Traffic Light System With Pedestrian Crossing
Hi Everyone,
I am new to the world of PBASIC but am grateful for the principles I am learning.
I am working on a similar project to https://forums.parallax.com/discussion/169193/push-buttons-being-read-while-other-actions-are-being-performed and have reviewed the suggestions there already. My traffic lights are working and the pushbuttons are as well.
The additional condition for me is that while a pedestrian is crossing in one direction, the traffic sequence in the other direction must continue. This seems like trying to approximate parallel running whereas PBASIC seems to be procedural. Right now if a pedestrian is crossing in one lane(say E-W) , the other lane(N-S) finishes its current sequence and then its red lights remain on till the pedestrian in lane E-W finishes crossing. I need a way for the N-S even after finishing its current sequence to start all over again independent of the pedestrian crossing in E-W which is going on nonetheless.
I would appreciate any help I could get. My current code is below.
pedButtonEW VAR Word 'Button to press for pedestrian crossing
pedButtonNS VAR Word 'Button to press for pedestrian crossing
waitew VAR Byte 'variable to ensure crossing waits until the lane is red before beginning
waitns VAR Byte 'variable to ensure crossing waits until the lane is red before beginning
flash VAR Word 'variable for flashing LED at the later part of pedestrian crossing
rest VAR Word ' variable to simulate pause using for loops
testew VAR Word 'variable to ensure cycle runs twice between consecutive pedestrian crossings
testns VAR Word 'variable to ensure cycle runs twice between consecutive pedestrian crossings
newew VAR Byte
newns VAR Byte
testew = 2
testns = 2
waitew = 0
waitns = 0
DO
GOSUB begin
GOSUB eastwestleft
IF pedButtonEW = 1 THEN
GOSUB crossingew
ELSEIF pedButtonNS = 1 THEN
GOSUB crossingns
ENDIF
GOSUB northsouth
GOSUB crossingew
GOSUB crossingns
ENDIF
LOOP
begin: 'Beginning of Overall Sequence. All lights red.
GOSUB check
LOW 14
HIGH 15
HIGH 12
HIGH 11
HIGH 6
FOR rest = 1 TO 200
GOSUB check
PAUSE 10
NEXT
GOSUB crossingew
GOSUB crossingns
ENDIF
LOW 12
LOW 11
RETURN
eastwestleft: 'Sequence for East-West-Left Turn lane
waitew = 1
newew = 1
GOSUB check
GOSUB ns
LOW 12
LOW 11
LOW 13
LOW 5
LOW 10
LOW 4
HIGH 6
HIGH 8
HIGH 7
FOR rest = 1 TO 100
GOSUB check
GOSUB ns
PAUSE 10
NEXT
'Left arrow goes To amber ANd THEn red
LOW 7
HIGH 10
FOR rest = 1 TO 200
GOSUB check
GOSUB ns
PAUSE 10
NEXT
LOW 10
HIGH 11
FOR rest = 1 TO 200
GOSUB check
GOSUB ns
PAUSE 10
NEXT
'After 2-3 seconds (TO clear the intersection), the W-E light will go green
LOW 6
HIGH 4
FOR rest = 1 TO 500
GOSUB check
GOSUB ns
PAUSE 10
NEXT
'After a WHILE, the W-E and E-W lights will go TO amber and THEN red together
LOW 4
LOW 8
HIGH 5
FOR rest = 1 TO 100 'PAUSE 1000
GOSUB check
GOSUB ns
PAUSE 10
NEXT
LOW 5
LOW 10
HIGH 6
HIGH 12
FOR rest = 1 TO 250
GOSUB check
GOSUB ns
PAUSE 10
NEXT
waitew = 0
testew = testew + 1
newew = 0
RETURN
northsouth: 'Sequence for North-South Turn lane
waitns = 1
newns = 1
LOW 4
LOW 7
LOW 8
LOW 14
LOW 15
HIGH 13
HIGH 12
HIGH 6
HIGH 11
FOR rest = 1 TO 500 'Pause 5 seconds
GOSUB check
GOSUB ew
PAUSE 10
NEXT
'After a WHILE, the N-S and S-N lights will go TO amber and THEN red together
LOW 13
HIGH 14
FOR rest = 1 TO 100
GOSUB check
GOSUB ew
PAUSE 10
NEXT
LOW 14
HIGH 15
GOSUB check
GOSUB ew
waitns = 0
testns = testns + 1
newns = 0
RETURN
check: 'subroutine to check if pushbutton is pressed
IF (IN9 = 1) AND (pedButtonEW = 0)THEN
pedButtonEW = 1
ELSE
'For Debug testing
ENDIF
IF (IN0 = 1) AND (pedButtonNS = 0) THEN
pedButtonNS = 1
ELSE
'for Debug testing
ENDIF
RETURN
crossingew: 'subroutine to allow pedestrian to cross the East-West lane
IF waitew = 0 AND testew >= 2 THEN
HIGH 3
LOW 2
LOW 15
LOW 10
LOW 5
pedButtonEW = 0
GOSUB northsouth
PAUSE 14000
FOR flash = 1 TO 20
HIGH 3
LOW 2
PAUSE 248
LOW 3
LOW 2
PAUSE 248
NEXT
LOW 3
HIGH 2
testew = 0
ELSEIF waitew = 0 AND testew < 2 THEN
pedButtonEW = 0
ELSE
ENDIF
RETURN
crossingns: 'subroutine to allow pedestrian to cross the North-South lane
IF waitns = 0 AND testns >= 2 THEN
HIGH 1
LOW 14
LOW 13
pedButtonNS = 0
GOSUB eastwestleft
PAUSE 5500
FOR flash = 1 TO 20
HIGH 1
PAUSE 249
LOW 1
PAUSE 249
NEXT
testns = 0
ELSEIF waitns = 0 AND testns < 2 THEN
pedButtonNS = 0
ELSE
ENDIF
RETURN
ew: ' call pedestrian crossing subroutine
GOSUB crossingew
ENDIF
RETURN
ns: 'call pedestrian crossing subroutine
GOSUB crossingns
ENDIF
RETURN
It also helps if you group I/O pins with one set of pushbuttons and LEDs in the first set of I/O pins (0-7) and the other set of pushbuttons and LEDs in the second set of I/O pins (8-15). This way you can have another variable, say "iobank" that's set to 0 before the 1st "on ... gosub" and set to 8 before the 2nd "on ... gosub". Your I/O statements can add "iobank" to the I/O pin number like: "if INS.bit(button+iobank) = 1 then"
I will do my best to make the investment worth it.
