Modifying a RES directive before cog launch (or otherwise defining buffer sizes before cog launch)
Hey all.
For my VGA driver I'm passing in a couple variables from the Graphics wrapper: number of tiles per line, and number of lines per render.
Basically, using chip's same multi-cog methodology, I'm having n cogs each render interlacing lines of video, with a customizable number of lines per "render" (so @ 4 lines per render, cog 1 will render display 4 lines, then cog 2 will display 4 lines, then cog 1 will display 4 lines, etc.).
While cog 1 is displaying its 4 lines, cog 2 is populating its scanline buffer with data for the 4 lines it will display once cog 1 is done.
In order to reserve enough cog RAM for these buffers, I need to be able to RES numTiles x numLinesPerRender longs.
The problem is, it appears that RES amounts have to be either hard-coded inline or defined in the CON block. But if I'm passing these values in from the parent object, neither of these is viable.
Is there a way to define the size of a data buffer in a cog based on values passed to the containing object file? Or potentially by using the long declaration w/ a count modifier? To be clear I'm not attempting to dynamically allocate memory here; the size of the buffer will be known before cog launch.
Thanks!
Thanks!
I'm trying to figure out what you mean by "cog RAM". Do you want to use a buffer withing the cog or do you want to allocate a set amount of hub RAM for the cog to use?
"it appears that RES amounts have to be either hard-coded inline or defined in the CON block."
If I understand you correctly, you're right, you can't change the size of an array after compile whether is identified with RES or long.
Which VGA driver are you using? Can you tell us which line the RES variable is defined so we can follow along better?
Your program loads into the COG. Put a label at the end of your program and start your buffers there.
The COG RAM is seperate and always there. If you know you arent using that RAM, you also know nothing else will. It's private to the COG.
Long[50] 0
But like Duane I am slightly confused what you are asking for.
res does reserve space in a COG, but does not assign any values, so if you need to have a variable length of COG ram just use the last res and any COG memory left will be behind the last used COG address.
I need to define a buffer of size x in cog RAM (not Hub RAM).
As far as I am aware, I can do this by either doing:
I am passing the value of x to the .spin object which starts this cog.
As far as I know, the only way the x value can be defined is by explicitly setting it in the .spin object's con block (or obviously just hard-coding it inline).
Is there a way to have a value that is passed to a .spin object file be used to create a buffer of that value's size?
If this is the case, then I'm simply going to set them to the max size I would possibly require.
By contrast, doing this with a long buffer does affect your memory requirements.
Remember, though, that a res buffer can only be used by the PASM program that contains it. It will not work with Spin.
Thanks for the response; I think that's what I'm going to go with. Last question:
Given the following code:
If I use bar as an immediate value (e.g. mov test, #bar), will it be the same as #foo + 500?
Great thank you; the API makes it clear that the PC is affected by the res directive, but makes no mention of the effect it has on addressing. Yeah I picked some random numbers for the example without thinking about their legitimacy haha.
