PASM waitpeq not working as expected
in Propeller 1
The code gates one pin of 500Hz oscillation with another pin (high/low).
The SPIN code works with `waitpeq(|<TRIG1, |<TRIG1, 0)`.
However the PASM code doesn't. T_PIN stays high, even though R_PIN changes.
Comment out `waitpeq R_PIN, R_PIN` makes T_PIN toggles at 500Hz.
CON _clkmode = xtal1 + pll16x ' Crystal and PLL settings. _xinfreq = 5_000_000 ' 5 MHz crystal (5 MHz x 16 = 80 MHz). CON TRIG1 = 20 PUB main cognew(@T1,0) dira[22]~~ repeat waitpeq(|<TRIG1, |<TRIG1, 0) outa[22] := 0 waitcnt(clkfreq/1000 + cnt) outa[22] := 1 waitcnt(clkfreq/1000 + cnt) DAT org T1 'SET AS OUPUT OR dira, T_PIN mov time, cnt add time, delay_t loop waitpeq R_PIN, R_PIN or outa, T_PIN waitcnt time, delay_t andn outa, T_PIN waitcnt time, delay_t jmp #loop R_PIN long |< 20 T_PIN long |< 21 delay_t long 1_000 time res 1
after the or outa,T_Pin.
The CNT increment in the Spin loop is 2 * 80MHz/1000 == 160K, but the CNT increment in PASM is only 2 * 1000 = 2K,
Change delay_t to long 80000.
Thanks Phil. I fell into the WAITCNT trap. You saved me there.
