Anybody Using Lazarus?
JonnyMac
I'm looking for guidance on creating a cross-platform application that uses serial coms. I know it's possible because... well... BST!
We've used it under Windows fine.
There is also this thread I find
https://forum.lazarus.freepascal.org/index.php?topic=38283.0
that mentions some new alternatives. Not used those.
I see the comment "Note TLazSerial is just a component wrapper for Synaser....(Synapse)"
Mike R...
* Scan/Re-scan for available serial ports
* Select port from drop-down and connect to it
* Send simple data
* Receive data asynchronously
I've only run this in Window 10 though I am thinking about dropping into onto my RPi this week. The target for the test is a PAB with a simple program.
I did end up using the SynaSer library.
