In the quest to squeeze more into the PASM kernel I have used the otherwise unused wordcodes from $7C00..$7DFF to encode a 9-bit PASM instruction.
So instead of having a lot of repetitive 2 line PASM routines like:
' + ( n1 n2 -- n3 )
_ADD add tos+1,tos
jmp #DROP
I have instead replaced these with decoded wordcodes, so any useful PASM instruction that fits this criteria of 2 parameters in with one result is free!
$0000..$01FF directly executes cog PASM
$0200..$73FF calls hub wordcode
$7600..$7BFF <not used> - cog images are reused for buffers so no interpreted code would run here
$7C00..$7DFF PASM op - writes 9-bit instruction field and executes
$7Exx Task register offset
$7Fxx Conditional branch using signed 8-bit word displacement
While optimizing the wordcode decode sequence for 4.7 I decided to run the old fibonacci tests again however I couldn't seem to locate my test results from earlier versions. I guess I could load an old version and check it again, however the results look good I think.
Yeah, that's right David, some have had that discussion here before about recursive vs iterative but since the Tachyon return stack is held in the cog along with the kernel then there is a limit to the depth, 28 max in fact. So the iterative one gives me some idea but I'm testing out primes as well which is a better test really. Of course the only benchmark that ever really matters is the benchmark that a final application sets in the real world!
V4 runs a little slower in this simple Fibonacci routine since it has an extra PASM instruction for every Forth wordcode it fetches plus NEXT in FOR NEXT executes an extra instruction to allow for variable stepping. Overall though V4 is faster than V3 but I will check out the benchmarks and publish a table of execution speed for common operations and benchmarks.
I think the idea of the FIBO benchmark was not so much to see how long it takes to compute a Fibonacci number but more to test the efficiency of non-primitive function invocation. In Forth terms I suppose that would be non-primitive words. Does your prime number benchmark do that? In any case, my guess is the Tachyon likely outperforms most if not all of the other options on the P1. In this case I guess you're really just testing one version of Tachyon against another. I really need to go back to look at what you've done with "word codes" vs. "byte codes". On the surface it seems like word codes would produce less dense code but that doesn't seem to have happened with Tachyon.
Neat stuff. I made the jump from 8.8 to 9.2 SAP. I think this is the last upgrade I can do in one life time. All is well. Now to dust off my project boxes and get back into Tachyon for some real productivity. Got my three junior SAs watching the SAP bridge.
In simple programs bytecode is more efficient than wordcode, its execution loop is only 3 instructions which directly calls code in the first 256 longs of a Tachyon cog. But to access the other 256 longs it needs an extra bytecode and the delay associated with that too. Also for bytecode to call code in hub memory it needs an extra bytecode to index a vector table which points to the code or else it needs 2 extra bytecodes to point directly to the table. V3 uses a mix of these calls but of course needs to maintain a vector table of 256x4 entries using 4 different bytecode calls. Some fast constants are encoded as a bytecode which calls cog code for that value, so there are only a handful of fast constants as all other literals have to be made up by adding 1 to 4 bytes to a bytecode.
Contrast this with wordcode which can directly index all of cog memory and by using only one extra instruction in the execution loop can distinguish between cog or hub code. But since P1 hub memory is only usable in the first 32k then the msb is set to indicate that the other 15-bits are a literal, no need for fast constants. Now we have additional tests that continue to fall through while not impacting the speed of cog code that test for short conditional jumps, task register offset, or now a 9-bit pasm instruction encoded into wordcode. There is no need for a vector table and since all hub code is word aligned the lsb of the address is used to indicate a jump rather than a call. Overall, this is very efficient indeed.
