3 = t2 + c
    t4 = t3 + b
    t5 = t4 + a
    t6 = t5 + d
    t7 = t6 + a
    t8 = t7 + b
    t9 = t8 + c
    t10 = t9 + b
    t11 = t10 + a
    print "taps", t0, t1, t2, t3, t4, t5, t6, t7, t8, t9, t10, t11
    print
    dim t(70)
    for x = 0 TO 70: t(x) = 0: next x 'clear bits
    inta = 0
    intb = 0
    print "iter", "delt", "inta", "intb", "samp"
    for y = 0 TO 70 * 2 - 1
      for x = 70 TO 1 step -1
        'Tukey68
        if m = 1 then t(x) = t(x - 1)
        'Tukey45
        if m = 2 then
          if x <= 10 or (x > 13 and x <= 31) or (x > 51 and x <= 56) or x > 59 then
            t(x) = t(x - 1)
          end if
          if x = t3 then t(x) = t(t3 - 3): ' t(13) = t(10)
          if x = t6 then t(x) = t(t6 - 20): 't(51) = t(31)
          if x = t8 + 3 then t(x) = t(t8): ' t(59) = t(56)
        end if
        'Hann30
        if m = 4 then
          if x <= 10 or (x > 13 and x <= 16) or (x > 53 and x <= 56) or x > 59 then
            t(x) = t(x - 1)
          end if
          if x = t5 then t(x) = t(t4): '     t(18) = t(16)
          if x = t6 then t(x) = t(t6 - 33): 't(51) = t(18)
          if x = t7 then t(x) = t(t6): '     t(53) = t(51)
        end if
        'Blackman22
        if m = 8 then
          if x <= 8 or x > 61 then
            t(x) = t(x - 1)
          end if
          if x = t3 then t(x) = t(t3 - 5): ' t(13) = t(8)
          if x = t4 then t(x) = t(t3): '     t(16) = t(13)
          if x = t8 then t(x) = t(t7): '     t(56) = t(53)
          if x = t8 + 5 then t(x) = t(t8): ' t(61) = t(56)
        end if
      next x
      if y < 70 then t(0) = 1 else t(0) = 0
      delta = t(t0) + t(t1) + t(t2)
      delta = delta - t(t3) - t(t4) - t(t5)
      delta = delta - t(t6) - t(t7) - t(t8)
      delta = delta + t(t9) + t(t10) + t(t11)
      inta = inta + delta * m
      intb = intb + inta
      sample = int(intb/8)
      print y, delta, inta/m, intb, sample
    next y
    EDIT:
    New Blackman window added as fourth one.
    edited 2018-12-14 22:32
    Here are the three four windows for the BASIC program above:
    Tukey 21/40	"Tukey68"
     1, 2, 4, 6, 8,11,14,17,20,23,26,29,32,34,36,38,39	Ramp up/down =  340 x 2
    40[34]							Plateau      = 1360
    39,38,36,34,32,29,26,23,20,17,14,11, 8, 6, 4, 2, 1	Grand total  = 2040, /8 = 255
    Tukey 19/34	"Tukey45"
     1, 2, 4, 6, 8,11,14,17,20,23,26,28,30,32,33		Ramp up/down =  255 x 2
    34[15]							Plateau      =  510
    33,32,30,28,26,23,20,17,14,11, 8, 6, 4, 2, 1		Grand total  = 1020, /4 = 255
    Hann 19/34	"Hann30"
    33,32,30,28,26,23,20,17,14,11, 8, 6, 4, 2, 1		Grand total  =  510, /2 = 255
    Blackman 15/24	"Blackman22"
     1, 2, 4, 6, 8,11,14,17,20,22,23			Ramp up/down =  128 x 2
    23,22,20,17,14,11, 8, 6, 4, 2, 1			Grand total  =  256 *** clamp to 255 ***
    I'm curious to know how these windows affect the rise and fall times of square waves. The new Blackman window above is the shortest and thus should have the fastest response.
