P2-ROM: Booter, Serial, Flash, SD card, Monitor and TAQOZ features and operation - Page 4 — Parallax Forums
124»
  • evanhevanh Posts: 17,173
    edited 2018-06-03 03:51
    jmg wrote: »
    Can you summarize the rules around long files names and formatting steps ?
    They aren't as bad as I was thinking there for a while, but best not to use them at all. They aren't recognised by the boot process and because they take up three filename entries each when deleting they leave a lot of odd gaps when mixed with 8.3 naming.
    jmg wrote: »
    Does this mean the FPGA loading side is not 100% reliable, but gets more reliable with a longer power-off ?
    Probably. I'm leaving this one in the don't do it bin.
    Thanks Tubular, for the push button reset help. It works. I remember that used to be an input that could be read so I gather Chip changed the FPGA function for it.
  • Here's the updated monitor register definitions used for SD functions.
    ''============[ COG VARIABLES - SD BOOT]========================================
                    org     $1C0              ' place the variables in cog $1C0-$1DF
    cmdout          res     1                       ' The 8b CMDxx | $40
    cmdpar          res     1                       ' The 32b parameters
    cmdcrc          res     1                       ' The 8b CRC (must be valid for CMD0 & CMD8)
    cmdpar2         res     1                       ' SDV1=$0, SDV2=$40000000
    cmdtype         res     1                       ' reply is R1=1, R3=3, R7=7, else 0
    reply           res     1                       ' R1 reply (moved to replyR1 when R3/R7 32b reply here)
    replyR1         res     1                       ' R1 reply (8b saved when R3/R7 32b reply follows)
    dataout         res     1                       ' 8/32 bit data being shifted out
    bytescnt        res     1                       ' #bytes to send/recv
    bitscnt         res     1                       ' #bits to be shifted in/out
    ctr1            res     1
    timeout         res     1                       ' = starttime + delay
    spare           res     1
    skiprun         res     1                       ' 1= skip load/run mbr/vol & load/no-run fname
                                                    '\ 1=SDV1, 2=SDV2(byte address), 3=SDHC/SDV2(block address)
    blocksh         res     1                       '/ block shift 0/9 bits
    clustersh       res     1                       ' sectors/cluster SHL 'n' bits
    vol_begin       res     1 '$0000_2000           ' Ptn0: first sector of PTN
    fsi_begin       res     1 '$0000_2001           ' Ptn0:       sector of file system info
    fat_begin       res     1 '$0000_3122           ' Ptn0: first sector of FAT table
    dir_begin       res     1' $0000_4000           ' Ptn0: first sector of DATA is DIR table
    dat_begin       res     1 '$0000_4580 $0000_54C0' Ptn0: first sector of file's DATA
    ptn_size        res     1 '$0008_0000           '       file-size 32KB = 64<<9 sectors
    _bufad          res     1
    _blocknr        res     1
    _sectors        res     1
    _entries        res     1
    bufad           res     1                       ' ptr sector buffer
    blocknr         res     1                       ' sector#
    fname           res     3                       ' 8+3+1
    _hubdata        res     1
                    fit     $1E0
    Bump thread for reference now we have first P2 silicon
  • thejthej Posts: 232
    edited 2018-09-29 03:07
    Is there a separate doc for this or does it only exist in this thread so far?
    Found it.
    j
    edited 2018-09-29 07:01
    Here are the MONITOR commands in the final ROM
    ROM_Booter_v32i.spin2    29/09/2018 4:19PM (downloaded from P2 forum)
    ''  MONITOR                        LMM DEBUGGER - SUPPORTED COMMANDS
    ''  xxxxxx : xx xx xx xx ... <cr>  DOWNLOAD:  to   cog/lut/hub {addr1} following {byte(s)}
    ''  xxxxxx - [xxxxxx] [L] <cr>     MEM LIST:  from cog/lut/hub {addr1} to < {addr2}  L=longs
    ''  xxxxxx G <cr>                  GOTO:      to   cog/lut/hub {addr1}
    ''                                                FC000 G <cr> will perform a reboot
    ''  Q <cr>                         QUIT:      Quit Rom Monitor and return to the User Program
    ''                                               {addr} is on the stack
    ''  Lfilename.xxx<cr>              LOAD:      Load file from SD   (8.3 filename)
    ''                                               returns "=" on success, "!" on failure
    ''  Rfilename.xxx<cr>              RUN:       Run  file from SD   (8.3 filename)
    ''                                               returns "!" on failure
    ''  <esc><cr>                      TAQOZ:     goto TAQOZ
    ''  <cr>                                      will repeat last MEM LIST command
    Note the changes to the download command to use ":", the memory list command to "-" and optional trailing "L" parameter (L=longs, else bytes).
