www.DipTrace.com
hmlittle59
Hello All,
All my TAB's are working except this one. Can someone else check.
Not working on my phone either
https://downforeveryoneorjustme.com/diptrace.com
hmm... I wonder where it is hosted ? Gives a 'diptrace.com took too long to respond' report from here.
I had a similar strange effect a few weeks ago with MCU vendor http://www.syncmos.com.tw/
That would appear as ok in downforeveryoneorjustme, but would timeout from here, but I was able to connect with a virtual web node, so I wondered if they had some country or region blocking going on, as a coarse protection against DOS attacks ?
In the last couple of weeks http://www.syncmos.com.tw/ has worked fine, so it was temporary, whatever the cause.
I'm located in Northern California.
Here's the output from Trace Route:
Backup and running here now.