The recent threads on the forum reminded me that there are a lot of goodies packed into a standard Tachyon kernel ready to run. Besides the normal WS2812 RGB LEDS, Ping sensors, DHT sensors, RTC, Serial etc I am also enhancing and adding many other drivers such as keypads and LCDs as standard that can be configured at runtime, so there is no need to compile the module and specify the pins at compile time, it is already loaded. To write to an array of 64 WS2812 RGB LEDs:
<myarray> 64 LEDS
Also, for instance, if you wanted a 4x4 keypad you would simply connect it up to 8 port pins, add 4 pullups, specify the starting pin:
8 !KEYPAD
and maybe an optional key beeper on P0
0 BEEPER
and all the key presses will be scanned, debounced, decoded, and buffered automatically without any extra cogs being used. In fact practically all the drivers run from the main Tachyon cog or the background timer cog.
To read the keypad you can read the next character with KEYPAD@ or simply make it the console keyboard device with KEYPAD. You can add your own decode table by sending it a string that corresponds to the keys like this:
" DCBA#9630852*741" KEYCODE!
Here is a document describing some of these devices and how easy it is to use.
This will all be part of the DEMONSTRATOR that I will get back into building.
Sounds great, but what does it mean? The other day I added a runtime configurable 4x4 keypad driver to EXTEND as a built-in device but as I was testing it on other hardware I had one device that had the row and columns scattered and not necessarily in order either. So I decided to redo the keypad driver so that I could specify a 32-bit mask for the rows and the same for the columns. These two longs are supplied to the keypad initialization routine !KEYPAD and the driver runs in the background only scanning and reading those bits that are specified in the masks.
Since we can have any combination of port pins for row and column this also means that it would be possible to scan a 16x16 matrix for 256 keys or even a 28x4 matrix etc. The driver generates a 10-bit code that corresponds to the row and column port pins and if a decode table is specified then the table is searched for a match but failing that it simply returns with the scancode.
How do you use it? Say if I had 4 columns on P0, P2, P4, P6, and 4 rows on P8,P9,P10,P11 I would start up the scanner with:
%1111_00000000 %01010101 !KEYPAD
As with the earlier driver you can also specify a beeper and also redirect console input to come from the keypad too etc.
To test out the use of the new keypad encoder and LCD driver that is now built into Tachyon I wrote a very small calculator app (316 bytes).
In the process I found that the lines that I shared between the LCD and the keypad were causing problems as the keypad was
being scanned by the timer cog and the LCD could be written to anytime. So I decided to buffer the LCD so the timer cog is now responsible
for refreshing the LCD. This also means that the LCD can be called from another task without I/O conflicts or delays.
Anyhow, the calculator is setup on a 20x4 LCD along with a 4x4 keypad and the LCD displays the last three entries over 3 lines.
EDIT: perhaps I could interface F32, the floating point ROM built-into Tachyon and add a larger keypad for a programmable scientific calculator!
TACHYON
Demonstrate use of built-in KEYPAD and LCD objects
by running a simple 4 function RPN integer calculator
using a 20x4 LCD and a 4x4 keypad
along with a piezo transducer for sounds.
--- table for P1144 PCB and 4x4 keypad ---
TABLE K1144
$0CB || '1' || $08B || '2' ||
$04B || '3' || $00B || 'A' ||
$0CA || '4' || $08A || '5' ||
$04A || '6' || $00A || 'B' ||
$0C9 || '7' || $089 || '8' ||
$049 || '9' || $009 || 'C' ||
$0C8 || '*' || $088 || '0' ||
$048 || '#' || $008 || 'D' ||
0 ||
byte ent --- new entry flag
byte digits
pub .ITEM CR 5 SPACES DUP ABS $6A0A PRINTNUM 0< IF '-' ELSE $20 THEN EMIT ;
--- home - display top 3 on stack
pub DISPLAY 1 EMIT 3RD .ITEM OVER .ITEM DUP .ITEM ;
pub CLOCK 1 EMIT .DATE SPACE .TIME ;
--- reenter? flag as entered
pub ENTER ent C@ IF DUP THEN ent C~~ digits C~ ;
--- Clear stack and push 3 dummy values
pub CLEAR LCD CLS !SP 0 0 0 ent C~ digits C~ ;
pri ADD ENTER + ;
pri SUBTRACT ENTER - ;
pri MULTIPLY ENTER * ;
pri DIVIDE ENTER / ;
pub KEYFNC
SWITCHES
'*' CLEAR
'#' ENTER
'A' ADD
'B' SUBTRACT
'C' MULTIPLY
'D' DIVIDE
NOP ( end switches with any non literal )
--- start new entry?