  • WindowFn  Vpp98%      StdDev     HFNoisePower     Length      freq -3dB   freq -6dB (MHz, sysclock=250MHz)
    tukey70 0.890625     0.226363    0.0314006           68       2.2583      2.99072
    tukey47  1.64062     0.385221     0.227268           45      3.54004      4.82178
    hann30    3.0625     0.851604     0.567518           28      5.98145      8.30078
    1200 x 900 - 36K
    1200 x 900 - 25K
    Thanks for the graphs.
    Was is Vpp98% again? Are the short windows a lot worse than Hann30?
  • TonyB_ wrote: »
    Peak-to-peak voltage out of 0-255, with the top and bottom 1% removed. We don't want rare outliers to affect the results.
    Generally, the length is the most important factor in how well a filter performs. Probably.
  • evanhevanh Posts: 17,278
    The marketers will start calling them intelligent filters soon.
    edited 2018-12-14 10:01
    Thanks for the graphs and tables, Guys.
    Today I made a 4th-order 22-bit filter that returns a 16-bit sample every clock. You can just do a RDPIN to get a sample.
    I modeled an RC integrator and put four in series. The ADC bits feed in as $000000/$3FFFFF. It takes about 256 clocks to settle to a stable 16-bit reading for a steady input pattern. Of course, our ADC is only good for 12 bits, or so, so the filter is overkill.
    Here is the filter model in SmallBASIC:
    d = 16   'how much to divide errors before adding into accumulators
    r = 10   'how often to report status (1=always)
    for y = 0 to 500
    acc = acc + 1/6   'simulate ADC bitstream
    if acc >= 1 then
      acc = acc - 1
      bit = 1
    else
      bit = 0
    endif
    'bit = 1    'test all 1's
    if bit = 1 then a0 = 0x3FFFFF else a0 = 0
    e1 = a0 - a1
    d1 = int(e1/d)
    a1 = a1 + d1
    e2 = a1 - a2
    d2 = int(e2/d)
    a2 = a2 + d2
    e3 = a2 - a3
    d3 = int(e3/d)
    a3 = a3 + d3
    e4 = a3 - a4
    d4 = int(e4/d)
    a4 = a4 + d4
    if y/r = int(y/r) then print y,bit,hex(a1),hex(a2),hex(a3),hex(a4),,"sample " + hex(int((a4+32)/64))
    next y
    Here is the Verilog code in the smart pin:
    This filter works great, but I don't know how practical it is. I think the windowed filters are more realistic, as they are a convenient 8 bits and don't have a RC-looking lag. Plus, they are 50 ALMs smaller. This filter is good for resolution, but not bandwidth.
    Here it is sampling a 10KHz 20mV sawtooth. Of sample[15:0], these are bits [8:1]:
    669 x 527 - 79K
    edited 2018-12-14 21:02
    This morning I made a triple-integrating window filter that only requires 4 taps for Hann and 6 taps for Tukey windows. Only two parameters are needed to define the shape.
    Here is the code:
    'a=4 : b = 00 : m=32     '17-tap Hann window, t2 and t3 cancel out
    'a=4 : b = 08 : m=16     '25-tap Tukey window
    'a=8 : b = 00 : m=04     '33-tap Hann window, t2 and t3 cancel out
    'a=8 : b = 16 : m=02     '49-tap Tukey window
     a=8 : b = 48 : m=01     '81-tap Tukey window
    gx = 10 : gy = 270 : iy = gy + 100
    t0 = 0
    t1 = t0 + a
    t2 = t1 + a
    t3 = t2 + b
    t4 = t3 + a
    t5 = t4 + a
    topbit = t5
    for x = 1 to 35 : print : next x
    print "taps",,t0,t1,t2,t3,t4,t5
    print
    dim t(topbit)
    for x = 0 to topbit : t(x) = 0 : next x 'clear bits
    inta = 0
    intb = 0
    intc = 0
    print "iter","ADC","delt","inta","intb","intc","samp","clam"
    for iter = 0 to topbit*2 + 1
    for x = topbit to 1 step -1 : t(x) = t(x-1) : next x 'shift bits
    t(0) = (iter <= topbit) 'new ADC bit
    't(0) = 1 - t(1)
    't(0) = int(rnd + 0.5)
    delt = t(t0) - t(t1)*2 + t(t2) - t(t3) + t(t4)*2 - t(t5)
    inta = inta + delt
    intb = intb + inta
    intc = intc + intb * m
    clam = int(intc/4096)
    samp = int(intc/16) - clam
    print iter,t(0),delt,inta,intb,intc,samp,clam
    line gx + iter*3, gy, gx + iter*3, gy - samp 'plot samples
    line gx + iter*3, iy, gx + iter*3, iy - intb 'plot intb
    next iter
    I graphed the filter, too:
    544 x 917 - 10K
    edited 2018-12-14 12:27
    How much more logic does this take?
