P2-ROM: Booter, Serial, Flash, SD card, Monitor and TAQOZ features and operation - Page 3 — Parallax Forums
13
    edited 2018-06-02 01:14
    I think you and Peter did fine work Cluso. Well done.
  • evanhevanh Posts: 17,017
    edited 2018-06-02 12:14
    I've got my uSD adaptor plugged into the Prop123 board now. And it works! That's always good. :)
    all_cogs_blink.obj boots in a blink. The 442 KB file of VGA_640_x_480_16bpp.obj takes about 9 seconds to boot.
    I've noticed what appears to be a bug. The FAT32 filename search for _BOOT_P2.BIX only works for the first entry of the directory. Not much of a search if it always has to be the first entry.
    What? No it searches until it's found, limited by the first cluster or the first blank $00 entry. If not found it's suppose to search for _BOOT_P2.BIY
    Minor correction, it works when it is the first non-empty entry. Your null detect might be opposite to intended.
    FPGA image used is Prop123_A9_Prop2_8cogs_v32i.rbf
    evanh wrote: »
    evan,
    I think you need to do further testing. My files are not anywhere near the start of my directory. There are 16 directory entries per sector, and in a normal 32KB cluster for FAT32 there will be 64 sectors scanned. That means a possible 1024 entries. I terminate if a long of $00000000 is found. This is the indication of the end of the directory entries. When an entry is deleted the first character of the entry has the top bit $80 set. The remaining filename is left intact. This is how undelete programs work.
    There are however other entries in the directory, such as directories (folders if you like) and system entries, and long filename entries. These are all skipped.
    Perhaps you need to look at the SD card with a hex disk program. Sorry, forget which one I use ATM.
    Don't forget, you can use the Monitor to load or run any file.
    Also, don't forget that my file names are case sensitive.
    Oh, no I made too much assumption again. Linux doesn't always fill the first empty entry when adding a new filename. There was filled then unfilled before the _BOOT_P2.BIX entry.
    Could be tricky in the future but you are right about the searching.
    edited 2018-06-02 13:56
    Gee! That's a pretty big failing in linux :(
    BTW While I only check for one cluster, IIRC the directory can be 2 clusters long. I figured 1024 entries was sufficient.
    I was disappointed about the proprietary and complex nature of exFAT. Hopefully someone will overturn MS patents. IMHO that was old 70's technology and nothing new. Or come up with FAT64.
    More specifically, renaming fills different entries from copying. Any renaming seems to reserve empty entries.
    Cluso99 wrote: »
    Hey, I wouldn't call that a fail when you are cheating somewhat. It's no different to deleting an extraneous file. Gaps in the entry list are hardly unheard of.
    evanh wrote: »
    Cluso99 wrote: »
    No. There are not supposed to be blank entries in the directory. That is one of the reasons for the way files are deleted.
    Linux is a full blown os. I think shortcuts in a micro os isn't exactly in the same realm. I am pretty sure if Windows did that there would be a lot of complaints.
    Anyway, that's how it is. There was time for testing and suggestions and complaints. Those days passed with only a handful of people testing.
    Cluso99 wrote: »
    Best not to be saying that. There hasn't been much time at all.
    Cluso99 wrote: »
    Windoze will leave blank entries upon file deletions.
    evanh wrote: »
    Cluso99 wrote: »
    No it doesn't. It marked the first character with OR $80. That's not a blank entry, it's a deleted entry.
    I haven't looked at the raw data. I assumed that to be the same thing. I have no idea what Linux does there.
    evanh wrote: »
    Cluso99 wrote: »
    Sorry, but I am quite annoyed at the lack of help in testing. I (and Peter) pleaded for testers and there was deathly silence!!!
    evanh wrote: »
    What? You haven't looked! I am dumbfounded
    Don't be so rushed. There really hasn't been much time to test the new stuff.
    I've had a quick look at the raw data, there is MSbit markers present like you say, so I'm not yet sure why the search is failing. It looks a bit like there is some unicode for the extended filenames ...
    hexdump took some digging to make work. Thank goodness for google and stackexchange.
    Here's a selected dump of a FAT32 root that is booting fine:
    00eb8000  41444154 41313620 20202008 00007d96 c24cc24c 00007d96 c24c0000 00000000 ADATA16    ...}..L.L..}..L......
    00eb8020  4269006e 006b002e 006f000f 002d6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...-b.j...............