ent C@ IF 0 ent C~ THEN
digits C@ 9 < 0EXIT
--- add in new digit
10 * SWITCH@ '0' - +
digits C++
pub !IO
--- These I/O on the P1144 need to be taken low
16 LOW 14 LOW
--- Setup keypad masks and key beep
K1144 %1010101 %1111_0000_0000 !KEYPAD
19 BEEPER
--- &ch.ln &bl.ce.rs.dat - setup LCD
&20.4 &18.17.15.0 !LCD
19 SPKR
16 longs calclp --- V4.7 loop stack (external in V4.5+)
pub CALC.TASK
calclp LP!
!IO RING
CLEAR DISPLAY
BEGIN KEYPAD@ ?DUP IF KEYFNC DISPLAY ELSE CLOCK 100 ms THEN AGAIN
--- LAUNCH CALCULATOR as a background task ---
pub CALC ' CALC.TASK 3 RUN ;
END
Hi there,
I'm working on a telnet application using an IoT5500.
.. .VER Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400 ok
.. .MODULES *** MODULES ***
Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.0
52FA: EASYNET.fth WIZNET NETWORK SERVERS 170821.0000
4A74: W5500.fth WIZNET W5500 driver 170708.0000
3800: EASYFILE.fth SDHC card + FAT32 Virtual Memory Access File System L
1B40: EXTEND.fth Primary extensions to TACHYON V4.5 kernel - 170814-1k
So far everything is working, but if the cable is plugged out there should be done some clean up code before leaving the connection.
REVECTORING BYE seemed the right place to do the cleaning up as you see here:
TACHYON V4
FORGET TEST1234
\ translate uSoll into dir and enable
pub TEST1234 ;
#P14 == _enable \ switch motor voltage on
#P15 == _dir \ 0: clockwise 1: counterclockwise
#P21 == _red \ red LED
#P22 == _green \ green LED
\ --- declare list of tx signals
5 LONGS myruntime
myruntime 4 + ORG
4 DS txcnt
4 DS RegArt
4 DS uSoll
4 DS var3
\ --- initialize signals
-1 txcnt ! \ increment before every send
0 RegArt !
0 uSoll !
0 var3 !
pub BYE
." orig BYE is called"
_green HIGH
_red HIGH
\ --- revector BYE for structured disconnection
WORD old_BYE
' BYE old_BYE W! \ remember old EASYNET BYE
pub new_BYE
." new BYE is called"
_enable FLOAT
_dir FLOAT
_green FLOAT
_red FLOAT
\ old_BYE W@ CALL
; \ --- sDISCON CON SKT@ .SOCKET LAN ;
\ REVECTOR BYE new_BYE
END
This is working fine
.. BYE orig BYE is called ok
.. new_BYE new BYE is called ok
. REVECTOR BYE new_BYE
.. BYE new BYE is called ok
The problem lies in the word new_BYE where I wanted to CALL the original (' old_)BYE word but that isn't working as expected: What I'd like to do is
old_BYE W@ CALL new BYE is called ok
but as shown new_BYE is called nevertheless .
Does anybody have an idea how I can call the old BYE word (maybe adding some offset bytes?
If I remember right this was working before V4r5 ?!
Hi there,
TACHYON V4
FORGET TEST1234
pub TEST1234 ;
5 LONGS myruntime
myruntime 4 + ORG
4 DS txcnt
4 DS RegArt
4 DS uSoll
4 DS var3
0 RegArt !
0 uSoll !
0 var3 !
pub BYE
_green HIGH
_red HIGH
WORD old_BYE
pub new_BYE
_enable FLOAT
_dir FLOAT
_green FLOAT
_red FLOAT
\ old_BYE W@ CALL
END
Thanks in advance,
proplem
Hi Proplem,
in V4.5 REVECTORING has changed.
