Ping Ultrasonic distance sensor life expectancy
I have a project I'm working on called Sonic Dip Stick that measures the amount of oil I have in my oil tank. Right now I ping the oil every 24 hours, but I was wondering what is the recommended time between pings over an indefinite time before I wear the device out?
Obviously I don't need to check the oil level more than a couple times a day for a decent oil usage statistic, however I have come up with a new requirement.
I'd like to place a display outside the house (the tank is inside) where the supplier fills the tank. I'd like to be able to detect a rapid change in oil level so that it can be presented on the display. The supplier will see an accurate oil level as he is filling. But I also don't want to over work the sensor by taking pointless measurements when no activity is occurring within the tank. Also, I'd like to not require the use of some other sensor for detecting motion within the tank or anything like that.
So again, bottom line, how frequent can I take measurements for an indefinite period without putting undue stress on the sensor?
In any case, a few dozen pings a day for the life of your house shouldn't be too much to expect. But like Erco says, it's not exactly a healthy environment inside the tank.
https://www.parallax.com/search?search_api_views_fulltext=eTape
If so, and your display shows remaining gallons, it should be easy to pump the difference. I feel like the fumes are going to be more of a wear-and-tear issue than polling it too much, but that's a guess.
The issue is that fuel oil is like any distillate and inside the tank there are fumes from the volatile organic compounds of the liquid. These fumes A ) can corrode or deteriorate materials not suitably protected and B ) give rise to fire danger in the case of a short. Most fuel oils have a low flash point.
You might be able to pull it off if you drilled two holes in the cap and poked the sender and receiver transducers through it, then sealing if off so that no part of the circuit board is exposed to the fumes. This doesn't mean there are no concerns of a short in the transducers. I don't know the design of those, but to make the pinging worthwhile, there needs to be some amount of current to the sender element. The eTape idea seems a lot safer to me.
