Trouble passing variables to FullDuplexSerial.spin
in Propeller 1
I am a first time to user. I have downloaded a SPIN file FullDuplexSerial.spin from the library , onto my Parallax propeller prototype board. I have loaded the code into Propeller IDE, it compiles and loads into board, but when I provide input for “PUB Start(rxPin, txPin, mode, baudrate) : okay “ the compile fails. I did try to add this line before the PUB line above “Start (31, 30, 0, 9_600)“ what am I doing wrong, any suggestions.
'Pub main
' Serial.Start(31, 30, 0, 9_600)
'Start(31, 30, 0, 9_600) : okay
'PUB Start(31, 30, 0, 9_600) : okay
Regards
'Pub main
Regards
OBJ 'in leiu of Parallax Serial Terminal, FullDuplexSerial is being used to communicate with the terminal serial : "FullDuplexSerial" PUB Main {{ Starts execution of FullDuplexSerialTest1.spin This is a very simple test. It starts the object, waits 1 second, prints two lines to the terminal, waits 1 more second, then shuts down. Set your terminal to a baud rate of 9600 baud to see the output. parameters: none return: none example usage: N/A - executes on startup }} 'start the FullDuplexSerial object serial.Start(31, 30, %0000, 9_600) 'requires 1 cog for operation waitcnt(cnt + (1 * clkfreq)) 'wait 1 second for the serial object to start serial.Str(STRING("Testing the FullDuplexSerial object.")) 'print a test string serial.Tx($0D) 'print a new line serial.Str(STRING("All Done!")) waitcnt(cnt + (1 * clkfreq)) 'wait 1 second for the serial object to finish printing serial.Stop 'Stop the objectobj ' main ' * master Spin cog time : "jm_time_80" ' timing and delays (80MHz) prng : "jm_prng" ' pseudo-random number generator io : "jm_io_basic" ' essential io term : "jm_fullduplexserial" ' * serial IO for terminal ' * uses cog when loadedI have a separate method called setup that handles the initialzing of these objects.pub setup '' Setup IO and objects for application time.start ' setup timing & delays prng.seed(-cnt, -cnt ~> 2, $EA7_BEEF, cnt <- 2, cnt) ' seed randomizer io.start(0, 0) ' clear all pins (master cog) term.start(RX1, TX1, %0000, BR_TERM) ' start serial for terminal *After calling setup my program is free to fly.I have attached an archive of my standard template as this may help you get up and running. Note that I use a personal derivative of FullDuplexSerial -- the interface is the same, it just has a few more methods.
You are the best, thank you very much for your help.
I did download FullDuplexSerial_Test1.spin with no problem into the board but I did not get anything back while I had the terminal up.
Then I saw FullDuplexSerial_Test2.Spin and load\compile\Download to board\Came up nicely and print text on terminal and ask me to type and echo back.
I am very happy. Now I need to look why test1 did not work.
Then continue with looking at the RX buffer content. and process the data I receive.
Again thank you and have a great day
Regards
Akbar
It seems the Test1 example waits 1 second and then prints something and that's it. It may be that you're missing what is sent by the time you get the terminal open?
pub main setup term.rxflush ' wait open terminal & keypress term.rx term.tx(term#CLS) term.str(string("Hello, World!", 13, 13)) repeat waitcnt(0)By doing this I can download to RAM (F10) and not miss anything sent to the terminal.
