Can anyone recommend an online USA supplier for round abs sheets ?
I like very much the Arlo KIT, so i got inspired ... and I would like to build a smaller 2WD bot 12-14" diameter.
I found a few suppliers for square abs sheets, but no round cuts.
Any tips will be appreciated
Cutting out circles is pretty easy if you have most any stationary motorized tool like a router table. Cut a 12" square piece, find the center, and drill a hole. Use the hole as a center for mounting the piece 6" away from the cutting bit/blade. Slowly turn the plastic into the tool.
Tools: SimpleIde and Visual Studio
@Kwinn:
The ABS plates are 0.19" (5mm) tick otherwise they will bend easily, do you think hand tools can do the job ?
https://www.walmart.com/ip/Kitchen-Household-Plastic-Round-Shape-Mats-Cutting-Chopping-Boards-Block-White/181170019
Me, I'm old school, I'd start with a pair of compasess to scribe a circle. A hacksaw/fret saw to get it as round as possible. Clean it up with a file and sandpaper.
Kitchen Round shape is a good start. I hope to get the discount price
sometime ago i tried to modeling a tick abs sheet, i used hand saw and a file, after spending some time, it was a big mess... maybe is me i'm not used to work with hardware tools
Try an arts and crafts store but be prepared for sticker shock.
If you happen to be in California somebody like Tap Plastics would be glad to cut a round sheet for you, for a small fee.
https://www.tapplastics.com
I was amazed to find they have a store that can do that, right in the middle of the main street of Mountain View, which is otherwise nothing but bars and restaurants. But hey, those bars and restaurants need plastic signs and such.
There must be similar businesses the world over.
Thanks, I'll contact them.
Impressive numbers: 20 stores: 15 in CA !
https://www.amazon.com/American-Wood-Round-Plywood-Table/dp/B001FA3SIA
Right, erco?
Got one just down the street. Use them all the time.
Second was "Mr Metric" in San Jose, the only place I could find metric nuts and bolts in a hurry.
http://www.mrmetric.com
Edit: By the way, how come it is so hard to buy silicon in "Silicon Valley" ?
+1
The 1/4" thick sheets of sub floor plywood would make great robotics platforms. Put on a coat of varnish or lacquer and you would have a pretty spiffy bot.
A link:
https://www.acrylic-designs.com/
I thought about that when in Tap Plastics, Mountain View. They have a stack of offcuts in the store, but they want dollars for them...
I know a few people that use kitchen cutting boards for all of their robot platforms because they don't easy access to heavy tools. I frequent Tap Plastics for most of my acrylic needs. I also source material from McMaster and InterState Plastics.
Yep, plywood is good, you KNOW I'm a fan. For the OP I'd say go Gordon's suggested route, that $12 round cutting board is close to perfect. I'm all for making best use of found parts. You can't glue to that HDPE, but it holds a thread very well and is self-lubricating for a tap or self-tapping screws. Only TWO left? ptiago, you better nab BOTH of them before I do! Yes, really!
OTOH, ABS or plain old HIPS glues beautifully using cyano or solvent bonding. Great for all sorts of fabricating. I'd go for 1/4" thick myself, very strong stuff. Sandable and paintable too.