    Filenames are in the format 8.3 (short filenames) with SD formatted as FAT32.
    edited 2018-12-26 01:20
    ROM MONITOR
    Updated 25Oct2018 15:56 (GMT+11:00)
    Here are the Monitor subroutine entry points...
    '' | Cluso's LMM_SerialDebugger for P2    (c)2013-2018 "Cluso99" (Ray Rodrick)|
    ''              LMM DEBUGGER - lmm_f CALL Modes...(not all modes supported in ROM)
      _MODE         = $F << 5                       ' mode bits defining the call b8..b5 (b4..b0 are modifier options)
      _SHIFT        = 5                             ' shr # to extract mode bits
      _HEX_         = 2 << 5                        ' hex...
        _REV_               = 1 << 4                '   - reverse byte order
        _SP                 = 1 << 3                '   - space between hex output pairs
       '_DIGITS             = 7..0 where 8->0       '   - no. of digits to display
      _LIST         = 3 << 5                        ' LIST memory line (1/4 longs) from cog/hub
        _ADDR2              = 1 << 4                ' 1= use lmm_p2 as to-address
        _LONG_              = 1 << 1                ' 1=display longs xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx
      _TXSTRING     = 4 << 5                        ' tx string (nul terminated) from hub
      _RXSTRING     = 5 << 5                        ' rx string
        _ECHO_              = 1 << 4                '    - echo char
        _PROMPT             = 1 << 3                '    - prompt (lmm_x)
        _ADDR               = 1 << 2                '    - addr of string buffer supplied
        _NOLF               = 1 << 1                '    - strip <lf>
      _MONITOR      = 7 << 5                        ' goto rom monitor
    _SerialInit        = $fcab8     ' Serial Initialise     (lmm_x & lmm_bufad must be set first)
    _HubTxCR           = $fcae4     ' Sends <cr><lf>        (overwrites lmm_x)
    _HubTxRev          = $fcaec     ' Sends lmm_x with bytes reversed
    _HubTx             = $fcaf0     ' Sends lmm_x           (can be up to 4 bytes)
    _HubHexRev         = $fcb24     ' Sends lmm_x with bytes reversed as Hex char(s) as defined in lmm_f
    _HubHex8           = $fcb28     ' Sends lmm_x as Hex char(s) after setting lmm_f as 8 hex chars
    _HubHex            = $fcb2c     ' Sends lmm_x as Hex char(s) as defined in lmm_f
    _HubTxStrVer       = $fcb9c     ' Sends $0 terminated string at lmm_p address after setting lmm_p=##_str_vers
    _HubTxString       = $fcba4     ' Sends $0 terminated string at lmm_p address
    _HubListA2H        = $fcbc4     ' List/Dump line(s) from lmm_p address to lmm_p2 address after setting lmm_f=#_LIST+_ADDR2
    _HubList           = $fcbc8     ' List/Dump line(s) from lmm_p address to lmm_p2 address according to lmm_f
    _HubRx             = $fcb10     ' Recv char into lmm_x
    _HubRxStrMon       = $fccc4     ' Recv string into lmm_bufad address after setting prompt=lmm_x=#"*" & params=lmm_f=#_RXSTRING+_ECHO_+_PROMPT
    _HubRxString       = $fcccc     ' Recv string into lmm_p/lmm_bufad address according to params in lmm_f
    _HubMonitor        = $fcd78     ' Calls the Monitor; uses lmm_bufad as the input buffer address
    _RdLongCogHub      = $fcf34     ' read cog/lut/hub long from lmm_p address into lmm_x, then lmm_p++
    _str_vers          = $fd014     ' locn of hub string, $0 terminated
      _HUBROM          = $FC000     ' ROM $FC000
      _HUBBUF          = $FC000     ' use as RxString buffer    (overwrites Booter)
      _HUBBUFSIZE      = 80         ' default size for _HUBBUF  (can be 128)
    In addition to this, you need to have these COG registers available. You can define by CON or reserved as registers in your code (both types given)
    CON                ''============[ COG VARIABLES $1E0-$1EF - MONITOR]==============================
                       ''-------[ LMM parameters, etc ]------------------------------------------------
    lmm_x              = $1e0          ' parameter passed to/from LMM routine (typically a value)
    lmm_f              = $1e1          ' parameter passed to      LMM routine (function options; returns unchanged)
