Onshape - a very nice free parametric 3D modeler
Following the discussions on 3d printer threads i would like to point you to Onshape: onshape.com
It is a complete and professional parametric 3D modeler, that compares (according to the website) to big guys like Solidworks or Inventor.
The novelty is it works on line only, so no installation required on the PC, only a recent browser is required.
On phones and tablet it works using a dedicated app. Mind on the mobile devices it's not a simple viewer, you can work and model on them.
Finally there is a free version with almost all the featues (with some revision/control exceptions). Only limitation is with a free account the models are public.
I started using it to create some adapters to be 3d printed and I like it very much.
Massimo
Massimo
Bean
If you've got a modeler license that perpetual, keep hold of it. Those are going away rapidly. I suggest getting it into a VM now.
That said, if you can allow your design to be public, OnShape is very capable. Made by the same crew (mostly) that did Solidworks. Interestingly, they chose a git style of revision control. Very cool.
It's a Parasolid engine, not a mesh modeler like Autodesk 360 is. This may matter, if you are doing CNC work on the finished models.
Both 360 and OnShape produce nice STL files.
I have done a respectable model or two on my Note 8 phone. Spiffy!
What I'll do is create, export, delete. I often don't need history.
I had a perpetual license of Alibre, but perpetual is not really meaning perpetual....
I like your VM suggestion! Never tought of that!
Massimo
