BASIC Stamp2 SX DIP (Interpreter Chip)
microcontrolleruser
Sent money to Parallax to help develop the new Propeller by purchasing a Stamp SX not a SX SX.
https://www.parallax.com/product/pbasic2sx_p
Getting a Stamp 1 DIP lost out to the old rule 'Get the most micro you can for the money'.
Picked up their EEPROM and crystal to ensure the little Stamp2 SX is happy.
Anybody know if any of the instructions you gain over a Stamp2 are useful?
https://www.parallax.com/sites/default/files/downloads/BASICStampComparisonChart-0114.pdf
Thank you Publison
The comparison chart looks like one in Stamp Editor Help/Hardware.
Figured out the three extra instructions.GET PUT and RUN.
The GET and PUT go with 'Scratchpad' memory.
Which is the SX-SX's data memory.
In the SX you can get to it by address, this one the compiler numbers the registers for you.
The RUN looks like something for later.Calling another program? That is a new one on me.
All of these Basic Stamps have 16K of EEPROM for program storage divided into 2K "pages". The RUN statement works like a GOTO to the beginning of one of these 2K "pages". There's no way to specify a statement within a 2K "page" nor is there any way to return to the "page" containing the RUN statement. Despite these limitations, the RUN statement is helpful ... allowing a program to essentially have overlays. There are some application notes on ways to use the RUN statement.
Don't forget that the SX 50 MHz) is 2.5X faster than a BS2 (20 MHz) so any commands that involve timing will have different except for PAUSE which is always in ms.
Thanks Mike
'128 bytes of "scratchpad" memory'
Yes.We own a PX on a breakout board.
This Stamp SX is a nice transition to the P24 and up stamps.
' EEPROM for program storage divided into 2K "pages"
I know what causes the 2k limit.Just have to refresh my memory on it.Probably in the SX-SX datsheet.
It's the size of the register controlling it that does that.
' There are some application notes on ways to use the RUN statement.'
That's handy info.
Thanks Genetix
' the SX 50 MHz) is 2.5X faster than a BS2 (20 MHz)'
One major reason for that is the SX-SX 'software peripherals'.The Ubicom Sx needs to run fast for those to work.
So you get the benefit of that with the Stamp SX.
'so any commands that involve timing will have different'
That's handy info too.Thanks.
Not really. The BS2 (and the PBasic interpreter) was designed for a 2K (byte) EEPROM. The interpretive code format was designed around this 2K maximum program size. Rather than completely redesign the interpretive code and interpreter for larger EEPROMs, the notion of these 2K "pages" was used.
"The Ubicom SX needs to run fast for those to work." It's kind of the other way around.
The SX runs at about 2.5X the speed of the PIC used for the BS2. Most non-time-dependent statements and operators in PBasic benefit from the speed boost allowing PBasic programs to accomplish more. Time-dependent statements are also faster (except for PAUSE) so the various timing parameters have to be changed.
'2K maximum program size'
Anyhow it is Assembler stuff.Not necessary when using PBasic.
Program counter.Big fun.
Thanks Mike
Saving any more questions about new Stamp 2 SX for tomorrow morning.
It does seem like a cool little micro.
Nuts and Volts #54 (Volume 2) is all about the BS2sx.
I think the title speaks for itself.
#54: "Faster, Stronger, Better: the BASIC Stamp 2-SX"
https://www.parallax.com/downloads/nuts-and-volts-basic-stamps-volume-2
#71 which is also in Volume 2, talks about converting code from the BS2 to the BS2 sx-based modules.
#87 is on Multi-bank programming (Volume 3)
https://www.parallax.com/downloads/nuts-and-volts-basic-stamps-volume-3
The BASIC Stamp Manual though is your best resource.
https://www.parallax.com/downloads/basic-stamp-manual
Thank you Genetix
Here's some more info on it.
http://www.ic0nstrux.com/SX-tech-board#.WyP9sIplDIU
Next thing to do is start laying out circuit on breadboard.
SX should be here Monday or Tuesday.
Serial port hardware connector will be here in about a week.
That board is for the 28 pin SX chip, not the BS2-SX.
You would need this chip:
https://www.ebay.com/itm/1pc-UBICOM-Scenix-SX28AC-DP-microcontroller-50MHZ-50MIPS-Parallax-USA-seller-/231953261907?_trksid=p2385738.m4383.l4275.c10
Thank Publison
I was looking for SX SX schematic to hook up the Stamp SX.
Those downloads there have some handy stuff in them.
Looked at Stamp SX module schematic.Might be able to get by with that.
Wonder why Parallax never made schematics to breadboard Stamp 1 and Stamp SX DIP's?
Or Stamp 2 DIP?
What is a SX SX?
Thanks Publison
'What is a SX SX?' SX28
'You should make a distinction between the SX OEM and Stamp SX module'
Title of post is right off of Parallax website.
Thank you David Betz
'For that price you could get a Propeller, EEPROM, and crystal.'
We use Propeller and SX.
' Why bother with the SX?''
Because we want to.
Parallax never used that term in their marketing content. That muddies the waters when trying to answer your questions.
' I agree that Parallax never really created a successor to the BASIC Stamp'
It exists as another companies PICBasic.More or less a continuation of Basic Stamp.
Then there is PICaxe.Basic with more powerful micro's than PIC16F54(56 Stamp almost the same) and 16F57 Parallax uses.
So Parallax would have to play catchup and then pass them.
We will figure out how to wire these DIP's one way or the other.
It is just a little checklist.
Power, serial connection,oscillator and EEPROM.
Can't be that hard.
Refer to this:
https://www.parallax.com/product/27302
https://www.parallax.com/downloads/basic-stamp-2sx-oem-manual
https://www.parallax.com/downloads/basic-stamp-2sx-oem-component-list
There's a schematic at the end of the manual.
That whole thing is getting WAY off track.
We are getting a Stamp SX working on a breadboard.That's it.
Thank you Genetix
Let me take a closer look at that.
It looks like a Stamp 2 in a socket on a PCB board.With components to get it to run.That's what we need only on a breadboard.
Should work out about the same on a breadboard.
Went down this road with Stamp 1 DIP.
Guess we could get a Stamp 2 DIP and get that working and just modify for Stamp 1 and Stamp SX.
The SX is fast (50MHz clock) and a breadboard has fairly long interconnections with a lot of capacitance between a given connection and those around and adjacent to it. You may have problems trying to run the SX on a breadboard. There used to be breadboards specially designed to minimize the capacitance (and inductance) in and among the various interconnects, but I haven't seen them in years. Good luck.
Thanks Mike
Current plan.
Find + and - pins on SX28.
Sift through available info and see if pins are in same place on BS2SX.
Stamp will get here Monday probably.
To the eye it looks the same as SX28.I have to mark it somehow so
it does not get programmed and wipe out Parallax stuff on it.
VDD and VSS are pins 2 and 4 on the SX28.
We'll see where they are at on the BS2SX.
Found OSC1 OSC2 for the oscillator circuit.
The EEPROM is still a mystery.
Ditto on the serial adapter.
Interesting SX28 has PORTA PORTB and PORTC.
Lots of I/O pins.I'll get spoiled.Been working with 4 and 8 pins.