    lmm_p              = $1e2          ' parameter passed to/from LMM routine (typically a hub/cog ptr/addr)
    lmm_p2             = $1e3          ' parameter passed to/from LMM routine (typically a 2nd hub/cog address)
    lmm_c              = $1e4          ' parameter passed to/from LMM routine (typically a count)
                       ''-------[ LMM additional workareas ]-------------------------------------------
    lmm_w              = $1e5          ' workarea (never saved - short term use between calls, except _HubTx)
    lmm_tx             = $1e6          ' _HubTx
    lmm_hx             = $1e7          ' _HubHex/_HubString
    lmm_hx2            = $1e8          ' _HubHex
    lmm_hc             = $1e9          '   "
    lmm_lx             = $1ea          ' _HubList
    lmm_lf             = $1eb          '   "
    lmm_lp             = $1ec          '   "
    lmm_lp2            = $1ed          '   "
    lmm_lc             = $1ee          '   "
    lmm_bufad          = $1ef          ' _HubRxString
    ''============[ COG VARIABLES - MONITOR]========================================
                    res     $1E0-$            ' reserve (if any)
                    org     $1E0              ' place the variables in cog $1E0-$1EF
    lmm_x           res     1       '$1e0  parameter passed to/from LMM routine (typically a value)
    lmm_f           res     1       '$1e1  parameter passed to      LMM routine (function options; returns unchanged)
    lmm_p           res     1       '$1e2  parameter passed to/from LMM routine (typically a hub/cog ptr/addr)
    lmm_p2          res     1       '$1e3  parameter passed to/from LMM routine (typically a 2nd hub/cog address)
    lmm_c           res     1       '$1e4  parameter passed to/from LMM routine (typically a count)
    lmm_w           res     1       '$1e5  workarea (never saved - short term use between calls, except _HubTx)
    lmm_tx          res     1       '$1e6  _HubTx
    lmm_hx          res     1       '$1e7  _HubHex/_HubString
    lmm_hx2         res     1       '$1e8  _HubHex
    lmm_hc          res     1       '$1e9    "
    lmm_lx          res     1       '$1ea  _HubList
    lmm_lf          res     1       '$1eb    "
    lmm_lp          res     1       '$1ec    "
    lmm_lp2         res     1       '$1ed    "
    lmm_lc          res     1       '$1ee    "
    lmm_bufad       res     1       '$1ef  _HubRxString
                    fit     $1F0
    edited 2018-10-25 05:38
    Here is a very simple example of using the ROM Monitor with...
    * Setting the crystal oscillator (we have a 12MHz oscillator)
    * Setting clock to 96MHz
    * Setting Serial to 115,200 baud, 8 bits
    * Sending serially a $0 terminated string in a 1s loop
    This is the user code to do this...
    DAT             orgh    0
                    org     0
    ''-------[ Set Xtal ]----------------------------------------------------------
    entry           hubset  #0                                      ' set 20MHz+ mode
                    hubset  ##%1_001011_0001011111_1111_01_00       ' ena-xtal+PLL,div=12,mul=96,p=15,0pF,20MHz+
                    waitx   ##20_000_000/100                        ' ~10ms at 20MHz (rc osc)
                    hubset  ##%1_001011_0001011111_1111_01_11       ' 96MHz
                    waitx   ##delay5s                       ' just a delay to get pc terminal running
    ''-------[ Start Serial ]------------------------------------------------------
                    mov     lmm_bufad,        ##_HUBBUF     ' locn of hub buffer for serial routine
                    mov     lmm_x,            ##_bitper     ' sets serial baud
                    call    #_SerialInit                    ' initialise serial
    .loop           mov     lmm_p,            ##_str_vers   ' must be in hub!
                    call    #_HubTxString                   ' display the $0 terminated string
                    waitx   ##delay1s                       ' just a delay before repeating
                    jmp     #.loop
    This is the full code with equates...