    00eb8040  0130002e 0061006c 006c000f 002d5f00 63006f00 67007300 5f000000 62006c00 .0...a.l.l...-_.c.o.g.s._...b.l.
    00eb8060  30414c4c 5f437e31 4f424a20 0064fb6d c24cc24c 0000fb6d c24ced01 40000000 0ALL_C~1OBJ .d.m.L.L...m.L..@...
    00eb8080  4269006e 006b002e 006f000f 006d6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...mb.j...............
    00eb80a0  0131002e 0061006c 006c000f 006d5f00 63006f00 67007300 5f000000 62006c00 .1...a.l.l...m_.c.o.g.s._...b.l.
    00eb80c0  31414c4c 5f437e31 4f424a20 0000006e c24cc24c 0000006e c24cee01 40000000 1ALL_C~1OBJ ...n.L.L...n.L..@...
    00eb80e0  4269006e 006b002e 006f000f 00b46200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o....b.j...............
    00eb8100  0132002e 0061006c 006c000f 00b45f00 63006f00 67007300 5f000000 62006c00 .2...a.l.l...._.c.o.g.s._...b.l.
    00eb8120  32414c4c 5f437e31 4f424a20 0064016e c24cc24c 0000016e c24cef01 40000000 2ALL_C~1OBJ .d.n.L.L...n.L..@...
    00eb8140  5f424f4f 545f5032 42494120 0064086e c24cc24c 0000086e c24cf201 40000000 _BOOT_P2BIA .d.n.L.L...n.L..@...
    00eb8160  e533002e 0061006c 006c000f 00f45f00 63006f00 67007300 5f000000 62006c00 .3...a.l.l...._.c.o.g.s._...b.l.
    00eb8180  e5414c4c 5f437e31 4f424a20 0000046e c24cc24c 0000046e c24cf001 40000000 .ALL_C~1OBJ ...n.L.L...n.L..@...
    00eb81a0  5f424f4f 545f5032 42495920 0000046e c24cc24c 0000046e c24cf001 40000000 _BOOT_P2BIY ...n.L.L...n.L..@...
    00eb81c0  5f424f4f 545f5032 42495a20 0000166c c24cc24c 0000355c c24ce901 40000000 _BOOT_P2BIZ ...l.L.L..5\.L..@...
    00eb81e0  5f424f4f 545f5032 42495820 0064756a c24cc24c 0000355c c24ce101 40000000 _BOOT_P2BIX .duj.L.L..5\.L..@...
    00eb8200  4269006e 006b002e 006f000f 002c6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...,b.j...............
    00eb8220  0134002e 0061006c 006c000f 002c5f00 63006f00 67007300 5f000000 62006c00 .4...a.l.l...,_.c.o.g.s._...b.l.
    00eb8240  34414c4c 5f437e31 4f424a20 0000aa6c c24cc24c 0000355c c24cec01 40000000 4ALL_C~1OBJ ...l.L.L..5\.L..@...
    00eb8260  4269006e 006b002e 006f000f 006e6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...nb.j...............
    00eb8280  0135002e 0061006c 006c000f 006e5f00 63006f00 67007300 5f000000 62006c00 .5...a.l.l...n_.c.o.g.s._...b.l.
    00eb82a0  35414c4c 5f437e31 4f424a20 0000066e c24cc24c 0000066e c24cf101 40000000 5ALL_C~1OBJ ...n.L.L...n.L..@...
    00eb82c0  e569006e 006b002e 006f000f 00b36200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o....b.j...............
    00eb82e0  e536002e 0061006c 006c000f 00b35f00 63006f00 67007300 5f000000 62006c00 .6...a.l.l...._.c.o.g.s._...b.l.
    00eb8300  e5414c4c 5f437e31 4f424a20 0064086e c24cc24c 0000086e c24cf201 40000000 .ALL_C~1OBJ .d.n.L.L...n.L..@...
    00eb8320  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................
    And here's one that doesn't boot:
    00eb8020  e569006e 006b002e 006f000f 002d6200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o...-b.j...............
    00eb8040  e530002e 0061006c 006c000f 002d5f00 63006f00 67007300 5f000000 62006c00 .0...a.l.l...-_.c.o.g.s._...b.l.
    00eb8060  e5414c4c 5f437e31 4f424a20 0064fb6d c24cc24c 0000fb6d c24ced01 40000000 .ALL_C~1OBJ .d.m.L.L...m.L..@...