The first WORDcode of the old wordcode is replaced by a jump to the new wordcode.
So the saved pointer to the old location will no longer work, actually just point to the new definition.
But the old one is still there - just the first wordcode was lost.
So you could copy the first wordcode of the to be redefined word to a save location and add a jump to the rest of the old code. ... will not work in many cases ... not a good solution.
Or you could copy the complete original definition somewhere and point to it
It is to late to do the full experiments -
here just the first part:
REVECTOR writes the address of the new routine into the first word of the old routine but it also sets bit0 of that it does a jump rather than a call. Be aware too that the simple test case of printing a string as the "first" word in a routine cannot be replaced with a call as the code would return to execute the string and crash. So it needs to be a jump which revector does.
Anyway, why don't you just create the new BYE which includes source code from the original, and then revector the original to the new.
pub new_BYE
_enable FLOAT
_dir FLOAT
_green FLOAT
_red FLOAT
All code that calls the original BYE will jump to new_BYE.
BTW, I'm thinking of writing a standalone app to make the IoT5500 a serial gateway with some extras, such as direct access to a target's Propeller to allow reprogramming by sending a file via FTP or even reading the target.
Tachyon is nice to use interactively but for longer larger FORTH source I prefer to use a text editor.
Too often I forgot to save before uploading in minicom. So I created a simple IDE consisting of a text editor, a simple terminal and a function to upload the text without the need to first save it.
I have created a github project for this: https://github.com/rbehm-ibb/Tachyon-IDE.
This is currently quite unfinished work, it needs an ANSI interpreter in the terminal.
Peter, I hope you don't mind that I stole your "Use the Forth" logo for this.
I also tried the ESPLORER made for ESP8266 with Tachyon.
But I don't like the missing direct entry to the terminal.
pub new_BYE
_enable FLOAT
_dir FLOAT
_green FLOAT
_red FLOAT
but I prefer the method MJB gave some hints for.
Why? I want to use EASYNET I don't want to copy or change it. If I'd copy the code, what would happen if Yoda decided to change the BYE word without asking his padawans? All padawans code would be wrong or incomplete.
The current implementation of the REVECTOR mechanism lacks the functionality of un-REVECTORing . This could BTW be one snippet of the clean up code I want to implement.
This is just one example of a general topic. In my opinion the previous implementation of REVECTOR was better in this way and I'd like to get this functionality back.
@ MJB - thanks for your suggestion. I couldn't reproduce and analyze it further (time is short). Further I think this should be solved in tachyon itself.
Proplem - the only way that REVECTOR could work in V3 was via the vector table which only existed for the first 512 calls.
Originally there was room in the vector tables for 1,024 entries but at some point it runs out and so 3 bytes were used in a call with one bytecode plus 2 bytes for a 16-bit address. By the time EASYNET is loaded this table has long been exhausted and high level calls were using 3 bytes and therefore they were not revectorable.
V4 by contrast does not need vector tables and a call is always one wordcode, so it is easy to replace the first wordcode with a jump. I do this all the time but if I want a little flexibility I simply add a NOP as the first word so it can be replaced with a call rather than a jump and after the return everything executes normally. For instance, this is the way that I patch in LED indicators for EASYFILE and EASYNET, as some systems have them and some don't, and the methods to access them vary. So the V4 REVECTOR works well in this regard. If it makes it easier for you I will simply add a NOP as the first wordcode in BYE.
Hi Reinhardt, how are the Taiwanese helicopters going?
Thanks, I downloaded your code immediately after you posted but I didn't want to bury your post too soon by replying immediately. I did try to import it as a project into QT Creator running on Linux but it was missing config.h when I went to build it. I think I have to check my other settings when I get back to it.
btw, I normally use sublime or medit and then run minicom as a terminal and just alt-tab between windows copying and pasting. I never really type more than one line in interactively as I find it very easy to copy and paste from the editor.