    '' | Cluso's ROM_Monitor_Demo_001 for P2 v32i Silicon                   v0.xx |
    '' |  Author :       (c)2013-2018 "Cluso99" (Ray Rodrick)                     |
    '' |  License:       MIT License - See end of file for terms of use           |
    '' RR20181025   001     initial demo
    ''============================[ CON ]============================================================
    CON
      _clockfreq    =  96_000_000
      _cpufreq      = _clockfreq
      delay5s       = _cpufreq * 5                            ' 5s
      delay1s       = _cpufreq                                ' 1s
      _baud         = 115_200                                 ' 115,200 baud
      _bitper       = (_cpufreq / _baud) << 16 + 7            ' xxxxxxx baud, 8 bits
      _txmode       = %0000_0000_000_0000000000000_01_11110_0 'async tx mode, output enabled for smart output
      _rxmode       = %0000_0000_000_0000000000000_00_11111_0 'async rx mode, input  enabled for smart input
       rx_pin       =       63                   ' pin serial receiver
       tx_pin       =       62                   ' pin serial transmitter
    CON
    ''  xxxxxx - xx xx xx xx ... <cr>  DOWNLOAD:  to cog/lut/hub {addr1} following {byte(s)}
    ''  xxxxxx [.xxxxxx] L <cr>        LIST:      from cog/lut/hub {addr1} to < {addr2}
    ''  Rffffffffxxx<cr>               RUN:       Run file from SD
    ''              LMM DEBUGGER - lmm_f CALL Modes...(not all modes supported)
    DAT
                    orgh    0
                    org     0
    entry
    ' this code displays a version string (it's not required)
                    call    #_HubTxString
                    jmp     #.loop
                    fit     $1F0
    ''=======[ ^^^^^ End of COG Variables ^^^^^ ]===================================
    edited 2018-10-25 04:58
    ROM SD Code/Routines
    Here are the Monitor subroutine entry points (not all are callable directly)
    CON                '' +--------------------------------------------------------------------------+
                       '' | Cluso's Minimal SD Boot Test for P2  (c)2012-2018 "Cluso99" (Ray Rodrick)|
                         _csum    = ("P" + "r"<<8 + "o"<<16 + "p"<<24)  ' "Prop" checksum (reversed)
                         _csum2   = ("P" + "r"<<8 + "o"<<16 + "P"<<24)  ' "ProP" checksum (reversed)
                         _fname1a = ("_" + "B"<<8 + "O"<<16 + "O"<<24)  '\\ filename...
                         _fname1b = ("T" + "_"<<8 + "P"<<16 + "2"<<24)  '||   8.3 +$00
                         _fname1c = ("B" + "I"<<8 + "X"<<16 + $00<<24)  '//
                         _fname2c = ("B" + "I"<<8 + "Y"<<16 + $00<<24)  '//
                         mbr_begin  = 0                 ' first sector of disk $0000_0000
                       '       COG & LUT & HUB ADDRESSES
                         hubdata       = $0_0000        ' expands up   (512byte sectors)
                         max_size      = (512-16)*1024  ' max file_size(bytes) that can be loaded
                         cog_start0    = $000           ' cog code start
                         cog_len       = 512-16         ' cog code length
                         cog_len80     = 512/4          ' 512 bytes (sector)
    _Start_SDcard      = $fc560     ' initialise & read CSD/CID
    _Run_SDfile        = $fc578     ' initialise & read CSD/CID
    _Load_SDfile       = $fc590     ' initialise & read CSD/CID
    _SDcard_Init       = $fc5a4     ' init hub data ptr=$0
    _readMBR1          = $fc6dc     ' do not load/run MBR/VOL code
    _readMBR           = $fc6e0     ' VBR/MBR = SECTOR 0
    _readDIR           = $fc810     ' copy _fname1 -> fname
    _searchDIR         = $fc840     ' 12th char must be $00
    _validateCSUM      = $fc8d0     ' check long at $17C
    _readFILE          = $fc900     ' DAT SECTOR#
    _readnxtSECTOR     = $fc944     ' next sector#
    _readnxtSLOT       = $fc948     ' next data slot
