Propeller Activity Board WX I2C Far infrared sensor array
I can't figure out this I2c stuff. The dyi I2c does not help. The device asks for commands etc. In desperate need of help.
device: Far infrared sensor array at high speed with low noise (16x4 RES) - MLX90621
https://www.melexis.com/en/product/MLX90621/Far-Infrared-Sensor-Array-High-Speed-Low-Noise
For example, how do I setup communication?
For example the datasheet staes
Figure 4 Whole EEPROM dump (SA = 0x50, command = 0x00)
My modified code:
#include "simpletools.h" // Include simpletools header
i2c *eeBus;
// I2C bus ID
int main() // Main function
eeBus = i2c_newbus(9, 8, 0); // Set up I2C bus, get bus ID
// Use eeBus to write to device
i2c_out(eeBus, 0x50, // with I2C address 0b1010000,
0x00, 1, 0x04, 1); // send address 32768 (2 bytes)
// and "abc..." data (8 bytes)
while(i2c_busy(eeBus, 0b1010000)); // Wait for EEPROM to finish
char testStr[] = {0, 0, 0, 0, 1, 0, 0, 0}; // Set up test string
// Use eeBus to read from device
i2c_in(eeBus, 0x50, // with I2C address 0b1010000,
0x00, 1, testStr, 8); // send address 32768 (2 bytes)
// data in to testStr (8 bytes)
print("testStr = %s \n", testStr); // Display result
My modified code:
i2c *eeBus;
// I2C bus ID
'The dyi I2c does not help'
Are you saying you found sample code and it does not just paste right in with a little rewriting?
EDIT
Here's google search
https://www.google.com/search?q=propeller+C+i2c+example&ie=utf-8&oe=utf-8
Caldwell
http://learn.parallax.com/search?search_api_views_fulltext=propeller+i2c
Call support. You bought an activity board. It has I2C. Where's the code for it?
Andy Lindsay wrote the articles,
Call Parallax and see if they can rustle him up for you or get his email.
That is if you are really stuck.
With Parallax you are paying for support.
I can steer you to microcontrollers where you submit a help ticket and it gets ugly from there.
Well.
Then he needs to contact sensor outfit.
Electronics forum would probably help.
This seems to be pretty detailed:
https://github.com/Leenix/MLX90621-Lite/blob/master/MLX90621.cpp
i2c *eeBus; // I2C bus ID
eeBus = i2c_newbus(28, 29, 0); // Set up I2C bus, get bus ID
i2c_out(eeBus, 0b1010000, // with I2C address 0b1010000,
32768, 2, 6, 2); // send 2 byte address of 32768
// and 8 byte data string.
//int testStr[] = {0, 0, 0, 0, 0, 0, 0, 0}; // Set up test string
int data = 4;
i2c_in(eeBus, 0b1010000, // with I2C address 0b1010000,
32768, 2, data, 2); // send 2 byte address of 32768
// & store data in 8 byte array.
print("testStr = %d \n", data); // Display result
Why dont this code write 6 to the eeprom address and return it to data.?
int data = 4;
Take a look at this.
http://forums.parallax.com/discussion/97595/eeprom-memory-mapping
The third or fourth post down.
Hope that helps!