    TonyB_ wrote: »
    For supporting four windows, it would certainly take less.
    thirdorderfilter(4,00)      5.5      1.60715       39.094           14      11.7798      16.2964
    thirdorderfilter(4,08)      5.5       1.5986      3.72318           22      6.71387      9.21631
    thirdorderfilter(8,00)  3.14062     0.840053     0.494072           30      5.92041      8.17871
    thirdorderfilter(8,16)  1.63281     0.407364      0.32118           46      3.41797      4.63867
    thirdorderfilter(8,48) 0.824219     0.213652    0.0951247           78      1.83105      2.50244
    Vpp98% is peak-to-peak noise with the output scaled to 0-255, but without quantization. It could be considered the number of counts that the reading will wander.
    Cutoff frequencies are in MHz and assume a sysclock of 250MHz.
    1200 x 900 - 38K
    1200 x 900 - 51K
  • cgracey wrote: »
    TonyB_ wrote: »
    The problem is these new windows are not Hann nor Tukey and I don't know what they are.
    edited 2018-12-14 22:18
    I've edited my BASIC program to add a fourth window:
    http://forums.parallax.com/discussion/comment/1457894/#Comment_1457894
    Details of all four are in this edited post:
    http://forums.parallax.com/discussion/comment/1457896/#Comment_1457896
    There is a family of "raised cosine" windows given by
    w(n) = a0 - a1*cos(2*pi*n/N) + a2*cos(4*pi*n/N)   for n = 0 to N-1
    Window	 	a0	a1	a2
    Hann		0.5	0.5	0
    Hamming		0.543	0.457	0
    Blackman	0.423	0.498	0.079
    The new fourth window mentioned above is a Blackman window, which has better stopband attentuation and lower passband ripple than either Hann or Hamming. The chosen Blackman is mostly identical to the Hann and Tukey, which means the logic required to implement it is reduced.
    The following table show the taps that are skipped for three of the windows.
    00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 Tap
    +1 +1 +2 +2 +2 +3 +3 +3 +3 +3 +3 +3 +3 +2 +2 +2 +1 +1  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0 -1 -1 -2 -2 -2 -3 -3 -3 -3 -3 -3 -3 -3 -2 -2 -2 -1 -1  0 Slope
    **    **       **                      **       **    **        **    **       **                      **       **    ** Slope change
     1  2  4  6  8 11 14 17 20 23 26 29 32 34 36 38 39 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 39 38 36 34 32 29 26 23 20 17 14 11  8  6  4  2  1  0	  Tukey68
     1  2  4  6  8 11 14 17 20 23 26 __ __ 28 30 32 33 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 33 32 30 28 26 23 __ __ 20 17 14 11  8  6  4  2  1  0	  Tukey45
     1  2  4  6  8 11 14 17 20 23 26 __ __ 28 30 32 33 __ 33 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 32 __ 30 28 26 23 __ __ 20 17 14 11  8  6  4  2  1  0	  Hann30
     1  2  4  6  8 11 14 17 20 __ __ __ __ 22 __ __ 23 __ 23 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 22 __ 20 __ __ 17 __ __ __ __ 14 11  8  6  4  2  1  0	  Blackman22
    The next table shows the plateau taps after the ramps, with the Tukey45 taps at the end of the plateau shift bits.