    _readSECTOR        = $fc950     ' sector#
    _readREG           = $fc974     ' CMD9,10: CSD,CID register
    _readBLOCK         = $fc97c     ' CMD17: PAR=sector, 512 bytes
    _cmdRZA41          = $fc9bc     ' CMD55:       R1 response
    _cmdRZtoken        = $fc9bc     ' CMD9,10,17,24: R1+$FE response
    _cmdR1R3           = $fc9c4     ' CMD58:    R1+R3 response
    _cmdR1R7           = $fc9c4     ' CMD8:     R1+R7 response
    _cmdR1             = $fc9c4     ' CMD0,A41,16: R1 response
    _cmdxx             = $fc9c8     '
    _getreply          = $fc9f8     ' recv R1 byte
    _recvlong          = $fca30     ' call here to Recv a Long (+send 1's)
    _sendlong          = $fca34     ' call here to Send a Long (long=32bits)
    _sendFF            = $fca3c     ' call here to Send $FF Byte
    _recvbyte          = $fca3c     ' call here to Recv a Byte (+send 1's)
    _sendbyte          = $fca40     ' call here to Send a Byte (msbit first)
    _sendrecv          = $fca48     ' clear reply
    _fail              = $fca74     ' C & NZ = fail
    In addition to this, you need to have these COG registers available. You can define by CON or reserved as registers in your code (both methods given)
                       ''============[ COG VARIABLES $1C0-$1DF - SD BOOT]==============================
    cmdout             = $1c0          ' The 8b CMDxx | $40
    cmdpar             = $1c1          ' The 32b parameters
    cmdcrc             = $1c2          ' The 8b CRC (must be valid for CMD0 & CMD8)
    cmdpar2            = $1c3          ' SDV1=$0, SDV2=$40000000
    cmdtype            = $1c4          ' reply is R1=1, R3=3, R7=7, else 0
    reply              = $1c5          ' R1 reply (moved to replyR1 when R3/R7 32b reply here)
    replyR1            = $1c6          ' R1 reply (8b saved when R3/R7 32b reply follows)
    dataout            = $1c7          ' 8/32 bit data being shifted out
    bytescnt           = $1c8          ' #bytes to send/recv
    bitscnt            = $1c9          ' #bits to be shifted in/out
    ctr1               = $1ca
    timeout            = $1cb          ' = starttime + delay
    spare              = $1cc
    skiprun            = $1cd          ' 1= skip load/run mbr/vol & load/no-run fname
    blocksh            = $1ce          '/ block shift 0/9 bits
    clustersh          = $1cf          ' sectors/cluster SHL 'n' bits
    vol_begin          = $1d0          ' Ptn0: first sector of PTN
    fsi_begin          = $1d1          ' Ptn0:       sector of file system info
    fat_begin          = $1d2          ' Ptn0: first sector of FAT table
    dir_begin          = $1d3          ' Ptn0: first sector of DATA is DIR table
    dat_begin          = $1d4          ' Ptn0: first sector of file's DATA
    ptn_size           = $1d5          '       file-size 32KB = 64<<9 sectors
    _bufad             = $1d6
    _blocknr           = $1d7
    _sectors           = $1d8
    _entries           = $1d9
    bufad              = $1da          ' ptr sector buffer
    blocknr            = $1db          ' sector#
    fname              = $1dc          ' 8+3+1
    _hubdata           = $1df
                    long    $0[$1C0-$]        ' fill with zeros (if any)
    ctr1            res     1
    spare           res     1
    _bufad          res     1
    _blocknr        res     1
    _sectors        res     1
    _entries        res     1
    fname           res     3                       ' 8+3+1
    _hubdata        res     1
                    fit     $1E0
    Reserved for sample code using the ROM SD code
    Reserved for sample SD Boot sectors and files
  • Does SD boot work? Or will it require the re-spin?
  • ke4pjw wrote: »
    Yes, it works. From TAQOZ you can even write directly to a file or the mbr. I will post up some samples soon.
    Peter has SD working. I'm in the process of getting P1 spin code working so I can port my Prop OS to P2 simply.
