14 Pin Basic Stamp LCD Sample Code
microcontrolleruser
in BASIC Stamp
Looking for the code for the old original 14 pin LCD display.
Not the newer Serial LCD Parallax sells currently.
I have seen it somewhere but can't remember where.Maybe Stampworks manual.
Thank you Mike
Tell you what we're up to in the AM.
Bob
As Mike said, the Parallel LCD has a 14-pin connector but LCDs that have backlights may have 16 or 18 pins.
I think this is what you are looking for.
https://www.parallax.com/downloads/2x16-parallel-lcd-basic-stamp-sample-code
https://www.parallax.com/downloads/2x16-parallel-lcd-basic-stamp-variable-display-code
Most LCDs use the Hitachi HD44780 or an equivalent from which all the code is based even on other microcontrollers.
https://www.parallax.com/downloads/hitachi-hd44780-chipset-datasheet
StampWorks has entire chapter on Parallel LCDs including how to make custom characters starting on page 73 [83 of the PDF].
https://www.parallax.com/downloads/stampworks-experiment-kit-manual
https://www.parallax.com/downloads/stampworks-basic-stamp-source-code
Also as Mike said there are a number of Nuts and Volts articles that use an LCD.
Thank you Genetix
Let me take a look at that first one.
Bob
