Simple IDE bug?
Beavis3215
I have recently purchased a MAC and am using simple IDE for programming currently a Propeller Flip. I have noticed that if I edit my code once, the Flip programs ok. Usually if I edit code a second time and reprogram the Flip, things function ok. If I edit code a third time, code will compile ok, but Simple IDE can't find a port and will give me an error message. If I log out of Simple IDE and restart, I get another 2 attempts. Any ideas? One other clue is that when it gives me the error, the last code I edited is highlighted yellow.
You can see a few threads on the topic if you do a quick search. Here is a thread I made recently:
http://forums.parallax.com/discussion/168219/problems-with-propeller-spin-support-on-macintosh-computers#latest
There are some links to other threads discussing the topic in that thread. I believe this issue is also discussed on the Propeller IDE thread.