    +1 +1 +2 +2 +2 +3 +3 +3 +3 +3 +3 +3 +3 +2 +2 +2 +1 +1  0 -1 -1 -2 -2 -2 -3 -3 -3 -3 -3 -3 -3 -3 -2 -2 -2 -1 -1  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0 Slope
     1  2  4  6  8 11 14 17 20 23 26 29 32 34 36 38 39 40 40|39 38 36 34 32 29 26 23 20 17 14 11  8  6  4  2  1  0|40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40	  Tukey68
     1  2  4  6  8 11 14 17 20 23 26 __ __ 28 30 32 33 34 34|33 32 30 28 26 23 __ __ 20 17 14 11  8  6  4  2  1  0|__ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 34 34 34 34 34 34 34 34 34 34 34 34 34 	  Tukey45
     1  2  4  6  8 11 14 17 20 23 26 __ __ 28 30 32 33 __ 33 32 __ 30 28 26 23 __ __ 20 17 14 11  8  6  4  2  1  0|__ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 	  Hann30
     1  2  4  6  8 11 14 17 20 __ __ __ __ 22 __ __ 23 __ 23 22 __ 20 __ __ 17 __ __ __ __ 14 11  8  6  4  2  1  0|__ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ 	  Blackman22
    It is easier to see both ramps and the overall similarities between the windows in this second table.
    edited 2018-12-14 22:29
    Thanks again for the graphs. Could you please add the new Blackman22 to the above?
    I think it's better to exclude zeroes in the names, hence Tukey68 and Tukey45.
    EDIT:
    I've noticed that you say the length of Hann30 is 28 but it does have 30 non-zero values.
    TonyB_ wrote: »
    TonyB_ wrote: »
    They are just simple integrations. Close approximation to raised sine.
    This SmallBASIC program graphs it all:
    'a=8 : b = 48 : m=01     '81-tap Tukey window
    gx = 10 : cy = 270 : by = cy + 100 : ay = by + 100 : dy = ay + 50
    t0 = 0
    t1 = t0 + a
    t2 = t1 + a
    t3 = t2 + b
    t4 = t3 + a
    t5 = t4 + a
    topbit = t5
    for x = 1 to 40 : print : next x
    print
    dim t(topbit)
    inta = 0
    intb = 0
    intc = 0
    't(0) = 1 - t(1)
    inta = inta + delt
    intb = intb + inta
    x = gx + iter*4
    line x, cy, x, cy - intc/16 'plot intc
    line x, by, x, by - intb    'plot intb
    line x, ay, x, ay - inta*2  'plot inta
    line x, dy, x, dy - delt*8  'plot delta
    next iter
    Here's the output for the Tukey49:
    422 x 1977 - 25K
  • TonyB_ wrote: »
    TonyB_ wrote: »
    cmafilter(8,8,16) = thirdorderfilter(8,0)
    cmafilter(4,4,8) = thirdorderfilter(4,0)
    cmafilter(4,4,16) = thirdorderfilter(4,8)
    cmafilter(8,8,32) = thirdorderfilter(8,16)
    cmafilter(8,8,64) = thirdorderfilter(8,48)
    cmafilter(x,y,z) is a cascaded moving average. It means filter by a moving average of length x. Then filter the output of that by a moving average filter of length y. Do it again with a moving average of length z. If all 3 numbers were the same it would be a sinc3 filter. This is slightly more general. We basically have a sinc3 with the center part lengthened.
