www.DipTrace.com — Parallax Forums
www.DipTrace.com
Hello All,
All my TAB's are working except this one. Can someone else check.
Not working on my phone either
  • downforeveryoneorjustme shows it as up right now but I cannot get it to open from any browser on two separate net connections (corporate fiber and secured DSL). Both come back with timeout errors. So, the site may respond to ping given the impression that it is "up" but the server may not be serving anything up.
  • jmgjmg Posts: 15,200
    hmm... I wonder where it is hosted ? Gives a 'diptrace.com took too long to respond' report from here.
    I had a similar strange effect a few weeks ago with MCU vendor http://www.syncmos.com.tw/
    That would appear as ok in downforeveryoneorjustme, but would timeout from here, but I was able to connect with a virtual web node, so I wondered if they had some country or region blocking going on, as a coarse protection against DOS attacks ?
    In the last couple of weeks http://www.syncmos.com.tw/ has worked fine, so it was temporary, whatever the cause.
  • I can't get to it either.
  • Francis BauerFrancis Bauer Posts: 409
    edited 2018-09-01 03:38
    www.diptrace.com works for me, it resolves to https://diptrace.com.
    I'm located in Northern California.
    Here's the output from Trace Route:
    tracert www.diptrace.com
    Tracing route to diptrace.com [199.167.45.149]
    over a maximum of 30 hops:
      1     2 ms     2 ms     3 ms  ZyWALL 2 Plus [192.168.1.1]
      2     *       13 ms    12 ms  xxx.xxx.xxx.xxx.dsl.static.sonic.net []
      3    14 ms    13 ms    14 ms  104.at-2-1-0.gw3.200p-sf.sonic.net [64.142.73.165]
      4    13 ms    14 ms    13 ms  0.ae2.gw.200p-sf.sonic.net [70.36.211.53]
      5    16 ms    14 ms    36 ms  as0.gw2.200p-sf.sonic.net [208.106.96.250]
      6    15 ms    14 ms    15 ms  303.ae4.gw.pao1.sonic.net [69.12.163.217]
      7    15 ms    16 ms    17 ms  palo-b22-link.telia.net [213.248.81.254]
      8    17 ms    19 ms    15 ms  abovenet-ic-312365-palo-b1.c.telia.net [62.115.48.58]
      9    84 ms    84 ms   108 ms  ae9.cs1.sjc2.us.eth.zayo.com [64.125.27.188]
     10    85 ms    85 ms    84 ms  ae2.cs1.lax112.us.eth.zayo.com [64.125.28.145]
     11    87 ms    84 ms    91 ms  ae3.cs1.dfw2.us.eth.zayo.com [64.125.29.52]
     12    85 ms    83 ms    86 ms  ae5.cs1.iah1.us.eth.zayo.com [64.125.28.98]
     13    86 ms    84 ms    87 ms  ae3.cs1.dca2.us.eth.zayo.com [64.125.29.48]
     14    86 ms    87 ms    88 ms  ae1.mcs1.dca2.us.eth.zayo.com [64.125.29.231]
     15    86 ms    84 ms    85 ms  ae2.mpr3.iad2.us.zip.zayo.com [64.125.27.221]
     16    85 ms    84 ms    84 ms  ae0.mpr4.iad2.us.zip.zayo.com [64.125.31.178]
     17    86 ms    84 ms    86 ms  64.125.195.222.t00883-02.above.net [64.125.195.222]
     18    85 ms    90 ms    85 ms  209.50.254.6.servint.net [209.50.254.6]
     19    86 ms   129 ms    86 ms  sc-had4074.servint.net [216.22.3.215]
     20    85 ms    86 ms    85 ms  199.167.45.149
    Trace complete.
    Seems ok here now too.. as www.DipTrace.com
  • Update:
    Backup and running here now.