Don't know, my customers are mainly on the other side of the planet (br, us).
Maybe you were too fast. I had not yet put my standard lib files into the repo. This is fixed now.
An interesting feature I have included is a very simple parser for the FORTH source. It extracts all definitions (CONSTANT, == : PUB PRI, PRE, ..) and collects them into a list displayed in a sidebar. You can click into that and it jumps the editor window to this definition. I would also add a quick access to some help files in the future.
It is really difficult to get managed with this because it dives quite deep into the internals for which I'm too short in time. I know from a didactic view it would be better to learn but practical requirements avoid that.
So I have to choose the copy version too be quicker.
As a feature request for Tachyon-P2 I would like REVECTORing implemented in the classical manner because it is more generic.
Thanks for understanding,
proplem
In Symbolics Lisp-MAchine Lisp we had nice things like before and after demons and wrappers
which allowed dynamic modification, extension and redefinition of functions.
While those could be implemented in Tachyon as well and would be great,
REVECTOR is one of those,
I would NOT want to waste space or sacrifice performance for a rarely used feature
if there are ways around for exceptional use cases.
The COPY approach workes well.
Extending every definition with a NOP just in case s.o. wants to revector it
costs space and slows down.
And if s.o. needs s.th. special you could create a Tachyon word / mechanism that does this without sacrificing general efficiency.
Like dynamically copying the to be REDEFINED word to a safe location and do the patching.
All the required introspection capabilities, access to the dictionary etc. are there.
But you are right - it takes some time and learning curve to do it.
The words doing a lookahead like ." make things a little tricky.
Hi PEter,
long time ago we talked about nRF24L01+
did you ever write code for it?
I am just getting back to a possible application and still have some unused parts here ...
Hi PEter,
I never did get these setup but only just the other day I was looking at what I could use for a link over 30m and of course these chips certainly are a possibility. I may end up getting sidetracked......
Hi PEter,
Sweeet! I just bought 10 of these and havent used them yet
Hi there,
currently reactivating some pre v4r5 code I found this word:
: !LCD lcdmem 4 COGREG! 4 3 COGREG! [PLOT] ;
With my own words this code writes the address lcdmem into cog memory 4 and then writes a 4 into cog memory address 3. After that the plot code is loaded into cog memory.
I would translate this into v4r5 like this:
: !LCD lcdmem 4 COG! 4 3 COG! [PLOT] ;
Correct? Or do I have to pay attention for something else?
@proplem - yes, only adjust any hard-coded constants by +1. These registers start in address $001 so they were simply offset and can of course write anywhere in cog memory.
So instead of having a lot of repetitive 2 line PASM routines like: I have instead replaced these with decoded wordcodes, so any useful PASM instruction that fits this criteria of 2 parameters in with one result is free!
CON { wordcoded PASM operations } _AND = $7CC1 _ANDN = $7CC9 _OR = $7CD1 _XOR = $7CD9 _SHR = $7C51 _SHL = $7C59 _SAR = $7C71 _ROL = $7C49 _ROR = $7C41 _REV = $7C79 _SUB = $7D09 _ADD = $7D01 _CMPSUB = $7DC1 _MIN = $7C99 ' Forth MIN takes the minimum value vs PASM _MAX = $7C91 _MINS = $7C89 _MAXS = $7C91 _ADDABS = $7D11WORDCODES
EDIT: No, I've done better it looks
V4.7
<myarray> 64 LEDS
8 !KEYPAD
0 BEEPER
How do you use it? Say if I had 4 columns on P0, P2, P4, P6, and 4 rows on P8,P9,P10,P11 I would start up the scanner with: As with the earlier driver you can also specify a beeper and also redirect console input to come from the keypad too etc.
