DEBUG jams programming port
in BASIC Stamp
hi there,
My previous program on a BS2 chip was probablly coded with high speed polling on I/O pins over BS2 ,thus making me unable to write code into it again.
Is there anyway to solve? thanks in advance.
Kelvin, L.
Kelvin, L.
https://www.parallax.com/downloads/basic-stamp-editor-software-windows
Do you have a serial or USB connection?
You should be able to reprogram a BS if it is recognized by the the Basic Stamp Tool.
Good call Phil. Didn't think of that.
It is solved, thanks for the hints.
I was trying the new programmer, the "Parallax IDE on Chrome" on Mac OS X, with a "PL2302 Serial port to usb cable from Prolific Technology" connected to a BS2 BOE.
But the programmer IDE always took a long while to scan for the serial device, and always hint me with "Board did not respond, check power and connection" on /dev/tty.usbserial.
Later i use "CoolTerm - the serial terminal" and found out that BS2 has debug message keep comming out.
That's why I called for help.
I came back to Windows 7 and use Basic Stamp editor 2.5.3 to program it, it has no problem at all.
I don't know which part is wrong, but it seems the respond of programmer on Mac is way slower than on Windows.
