Jeopardy Style Game control
I finally got my school division to install Blockly Prop after several months of a long battle! YEAH!
So I have just started tinkering in Blockly Prop and started a student challenge to build a jeopardy style game running on a personally designed board similar to the Prop Activity Board. My boards have access to pins 5 - 27. (Other pins are tied to specific robot control aspects like xbee etc)
Essentially I want 3 buttons which each control their own LED. When any one button is pushed, the Led Lights up and Locks all the rest of the players out until the Teacher pushes a 4th (separate Button to reset the code)
I have the code for the button and the lockout going which didn't take long.
However, I have spent several hours trying all kinds of arrangements to "reset" or (Clear all the prior commands) so that the LED's go out and all push-buttons are ready to trigger their LED for the next question. I don't want the instructor to have to cut the board off and on every time a new question is asked.
QUESTION: IS THERE A WAY TO "RESET" ALL THE PUSHBUTTONS in an IF ...ELSEIF loop in Blockly when each button is assigned the "break"command when pressed?
Thanks for any light anyone can shed on this.
My code is in the link below.
http://blockly.parallax.com/blockly/projectlink?id=31158&key=3765acb7-ddf1-475c-8045-a6b2c6657f0e
After the default break (exiting the switch/case) Just wait until the teacher button is pressed (repeat until teacher pin is high and teacher variable is true).
Tom M
This structured thing is out of control. It's so 90's.
Kind regards,
Kevin
I know the students are going to have fun with this!
Thanks again!
Kevin
Since the loop only has a couple of statements, I think that it will be quick enough that it will enter the case statement quickly enough to prevent 2 buttons from registering. If it does it will drop to the default. I not sure what will happen with switch bounces though.
Tom
In C using SimpleIDE, I use the "waitpne" command instead of looping to test for button presses which would be faster. I don't think that exists in Blockly.
Tom
In the "repeat until students" block I allow the teacher button (pin 8 ) to be part of the variable "students". If the teacher presses their button, or if there is a student tie, the value of "students" doesn't equal any of the cases, so the program goes to the default case. All 3 LEDs turn on, and there is a 1/2 sec delay. Then the program moves to the teacher reset section.
Tom M
Normal operation -
1. program clears LEDs and zeros the 2 variables.
2. waits (in a loop) until a student presses their button
3. lights the LED corresponding with the student who pressed the button ("students" bitwise and 0b111)
4. waits (in loop) for teacher to press their button
5. loops back to 1.
Error operation -
3a. If 2 or 3 students tie, lights all the LEDs corresponding with the students who tied ("students" bitwise and 0b111) means error
3.b If no student presses a button, teacher presses button & all LEDs light (if "students" bitwise and 0b1000) then pause 1/2 second
5. loops back to 1.
That would also allow button debouncing. In many of my Spin projects (some are being ported to Blockly), I run a background loop every 1ms; this lets me handle thinks like background buttons, a global timer, etc. very easily.
The program works but I found a couple of issues.
1. When the host (Alex or the teacher) presses the button to clear the LEDs, if the button is held too long, the program will pass through the "until students" loop (the teacher button pin will be high) and all 3 LEDs will light showing the error condition, so the teacher has to be quick on and off the button.
2. The sneaky contestant (student) could keep pressing their button while the teacher resets the LEDs, that would also pass through the "until students" loop (student button pin is high), and show their LED on.
The correction for both of these issues is to add a "while students" loop after setting the LED pins LOW, and before setting "student = 0". That stalls the program until all the buttons are released; then it proceeds to wait until a button is pressed. If the teacher presses their button to declare an error and holds it longer than 1/2 second, the LEDs will all light and then go out. But on a normal press/release the error will stay lit until the teacher button is pressed again. There is a pause block currently set for 500 ms, if longer or shorter delay is desired before the error LEDs go out if the button is held, just change that value.
The blocks are in: blockly.parallax.com/blockly/editor/blocklyc.jsp?project=34018#
Tom M.
You and I think alike, Master! I love me some short, crunchy Basic code.
Actually if looking for concise & crunchy, Peter could probably handle it in 1 (or maybe 2) lines of Tachyon, but I don't think that is the point of early educational programming. Simple examples are usually not very code efficient.
I miss my old Basic programmed computer (Compucolor 2), where simple (and not so simple) programs could be interactive, concise, and still readable. And it's one of the reasons, I enjoy programming in forth (ok, maybe not so readable, but the ability to redefine the language as you go was a good tradeoff).
Tom M.
