Problems programming EEPROM
in Propeller 1
I'm using proploader to program my Propeller. It's on COM4 and when I run it, it works OK. It's only when I try and burn the image into the EEPROM.
My assumption is that I have something wired incorrectly or maybe proploader doesn't work with my 128K EEPROM.
It's a 25AA1024. All of the voltages check out and I have plenty of decoupling caps.
I have the following wiring:
/HOLD = VCC
SI = SDA from Propeller
SCL = SCL
/WP = VCC
SO = Not connected
/CS = GND
Here is the message I get when I try and program:
Any ideas?
/HOLD = VCC
SCL = SCL
/WP = VCC
SO = Not connected
/CS = GND
Delivering second-stage loader Downloading file to port COM4 2044 bytes sent Verifying RAM Programming EEPROM EEPROM programming error: expected fffb4600, got fff68c00 ERROR: Download failed: -1
Any ideas?
I swapped the EEPROM out for a 24FC1025 and it worked. I can use that one for now but I am curious why the other doesn't work.
Thanks for any help.