    00eb80c0  31414c4c 5f437e31 4f424a20 0064fb6d c24cc24c 0000fb6d c24ced01 40000000 1ALL_C~1OBJ .d.m.L.L...m.L..@...
    00eb80e0  e569006e 006b002e 006f000f 00b46200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o....b.j...............
    00eb8100  e532002e 0061006c 006c000f 00b45f00 63006f00 67007300 5f000000 62006c00 .2...a.l.l...._.c.o.g.s._...b.l.
    00eb8120  e5414c4c 5f437e31 4f424a20 0064016e c24cc24c 0000016e c24cef01 40000000 .ALL_C~1OBJ .d.n.L.L...n.L..@...
    Okay, looks like I totally shouldn't have been using any long filenames. Everything cleans up nicely when I start over and only use the 8.3 naming.
    Here's what happened by reformatting then adding a single long filename as the first entry, then deleting it, then adding _BOOT_P2.PIX followed by duplicate BIY and BIZ files:
    evanh@controlled:~/hoard/coding/prop2/testing$ sudo hexdump /dev/sdc1 -s $((0x00eb8000)) -n 4096 -f hexdump.fmt
    00eb8000  41444154 41313620 20202008 00008723 c34cc34c 00008723 c34c0000 00000000 ADATA16    ....#.L.L...#.L......
    00eb8020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................
    00eb8020  426b002e 006f0062 006a000f 00cd0000 ffffffff ffffffff ffff0000 ffffffff Bk...o.b.j......................
    00eb8040  0161006c 006c005f 0063000f 00cd6f00 67007300 5f006200 6c000000 69006e00 .a.l.l._.c....o.g.s._.b.l...i.n.
    00eb8060  414c4c5f 434f7e31 4f424a20 00647085 c24cc24c 00007085 c24c0700 40000000 ALL_CO~1OBJ .dp..L.L..p..L..@...
    00eb8080  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................
    00eb8020  e56b002e 006f0062 006a000f 00cd0000 ffffffff ffffffff ffff0000 ffffffff .k...o.b.j......................
    00eb8040  e561006c 006c005f 0063000f 00cd6f00 67007300 5f006200 6c000000 69006e00 .a.l.l._.c....o.g.s._.b.l...i.n.
    00eb8060  e54c4c5f 434f7e31 4f424a20 00647085 c24cc24c 00007085 c24c0700 40000000 .LL_CO~1OBJ .dp..L.L..p..L..@...
    00eb8020  5f424f4f 545f5032 42495820 00647b85 c24cc24c 00007b85 c24c0800 40000000 _BOOT_P2BIX .d{..L.L..{..L..@...
    00eb8020  5f424f4f 545f5032 42495820 00647b85 c24cc24c 0000355c c24c0800 40000000 _BOOT_P2BIX .d{..L.L..5\.L..@...
    00eb8040  5f424f4f 545f5032 42495920 00648d85 c24cc24c 00008d85 c24c0900 40000000 _BOOT_P2BIY .d...L.L.....L..@...
    00eb8060  5f424f4f 545f5032 42495a20 00648f85 c24cc24c 00008f85 c24c0a00 40000000 _BOOT_P2BIZ .d...L.L.....L..@...
    edited 2018-06-02 17:02
    Here's hexdump's format file for anyone interested:
    1/1 "%08_ax  "
    4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x" " " 4/1 "%02x"
    " " 32/1 "%_p" "\n"
    Cluso,
    Sorry if I was a tad behind on the requirements. I certainly haven't read everything.
    I've just noticed the Prop123 board also requires a minimum of 10 seconds of power down to boot cleanly. This could easily explain some of my earlier confusion over what combinations worked or not. I've not had to deal with this when using the comport loading.
    Is there any debug for booting?
    edited 2018-06-02 18:26
    evanh wrote: »
    ... minimum of 10 seconds ...
    Bah! Or not. Sometimes it just doesn't boot. Most of the time it's happy with only a couple of seconds power off.
    EDIT: I'm doing <0.5 second power downs and it's about 1-in-3 attempts don't boot.
    EDIT2: Ah-ha! Dug up a terminal emulator and got it toggling the DTR line for resets instead of doing power cycles. Guess what? Perfect reboots as fast as I like. Pop out the SD card and the reboot doesn't load. Put the SD card back in and perfect rapid reboots again. Happy chappy. :)
  • Button PB0 does a reset on the A9 P123
  • jmgjmg Posts: 15,198
    evanh wrote: »
    I'm not quite following what works/does not work, and the trigger conditions here.
