Problems with my Basic Stamp Projekt board.
Sylence_99Sylence_99 Posts: 1
edited 2018-02-07 - 01:03:12 in Microcontrollers
Hello everyone!
Earlier that day I connectmy new Microcontroller with my Pc. Everything works but after I want to start my Projekt nothing happend after I turned the electricity on. The LED on the circuit board wasnt on and nothing happend. What happend?
A few minutes erlier everything works. I tested it with an "test projetct" and in this Projekt everything was allright. I hope somebody have a solution. If you wand more information, just send me a message!
Sorry for my bad grammar, I'm from germany and not very good in english ;)
  • Not much information to go on, but the first thing to check is that you have power going to the board using a voltmeter.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • Check to see that both ends of the cable are fully inserted.
    Check your USB port with another device.
    Try a different cable.
    Try a different USB port.
    Post pictures. The more info you provide the more people can help.
    Any com port in a storm.
    Floating point numbers will be our downfall; count on it.
    Imagine a world without hypothetical situations.
  • Take a deep breath and start over.
  • Willkommen in diesem Forum.
    Hast du losen ihre problem?