TACHYON { Demonstrate use of built-in KEYPAD and LCD objects by running a simple 4 function RPN integer calculator using a 20x4 LCD and a 4x4 keypad along with a piezo transducer for sounds. } --- table for P1144 PCB and 4x4 keypad --- TABLE K1144 $0CB || '1' || $08B || '2' || $04B || '3' || $00B || 'A' || $0CA || '4' || $08A || '5' || $04A || '6' || $00A || 'B' || $0C9 || '7' || $089 || '8' || $049 || '9' || $009 || 'C' || $0C8 || '*' || $088 || '0' || $048 || '#' || $008 || 'D' || 0 || byte ent --- new entry flag byte digits pub .ITEM CR 5 SPACES DUP ABS $6A0A PRINTNUM 0< IF '-' ELSE $20 THEN EMIT ; --- home - display top 3 on stack pub DISPLAY 1 EMIT 3RD .ITEM OVER .ITEM DUP .ITEM ; pub CLOCK 1 EMIT .DATE SPACE .TIME ; --- reenter? flag as entered pub ENTER ent C@ IF DUP THEN ent C~~ digits C~ ; --- Clear stack and push 3 dummy values pub CLEAR LCD CLS !SP 0 0 0 ent C~ digits C~ ; pri ADD ENTER + ; pri SUBTRACT ENTER - ; pri MULTIPLY ENTER * ; pri DIVIDE ENTER / ; pub KEYFNC SWITCHES '*' CLEAR '#' ENTER 'A' ADD 'B' SUBTRACT 'C' MULTIPLY 'D' DIVIDE NOP ( end switches with any non literal ) --- start new entry? ent C@ IF 0 ent C~ THEN digits C@ 9 < 0EXIT --- add in new digit 10 * SWITCH@ '0' - + digits C++ ; pub !IO --- These I/O on the P1144 need to be taken low 16 LOW 14 LOW --- Setup keypad masks and key beep K1144 %1010101 %1111_0000_0000 !KEYPAD 19 BEEPER --- &ch.ln &bl.ce.rs.dat - setup LCD &20.4 &18.17.15.0 !LCD 19 SPKR ; 16 longs calclp --- V4.7 loop stack (external in V4.5+) pub CALC.TASK calclp LP! !IO RING CLEAR DISPLAY BEGIN KEYPAD@ ?DUP IF KEYFNC DISPLAY ELSE CLOCK 100 ms THEN AGAIN ; --- LAUNCH CALCULATOR as a background task --- pub CALC ' CALC.TASK 3 RUN ; ENDbeat that, Spin, C, PropBasic....
don't stop teasing, Peter,
Enjoy!
.. .VER Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400 ok .. .MODULES *** MODULES *** Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.0 52FA: EASYNET.fth WIZNET NETWORK SERVERS 170821.0000 4A74: W5500.fth WIZNET W5500 driver 170708.0000 3800: EASYFILE.fth SDHC card + FAT32 Virtual Memory Access File System L 1B40: EXTEND.fth Primary extensions to TACHYON V4.5 kernel - 170814-1kSo far everything is working, but if the cable is plugged out there should be done some clean up code before leaving the connection.REVECTORING BYE seemed the right place to do the cleaning up as you see here: This is working fine The problem lies in the word new_BYE where I wanted to CALL the original (' old_)BYE word but that isn't working as expected: What I'd like to do is but as shown new_BYE is called nevertheless .
Thanks in advance,
proplem
Hi Proplem,
But usually I use Notepad++ with a Tachyon mode.
of course you're right one could do it like this but I prefer the method MJB gave some hints for.
Thanks to you both, best regards,
proplem
proplem
currently reactivating some pre v4r5 code I found this word: With my own words this code writes the address lcdmem into cog memory 4 and then writes a 4 into cog memory address 3. After that the plot code is loaded into cog memory.
I would translate this into v4r5 like this: Correct? Or do I have to pay attention for something else?
Thanks, proplem
From the source code around line 6822 (in V4.7)
org REG1 res 3 pixshift res 1 pixeladr res 1The pixshift of 4 is x16 bytes or 128 pixels.
I've got a nesting loop issue: results in Obviously K isn't usable.
Is there a way to nest loops more than twice?
proplem
