[Solved] Wrong Part or Error in Spin?
Hi all, I just received this rotary encoder that states it 600 pulses per rotation but after writing some spin to use "Quadrature Encoder.spin" from the Propeller tool library, I am getting 2,400 pulses per rotation. Am I doing something wrong or did I get a better part than what I ordered? I don't think "Quadrature Encoder.spin" is faulty or it would have been fixed years ago... I tested if it was just counting by four but I am able to increment/decrement by one and two if I am careful and go extremely slow.
Edit: Changed title to solved.
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
VAR
long pos[2]
OBJ
qe : "Quadrature Encoder"
pst : "Parallax Serial Terminal"
PUB Main
pst.Start(115200)
pst.clear
qe.Start(0,1,1,@pos)
repeat
pst.Dec(pos)
pst.Str(string(" --- "))
pst.Dec( qe.ReadDelta(0))
pst.Newline
Thanks for the information, I was suspecting that it was counting the edges of the pulses due to the fact that I could count by one with it.