    Can you summarize the rules around long files names and formatting steps ?
    evanh wrote: »
    evanh wrote: »
    Does this mean the FPGA loading side is not 100% reliable, but gets more reliable with a longer power-off ?
    I've seen some parts specify a minimum Vcc before their POR ramp works, and that can be << 1V. You could meter some supplies to see what residual level is needed to get more reliable ?
    edited 2018-06-03 02:08
    If you need to diagnose any SD problems then pop on over to TAQOZ. For instance, if you wanted to hex dump your root directory you can mount the card, fopen the directory as a file, and then hex dump it etc.
    Try this - you can even type all on one line if you like
    MOUNT
    @ROOT FOPEN
    0 $200 SD DUMP
    Here is the one that you said did not work, decoded
                                                vv AND $D8
    00eb8000          41 444154 41313620 202020 08 vol     00007d96 c24cc24c 00007d96 c24c0000 00000000 ADATA16    ...}..L.L..}..L......
    00eb8020  deleted e5 69006e 006b002e 006f00 0f long    002d6200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o...-b.j...............
    00eb8040  deleted e5 30002e 0061006c 006c00 0f long    002d5f00 63006f00 67007300 5f000000 62006c00 .0...a.l.l...-_.c.o.g.s._...b.l.
    00eb8060  deleted e5 414c4c 5f437e31 4f424a 20 arch    0064fb6d c24cc24c 0000fb6d c24ced01 40000000 .ALL_C~1OBJ .d.m.L.L...m.L..@...
    00eb8080          42 69006e 006b002e 006f00 0f long    006d6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...mb.j...............
    00eb80a0          01 31002e 0061006c 006c00 0f long    006d5f00 63006f00 67007300 5f000000 62006c00 .1...a.l.l...m_.c.o.g.s._...b.l.
    00eb80c0          31 414c4c 5f437e31 4f424a 20 arch    0064fb6d c24cc24c 0000fb6d c24ced01 40000000 1ALL_C~1OBJ .d.m.L.L...m.L..@...
    00eb80e0  deleted e5 69006e 006b002e 006f00 0f long    00b46200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o....b.j...............
    00eb8100  deleted e5 32002e 0061006c 006c00 0f long    00b45f00 63006f00 67007300 5f000000 62006c00 .2...a.l.l...._.c.o.g.s._...b.l.
    00eb8120  deleted e5 414c4c 5f437e31 4f424a 20 arch    0064016e c24cc24c 0000016e c24cef01 40000000 .ALL_C~1OBJ .d.n.L.L...n.L..@...
    00eb8140          5f 424f4f 545f5032 424941 20 arch    0064086e c24cc24c 0000086e c24cf201 40000000 _BOOT_P2BIA .d.n.L.L...n.L..@...
    00eb8160  deleted e5 33002e 0061006c 006c00 0f long    00f45f00 63006f00 67007300 5f000000 62006c00 .3...a.l.l...._.c.o.g.s._...b.l.
    00eb8180  deleted e5 414c4c 5f437e31 4f424a 20 arch    0000046e c24cc24c 0000046e c24cf001 40000000 .ALL_C~1OBJ ...n.L.L...n.L..@...
    00eb81a0          5f 424f4f 545f5032 424959 20 arch    0000046e c24cc24c 0000046e c24cf001 40000000 _BOOT_P2BIY ...n.L.L...n.L..@...
    00eb81c0          5f 424f4f 545f5032 42495a 20 arch    0000166c c24cc24c 0000355c c24ce901 40000000 _BOOT_P2BIZ ...l.L.L..5\.L..@...
    00eb81e0          5f 424f4f 545f5032 424958 20 arch    0064756a c24cc24c 0000355c c24ce101 40000000 _BOOT_P2BIX .duj.L.L..5\.L..@...
    00eb8200          42 69006e 006b002e 006f00 0f long    002c6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...,b.j...............
    00eb8220          01 34002e 0061006c 006c00 0f long    002c5f00 63006f00 67007300 5f000000 62006c00 .4...a.l.l...,_.c.o.g.s._...b.l.
    00eb8240          34 414c4c 5f437e31 4f424a 20 arch    0000aa6c c24cc24c 0000355c c24cec01 40000000 4ALL_C~1OBJ ...l.L.L..5\.L..@...
