Help with project.
in BASIC Stamp
How to get counter to count the number of cycles from a pushbutton instead of how long the pushbutton is being pressed. [img][/img]
Below is the project that I'm working on.
Sometimes a flowchart or even a simple description of the steps involved will help you understand what your program needs to do. How would you count the number of times a pushbutton is pressed? Remember that in some problems, you also have to look at when a pushbutton is released. For this reason, PC keyboards send both bits of information. They send a keycode to the PC when a key is pressed and a different keycode when that key is released.
wait for PB to go HIGH a few millisec wait for PB to go LOW a few millisec increment a counter
One example is that of counting milliseconds. The PAUSE takes approximately one millisecond and a few simple statements may take say 0.4ms. Those statements might decrement a counter and loop back to a PAUSE if the count is > 0. Now you have a more complex counter that's tied into a time source.
Try writing a program that displays a message, waits for 500ms using only a PAUSE 1 as the timing statement, then displays another message.
Alternatively, write a program that displays a message, waits for you to close a switch, and keeps track of the elapsed time in milliseconds using only a PAUSE 1, then displays another message.
Great News! Congrats.
"PBA 1
PBB 0
PBC 0
TC( Total Counter) 1"
This works for each button but i cant get it to loop
Here is my code
CounterA VAR WORD
CounterB VAR WORD
CounterC VAR WORD
counter VAR WORD
totalcounter VAR WORD
maximum VAR WORD
CodeA VAR WORD
CodeB VAR WORD
CodeC VAR WORD
CodeA = 2
CodeB = 3
CodeC = 3
maximum = 8
countera = 0
main:
DO
DO UNTIL (IN3 = 1) OR (IN4=1) OR (IN5=1)
LOOP
IF IN3 = 1 THEN
CounterA = CounterA + 1
totalcounter = totalcounter + 1
DO WHILE IN3 = 0
LOOP
ELSEIF IN4 =1 THEN
counterB= counterb + 1
DO WHILE IN4=0
LOOP
ELSEIF IN5=1 THEN
counterc = counterc + 1
DO WHILE IN5=1
LOOP
ENDIF
DO
DO
DEBUG CR,"PBA ",DEC CounterA, CR
DEBUG CR,"PBb ",DEC Counterb, CR
DEBUG CR,"PBC ",DEC Counterc, CR
DEBUG CR, "TC", DEC Totalcounter, CR
DO WHILE IN3 = 0 OR IN4 = 0 OR IN5=0
LOOP
LOOP
LOOP
LOOP UNTIL totalcounter =8 "
DO some code more code LOOP
As your code is displayed now, I am too lazy to try to figure out which LOOP goes with which DO.
2. But surely there is one too many DO/LOOPs near the bottom. Get your indentation squared away and I'm sure you will see it.
Here is the new code
CodeA = 2
CodeB = 3
CodeC = 3
maximum = 8
countera = 0
counterb = 0
counterc = 0
totalcounter = 0
DO
IF(IN3=1) AND (IN4=0) AND (IN4=0) THEN
PAUSE 500
DO
IF (IN3=0 AND counterc = 0 AND counterb = 0) THEN
counterA = counterA +1
ELSEIF IN3 = 0 AND counterb > 0 OR Counterc > 0 AND totalcounter >= 0 THEN
ENDIF
LOOP UNTIL IN4 = 0
ENDIF
IF(IN4=1) AND (IN3=0) AND IN5=0 THEN
PAUSE 500
IF IN4=0 AND counterc = 0 AND countera > 0 THEN
counterb = counterb +1
ELSEIF IN4 = 0 AND countera > 0 OR counterc > 0 OR totalcounter >= 0 THEN
ENDIF
DEBUG CR,"PBB ",DEC CounterB, CR
ENDIF
IF(IN5=1) AND IN4=0 AND IN3=0 THEN
PAUSE 500
IF IN5=0 AND counterb > 0 AND countera >0 THEN
counterc = counterc +1
ELSEIF IN5= 0 AND counterb = 0 AND countera = 0 THEN
ENDIF
DEBUG CR,"PBC ",DEC CounterC, CR
ENDIF
LOOP
DO UNTIL DO UNTIL (IN3 = 1) OR (IN4=1) OR (IN5=1)' wait for a button to be pressed totalcounter = totalcounter + 1 ' a button has to be pressed to get here so increment Totalcounter IF IN3 = 1 THEN CounterA = CounterA + 1 ' Button A pressed so increment counterA ELSEIF IN4 =1 THEN CounterB = CounterB + 1 ' Button B pressed so increment counterB ELSEIF IN5=1 THEN CounterC = CounterC + 1 ' Button C pressed so increment counterC DO UNTIL (IN3 = 0) AND (IN4 = 0) AND (IN5 = 0)' wait for all buttons to be released LOOP
Please use the "CODE" tags so others can understand you indentation.