    Here is the BASIC program for the 4th-order filter I added into the smart pin (to try it, anyway). At any time, you can do a RDPIN to get a 16-bit sample, which is noisy, though the filter is 16-bit stable:
    r = 16   'how often to report status (1=always)
    g = 1    'graphics/text mode
    for i = 0 to 2048
    if i/320 = int(i/320) then t = 1-t
    if t = 1 then acc = acc + 4/6
    if acc >= 1 then
      acc = acc - 1
      bit = 1
    else
      bit = 0
    endif
    'bit = int(rnd + 0.5)
    e1 = a0 - a1
    d1 = int(e1/d)
    a1 = a1 + d1
    e2 = a1 - a2
    d2 = int(e2/d)
    a2 = a2 + d2
    e3 = a2 - a3
    d3 = int(e3/d)
    a3 = a3 + d3
    e4 = a3 - a4
    d4 = int(e4/d)
    a4 = a4 + d4
    sample = int((a4+32)/64)
    if g = 1 then
      x = 10 + i
      s = 25000
      line x,  200, x,  200 - bit*100 'plot bit
      line x,  400, x,  400 - a1/s    'plot a1
      line x,  600, x,  600 - a2/s    'plot a2
      line x,  800, x,  800 - a3/s    'plot a3
      line x, 1000, x, 1000 - a4/s    'plot a4
      if sample = lastsample then same++ else same = 0
      if same > 10 then line x, 1200, x, 1100
      lastsample = sample
    elseif i/r = int(i/r) then
      print i,,bit,hex(a1),hex(a2),hex(a3),hex(a4),,"sample " + hex(sample)
    endif
    next i
    When the program runs in graph mode (g=1), it plots, top-down, the ADC bitstream, a1, a2, a3, a4, and lines for when the filter output has been 16-bit-stable for 10 consecutive samples. Every 320 clocks it switches between 1/6 duty and 5/6 duty, which is what the ADC outputs at GND and VIO readings:
    1429 x 1148 - 15K
    TonyB_ wrote: »
    Window	 	a0	a1	a2
    Hann		0.5	0.5	0
    Tony, super work here. This looks very nice. Four good filters.
    Do you know what they each sum to? The Blackman22 looks like it goes to 256. Not so sure about the rest.
    Thanks for coming up with all these.
    edited 2018-12-15 00:54
    Chip, Blackman22 sums to 256, the rest to 255. I could modify the Blackman22 to sum to 250, but that's not great. This window matches a genuine Blackman, as much as the resolution allows. How many shift bits are available? It must be more than 70.
    Your cascaded third-order filters need more adders bits. I calculate 27 vs 21 and total logic size of the two could be close. I think it would be optimal to have the plateau bits at the end as in the second table.
  • MJBMJB Posts: 1,235
    edited 2018-12-15 00:15
    TonyB_ wrote: »
    TonyB_ wrote: »
    as far as I recall a RC low-pass corresponds to a PT1 which represents a IIR-Filter. IIR filters are inherently shorter/less expensive to implement than FIR-filters, but have nonlinear phase response and often an non flat passband.
    https://gaussianwaves.com/2017/02/choosing-a-filter-fir-or-iir-understanding-the-design-perspective/
    edited 2018-12-15 00:53
    TonyB_ wrote: »
    Sinc3 uses many more adder bits, of course, so Tukey/Hann/Blackman should be bigger. It's been interesting to work on, if it doesn't make it into rev B.
    TonyB_, i think I will implement your filters. They take care of the eight bit issue nicely. For highest speed, they are necessary.
    I wish we had infinite logic, so that we could also implement a 16-bit converter. Then, the streamer could write 16-bit samples to memory whenever it wanted to, as well.
    edited 2018-12-15 01:45
    Does anyone have any better ideas than the filter I implemented to do 16-bit conversions? It was a very simple notion and it works well, but there may be some better techniques. Maybe something else would take less logic, or have better pass-band characteristics, or settle faster.
    Being able to grab a 16-bit conversion whenever you want it is really nice.
  • cgracey wrote: »
    Thanks, Chip. I don't mind if other filters are used, whatever can fit. I counted how many register bits in total were in use the other day for the scope mode and it came to 32x3 + 1x16 = 112. I'm not sure whether that is the limit and the 80 taps you need for one of your cascaded filters are impossible or not. If more bits are available then I could have a look at slightly larger windows that might avoid the need for clamping one of them. Having said that, Hann/Tukey and Blackman might not go together so well as now (see pic below). I've read some good things about the Blackman function, which is a combination of cosine-squared and cosine-squared-squared.