    00eb8260          42 69006e 006b002e 006f00 0f long    006e6200 6a000000 ffffffff ffff0000 ffffffff Bi.n.k...o...nb.j...............
    00eb8280          01 35002e 0061006c 006c00 0f long    006e5f00 63006f00 67007300 5f000000 62006c00 .5...a.l.l...n_.c.o.g.s._...b.l.
    00eb82a0          35 414c4c 5f437e31 4f424a 20 arch    0000066e c24cc24c 0000066e c24cf101 40000000 5ALL_C~1OBJ ...n.L.L...n.L..@...
    00eb82c0  deleted e5 69006e 006b002e 006f00 0f long    00b36200 6a000000 ffffffff ffff0000 ffffffff .i.n.k...o....b.j...............
    00eb82e0  deleted e5 36002e 0061006c 006c00 0f long    00b35f00 63006f00 67007300 5f000000 62006c00 .6...a.l.l...._.c.o.g.s._...b.l.
    00eb8300  deleted e5 414c4c 5f437e31 4f424a 20 arch    0064086e c24cc24c 0000086e c24cf201 40000000 .ALL_C~1OBJ .d.n.L.L...n.L..@...
    00eb8320          00 000000 00000000 000000 00 -end-   00000000 00000000 00000000 00000000 00000000 ................................
    And here is my code
    _searchDIR      and     fname+2,          ##$00FFFFFF   ' 12th char must be $00
                    mov     _blocknr,         dir_begin     ' DIR SECTOR#
                    decod   _sectors,         clustersh     ' max sectors to scan (1 cluster)
    .search_next    call    #@_readSECTOR                   ' read sector
      '+ Walk Directory: (read DIR sectors)                                          +
      '+ 16 x 32byte DIR(fname) entries per DIR sector                               +
      '+              +$00[1] = $00 = empty                                          +
      '+                     => $80 = deleted file                                   +
      '+      search  +$00[11] = 8.3 filename                                        +
      '+      verify  +$0B[1]  = FileAttrib                 AND $D8,check $00        +
      '+         $01=read,02=hidden,04=system,08=volume,0F=longfile,10=dir,20=archive+
      '+      calc    +$14[2]  = FAT32: 1st cluster# HI     -\-> cluster             +
      '+      calc    +$1A[2]  = FAT32: 1st cluster# LO     -/                       +
      '+      calc    +$1C[4]  = FAT32: FileSize in bytes   --> file_size            +
      '+      calc    dat_begin = dir_begin + ((cluster-2)<<6)                       +
      ' scan dir sector for files...
    .walk_dir         mov     _entries,         #16           ' 16*32byte file entries
                      mov     bufad,            _bufad        ' dir hub locn
      ' scan this sector for filename entry...
    .scan             rdlong  reply,            bufad         '\ check this entry
                      cmp     reply,            #0        wz  '|  $0 = empty?
              if_ne   jmp     #.check                         '|  n:
            _RET_   MODZ      _clr                        wz  '/ return "NZ" = not found
    .check            cmp     reply,            fname     wz  '| check fname...
                      add     bufad,            #4            '|
                      rdlong  reply,            bufad         '|
              if_e    cmp     reply,            fname+1   wz  '|
                      add     bufad,            #4            '|
                      and     reply,            ##$D8FFFFFF   '|  check atts b7+6+4+3
              if_e    cmp     reply,            fname+2   wz  '|
              if_e    jmp     #.found                         '/  found!
                      add     bufad,            #(32-8)       ' next entry
                      djnz    _entries,         #.scan        ' "NZ" not found this sector
                    add     _blocknr,         #1            ' next sector#
            _RET_   djnz    _sectors,         #.search_next ' return "NZ" = not found
    I read the first long, check that it is not $00000000 (an unused entry signifying end of directory)
    Then I compare the first long with the first 4 character of the filename. This automatically discards any deleted files (with an $80 bit set) as well.
    Then i read the next long and compare with the next 4 chars of the filename.
    Then I read the next (3rd) long, and the last char with $D8 which leaves the system and dir bits (removes read/hidden/system/archive bits). The filename 12th char has already been made $00. Then I compare.
    If all 3 compares passed, then it is the filename I am looking for. If not, try the next until $00000000 or the first cluster is done.
    So your file should have been found.
    Thanks for the effort there Cluso. It's all resolved I feel. That one was probably okay if I had tried it again. Biggest issue was the unreliable power ups. Followed by confusion over filename entry ordering due to the long filenames gobbling three entries each.
